WOW ... stop the rust while you can ...
Old Oct 27, 2009 | 09:58 PM
  #301 (permalink)
Irafatsar's Avatar
Default Re: WOW ... stop the rust while you can ...
I guess there are benefits to living where it never rains, detailed the car and still no rust.
Old Oct 28, 2009 | 09:54 AM
  #302 (permalink)
mbepic's Avatar
Cool Re: WOW ... stop the rust while you can ...
That is enough reason for moving my Xfire to Arizona this Fall;
Now, all I have to worry about is the headliner caving in from the dry heat???
Old Oct 28, 2009 | 10:14 AM
  #303 (permalink)
blackcrossfire07's Avatar
I asked the guy at a body shop to check it out for me. I said it was a common problem. He didn't want to do it.... told me a little rust is bound to happen and said it is best not to pull the strip off (because getting it back on is a pain). I offered to pay this guy (who has been doing this 30 years) and he could have easily done the job and made money but he refused. He felt like it wasn't worth it.
By the way, water does run down through the door when it rains and out the bottom holes. No car is 100% water tight. They are all designed to let water flow through the inner panels of the door (most of the water flows on the outside).
Old Oct 28, 2009 | 10:39 AM
  #304 (permalink)
mbepic's Avatar
I have to tell you that you don't need a body guy to check the bottom of your door yourself; taking the rubber out of the track and then reinstall is not a difficult thing to do.
I hope that when somebody checks this, you get it treated with rust inhibitor for future because this can be serious as you have seen from an earlier post. Even a little sign of rust in this area indicates that moisture is being trapped under the rubber. It is a vulnerable area for rust damage. Many readers of this thread have checked the area themselves and then treated the problem to avoid future damage.
Your body man is taking a very 'uninterested' view about this............bigger 'fish to fry', I guess.
Old Oct 28, 2009 | 11:14 AM
  #305 (permalink)
+fireamx's Avatar
IRA you're very lucky, because the very first post of a rusted door photo that I remember was on a grey Crossfire from Arizona. I'm pretty sure it was posted even before Andrew's historic thread.
If the car never gets wet (by rain or car wash) that's about the only way from keeping water from getting trapped underneath the seal.
Your seal must fit extreamly well, (or you send your car to the dry cleaners)
Rimshot, the trough is part of the door, I don't think it's a replacable part.
I don't recommend doing it, but some people have actually removed the rubber seal at the bottom of the door. If my trough rusted away, I'd probably try it, since you're probably going to have to find some replacement doors anyway.
Old Oct 28, 2009 | 02:44 PM
  #306 (permalink)
I happened to be there getting something done so I asked him to take a look at it. I considered checking it out myself... then decided it wasn't worth it. A lot of other things will rust underneath the car first before my door falls apart. That is just the way I feel about it. And I take very good care of my car and plan on keeping it for a long time.
Old Oct 30, 2009 | 03:16 PM
  #307 (permalink)
Irafatsar's Avatar
Roy
when are you heading out to AZ ?
Old Oct 30, 2009 | 09:54 PM
  #308 (permalink)
mbepic's Avatar
Roy
Ira...........we are down in Port Charlotte Florida as of today and will be staying here at least four nights, so by the middle of next week, we should be heading north again to the Panhandle and then make that 90degree turn to the left............Hwy 10 Phoenix bound.
We may stop along the way a little but expect to be in Phoenix by mid November at the latest.
They say it is a 'dry heat' and 'rust free'........oh I hope that is true!
BTW, the Xfire cruised like she was riding on air........hee hee; man I like this car!
Old Jan 13, 2010 | 07:09 PM
  #309 (permalink)
antonio311's Avatar
Chrysler has set up a complaint hot line for customers to call with issues. They told me the more people who call about a specific complaint like Door rust & weather stripping that holds in the water, the more likely they'll fix the issue! So I suggest everyone call with their vin # and file a complaint about the weather stripping holding in moisture & door rust!!!!
  • 800-CHRYSLER (800-247-9753)
  • 877-IAM-JEEP (877-426-5337)
  • 800-4ADODGE (800-423-6343)
  • 866-RAMINFO (866-726-4636)
Old Mar 23, 2010 | 08:02 PM
  #310 (permalink)
Headlock's Avatar
Will LPS-3 be effective?
Thanks,
Nick
Old Mar 23, 2010 | 09:54 PM
  #311 (permalink)
RMADERMAN's Avatar
Took Ashly's SRT to the dealer last night to have other work done and Chrysler rep was there today. I showed them the rust and they agreed to fix the rust problem. Showing them the problem was easy with the lambo doors.
Now I need to check mine.
PS. To all SRT owners, please check under your wing. I have had both wings off and there were both showing the beginning signs of rust.
Old Mar 23, 2010 | 10:02 PM
  #312 (permalink)
Headlock's Avatar
What part of the wing?
Old Mar 23, 2010 | 10:06 PM
  #313 (permalink)
RMADERMAN's Avatar
Under the pillars.
Old Mar 23, 2010 | 10:39 PM
  #314 (permalink)
Headlock's Avatar
Thanks, still haven't gotten a response from anyone regarding the LPS-3 rust inhibitor.
Old Mar 25, 2010 | 04:41 AM
  #315 (permalink)
antonio311's Avatar
When you remove the wing, there is a piece of metal that is infused to the wing mount that has the mounting bolts coming from it, that you secure to the hatch. That metal that has the bolts is not painted & is bare metal. This is what rusts!!!
Why the heck they wouldn't paint that metal???? I have no idea! Just scrape it down, to remove the rust, then paint the metal or treat it with rust inhibitor. I used the clear por 15 on mine & it came out great!
Now I have to do the Ragtop!
Old Mar 25, 2010 | 07:32 AM
  #316 (permalink)
radmanly's Avatar
Scrape it how? Did you sand it or wire wheel it?
Old Mar 25, 2010 | 08:49 AM
  #317 (permalink)
Harvey's Avatar
Banned
If it wasn't for Texas, driving from Florida to Phoenix would be easy.
Old Mar 25, 2010 | 10:59 AM
  #318 (permalink)
mbepic's Avatar
You got that right.........Texas has to be the worst waste of a day.
Old Apr 20, 2010 | 08:53 PM
  #319 (permalink)
rfors777's Avatar
Just looked at my '04 and there is indeed rust! I am buying Rust Bullet right now, and I will fix it next weekend. Thanks to everyone on this forum for making it really easy for a new Crossfire owner to find, and fix, the common problems.
Old Apr 21, 2010 | 01:05 AM
  #320 (permalink)
Thems fighting words in some parts.
