blower problem cause
Old Jan 26, 2014 | 03:51 PM
rip it's Avatar
Exclamation blower problem cause
I am presently t/s my inop blower. I removed the blower and connected 12vdc directly to the motor and nothing happened until I rotated the fan blade. It slowly spun up to high speed. I ran it for ~30 seconds. I touched the brush holders and one of the 2 burnt my finger. Checking the resistance with my meter shows mostly open as I rotated the blade. I believe the cause of the problem is the result of a clogged cabin air filter. I pulled mine and found green exterior carpet, mouse do do, an some other ufo material. I am guessing it probably was only allowing 10% air flow which would cause excessive heat to the motor and regulator.
Old Jan 26, 2014 | 05:12 PM
Default Re: blower problem cause
I'd think probably one or both of the carbon motor brushes is shot, or the commutator on the rotor is all gunked up.
Old Jan 26, 2014 | 05:46 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Is there a capacitor on these blowers required for start?
180 will know !
Old Jan 26, 2014 | 05:49 PM
There is a problem with the motor, clean up the brushes, one may be sticky in its slot and wipe the commutator with paraffin or electronics cleaner, check the bearings. It should easily turn by hand.
You may have to buy a motor, if so keep the control pack on it as it costs more than the motor if it is OK.
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
55chevy
Sep 13, 2015 07:38 PM
rdougc
Sep 5, 2015 10:30 PM
