Replacing interior netting on storage pockets
Old Jan 15, 2020 | 07:25 PM
Scotto97's Avatar
Default Replacing interior netting on storage pockets
The storage netting on my doors and passenger foot well has become loose and saggy, along with the storage pocket material behind the seats.
Has anyone came up with a solution to restore or replace these areas?
Old Jan 15, 2020 | 11:01 PM
Default Re: Replacing interior netting on storage pockets
There is a post on it somewhere, I’ll look.
Old Jan 15, 2020 | 11:14 PM
KeithTexas's Avatar
Mine was sagging, too, on both doors. I just pulled the top line a little tighter and tied a knot in it. It's been doing well like that for a year.
I hope there's a better solution for it.
Old Jan 15, 2020 | 11:20 PM
See the thread titled ‘Cargo net’ by Tazz. (CLICK)
Oops!
This is not the thread I was meaning, sorry I will look again.
Old Jan 16, 2020 | 10:37 AM
KeithTexas's Avatar
Besides just tightening up the top string and tying a knot, I also bought this little pocket door bin on amazon. It serves the purpose to hold a few little things. Then, the netting becomes just cosmetic. I've had it two years and still like it.
amazon car door pocket bin amazon car door pocket bin
Sure wish there was an easy replacement item for the netting, but I can't find it. Maybe that's an opportunity to create something.....
Old Jan 16, 2020 | 11:23 AM
I'll try again, this is the one I had in mind.
Here is the solution by Longbeach90814. CLICK
Old Jan 16, 2020 | 11:39 AM
maggy55's Avatar
I bought some 1/8 inch bungee cord ,https://www.ebay.com/itm/USA-1-8-x-1...sAAMXQt~hSKlHI, cut the old cord out at each end. Measured out the new cord to about 2/3rds the length of the pocket. Tied a couple of tight knots in one end. I was able to separate the panel from the door just enough to push the knot through the hole. Wove the new cord through the net an did the same thing on the other side. It's not a perfect solution , but it works
Old Jan 16, 2020 | 01:27 PM
That sounds like a good plan. They are getting old and starting to sag just like me.
I wonder if a 1” nail pushed halfway through 2” from the end and then it and the bungee chord are pushed through the hole. I think the nail would return to 90 degrees and stop the bungee chord coming out. Do it both ends and your done
Old Jan 16, 2020 | 04:43 PM
Scotto97's Avatar
That's what I've done so far - just tied a knot, but it looks bad.
Has anyone taken their door panel off to see if the existing cord could be shortened or a new and similar bungee cord could be installed?
Old Jan 22, 2020 | 02:42 AM
lotsofspareparts's Avatar
Yes you can, here is a link to an ebay page....https://www.ebay.com/itm/04-08-Chrys...ry!98292!US!-1
If you zoom in on the back side of the panels, you can see where the bungee comes through.... very apparent when you look for the white dots (rubber cording). I would have copied the pictures and posted them, but I'm unsure as to how much resolution would have been lost.
Here is another link for the bungee cord...… you can order it in contrasting colors as well..... https://www.ebay.com/itm/1-8-Shock-C...MAAOSwRJpbccB1
The netting in my most recent XF purchase is showing its age. I was also researching replacing the cording.
Jared
Old Jan 22, 2020 | 07:27 AM
RED DOG's Avatar
If you remove the door panel, you can tighten the top cord by pulling on the end (you'll see the metal ball attached to the end of the cord where it comes through the back side of the door panel). When you pull it tighter it will automatically lock into the new tighter position.
SkineeMinee
May 20, 2025 09:53 AM
Brian P
May 22, 2019 08:48 PM
wvwonder
Dec 18, 2014 10:43 PM
doggboy
U.K.
Jan 4, 2012 12:14 PM
the avenger
Sep 26, 2009 01:42 PM
