Hi Beam Flashing Mode Not Working
Old Apr 21, 2021 | 12:17 PM
Jack G's Avatar
Default Hi Beam Flashing Mode Not Working
The hi beam on/off switch on the steering column does not turn on the hi beams when the turn signal lever is pulled up or pushed down. The lever does turn on the hi beams however, when the lo beam headlight switch is in the on position. The blue hi beam icon is also displayed on the dash. Could this be a switch related problem or a blown fuse?
Old Apr 21, 2021 | 12:56 PM
Default Re: Hi Beam Flashing Mode Not Working
Do your wipers work? If not, it's fuse 32. See below.
Old Apr 21, 2021 | 02:13 PM
The multi function switch will only flash the high beams by pulling it toward the driver when the switch is in the OFF position, it will not turn ON the high beams.
It will turn ON and FLASH the high beams by pushing it forward and pulling it back respectively, when the low beams are ON.
I would guess you have a switch problem.
Old Apr 21, 2021 | 02:31 PM
Jack G's Avatar
I am not expecting the hi beams to be controlled to turn on and stay on when the light switch is off. I want to be able to flash my hi beams when the switch is off. As previously indicated the hi beams work normally when the light switch is on lo beam. The flashing mode is mentioned in the operators manual. I also drive an E class Benz that has the same type of light switching.
Old Apr 21, 2021 | 05:12 PM
That is not what the first sentence of your first post said. You should have been more specific and used the word FLASH not the word ON.
We can only go by what you write not what is in your head.
I just said what actually occurs and added my comment.
Old May 2, 2021 | 09:25 AM
Jack G's Avatar
I have checked out some of the suggested items which can prevent flashing of high beams. The following items have been checked: wipers work, directional signals work, fuse #32 is good, installed a new RCM, all the lights are working.
Thanks
Jack G
Oct 27, 2021 10:19 AM
EbonyXF
Sep 10, 2016 04:40 PM
Bob B
Mar 23, 2015 02:52 PM
Bolisg
Aug 13, 2012 07:56 PM
TX_xfire
Aug 21, 2009 03:15 PM
