I assume I am right ...
Old Jul 14, 2014 | 05:13 AM
Bay Cruise's Avatar
Default I assume I am right ...
So driving down the highway on cruise have to brake and cruise won't switch off, brake again and nope cruise won't switch off and yep BASESP light pops up so use stalk to disconnect cruise.
Pull in to service station ask wife to check brake lights and sure enough they are not working. Pump brakes and wow lights come on but only once so still no brake lights. Get on the phone and order a brake peddle switch as I think that's gone duff. Have to wait till Thursday before they have one in and I know it's only a 2 minute job to fit so no problem there. However plugged in my obd today and get no codes at all !!!!!
I assume I am right regards the switch......
Old Jul 14, 2014 | 09:57 AM
Bill F's Avatar
Default Re: I assume I am right ...
Have you checked the fuses?
Old Jul 14, 2014 | 04:41 PM
Bay Cruise's Avatar
I will assume that the fuse is ok as the lights did come back on again albeit only once, however good suggestion but what is the fuse number and is it under the bonnet or the box on the side of the drivers dash.
Old Jul 14, 2014 | 04:58 PM
sounds like a faulty switch. But corrosion can happen in the fuse box as well, not allowing contact. Doesn't hurt to just pull the fuses out and put them back in, scoring them a bit as you return back into the prongs. This should be done on all of them from time to time as these little cars are very voltage sensitive.
Old Jul 14, 2014 | 05:00 PM
Bay Cruise's Avatar
Do you know what fuse numbers they are ?
Old Jul 14, 2014 | 05:20 PM
You have no owners manual? If not click on the red in my sig and see all the manuals under the appropriate heading at the top of the list.
V V V
Old Jul 14, 2014 | 05:25 PM
Bay Cruise's Avatar
Yes I do but don't find the manual that easy to read, too many pages and the page numbering is atrocious. I find forums and other peoples expert instant help much much easier. Anyway I don't have acress to my mac to have a look at the moment as I am away and using my phone but thanks anyway.
Old Jul 15, 2014 | 12:25 AM
Red Runner's Avatar
Brake Lamp/Speed Control is the number 2 fuse 15 amp blue located at the left bottom of the interior fuse block on the drivers side end of your console. Access is by opening the door. There should be a card on the back of the door describing the fuses. Interesting that this fuse controls both your Brake Lamp & Speed Control.
Old Jul 15, 2014 | 02:45 AM
Bay Cruise's Avatar
Great Thanks, I had already checked those just in case and all were ok, so the switch it probably is. I don't seem to have the fuse description on the back of the fuse box cover so your info was helpful.
Regards speed control, it does make sense as the brake pedal switches off cruise so they would both work off the same fuse and switch if one goes faulty.
Old Jul 17, 2014 | 01:23 AM
Bay Cruise's Avatar
New switch fitted and all sorted now. Easy to fit takes 15 seconds BUT 15-20 minutes trying to get the two screws in the small black under dash cover. Had to be removed to get to switch on my car.
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rfourt
Sep 25, 2015 01:38 PM
cdcrone123
Sep 20, 2015 10:02 PM
lazorouss
Sep 11, 2015 09:16 AM
