Central Locking Control Module case?
Old May 1, 2015 | 12:41 PM
BEATv1's Avatar
Default Central Locking Control Module case?
So i just want confirmation this is the unit i'm going to inspect this weekend.
I drove my car to work, parked it and 8 hours later i return but the keyfob wont work. opened it manually and set off the alarm. I dont have an SKREEM alarm because i had the issue of it going off randomly and decided to take it off all-together. but i knew the alarm was going off because of the blinking lights. got in, tried to start but i guess for security reasons, it wont allow me to start. checked the battery of the key fob looked good. pressed and held the lock and unlock or the lock and alarm button? (i forgot the sequence) and it blinked twice. puzzled. i called a friend to bring my spare key. still nothing. popped the hood. unplugged the battery and waited a bit. replugged and still not working. (at this point, i still cant get my car to start because the alarm is still going off and my car thinking it's still locked) so i remembered when i had issues with the SKREEM alarm module, i took out fuse #9 which in turn, kept my car quiet but also kept my car unlocked. that did the trick, everything unlocked and i can now start and stop my car normally.
searched the forums and it seems that the Central Locking module may be the case.
any tips on how to replace or check for faulty lines?
thanks in advance!
Old May 1, 2015 | 04:14 PM
RED DOG's Avatar
Default Re: Central Locking Control Module case?
Start here . . .
https://www.crossfireforum.org/forum...tml#post471489
Read everything . . . Look at all the pictures . . . Then get into the rear wells of your trunk area and let us know what you find . . .
If water has ruined your electronics, let us know and we'll show you how to seal up the leaks!
Old May 1, 2015 | 11:05 PM
And to keep it out, you should nip a slot/hole in the two lower cavity drain hole plugs below the foam inserts under the jack kit (on both sides). You'll have to remove the lower trim on both sides and the rear lower trim below the hatch latch to be able to remove those foam inserts. I took a razor and sliced a very small (pie shapped) section out of the little 'nipple' sticking up into the well areas. The right side bay has the central locking module in there inside that foam 'box'. Carefully open that up and check closely for water damage as others have mentioned.
Old May 7, 2015 | 08:53 PM
BEATv1's Avatar
Okay a little update today since last weekend i was busy fixing a rust spot on my other car.
Thanks RED DOG for the link (helped out a lot with the pictures) and GraphiteGhost for the info!
so i opened her up and took out the interior panels and was greeted with the foam
more foam. it didnt look like there was water in there any time soon or it may have dried up by now
a little dirty
back of the module
How do these look? i dont see any water damage (again, my problem is that my doors wont unlock or lock from the keyfob)
The pins look good and intact
i'll wait for any more input before i put it back in.
if it still doesnt work, should i purchase another module?
Old May 7, 2015 | 10:08 PM
a little dirty
back of the module
With the part visible like that I would put in the plugs and see if it is working. If it is the problem is obviously elsewhere
Old May 8, 2015 | 10:06 AM
RED DOG's Avatar
I have never known one to be dry in there. I would have to think your Central Locking Module is fine. Connect it back up. When you lock / unlock the car using the button on the dash, does everything lock and unlock as it should?
Old May 11, 2015 | 02:32 PM
blackpepper's Avatar
I had the same issue ,I unpluged one of the connectors ,so my doors lock and unlock alarm doesn't go off interior light don't come on when you open or unlock the doors but this will do for now.I drill a few extra holes in the trunk also,to prevent water buildup next time around.
Old Jun 1, 2015 | 11:43 AM
BEATv1's Avatar
UPDATE: sorry for taking so long but it seems the issue has been resolved. I waited for everything to dry off, cleaned all connections, put the fuse #9 back in and viola! it locks again. i as well drilled some holes so any water that seeps in would drain out. thanks for all the input and now i can park my car without the fear of it being stolen lol
Old Jun 1, 2021 | 05:00 PM
Bay Cruise's Avatar
Hi I know this is an old post but I see you mention you disconnected a plug and your central locking still worked. Can you please advice what plug you disconnected. Thanks Bob
Mackel
Oct 16, 2015 09:03 AM
skeet370
29
Sep 18, 2015 05:53 AM
xjken
Sep 13, 2015 10:18 PM
55chevy
Sep 13, 2015 07:38 PM
crmnal
Sep 6, 2015 08:07 AM
