'04 crossfire with 26k problem.
Old May 16, 2019 | 08:51 AM
68rabird's Avatar
Default '04 crossfire with 26k problem.
My mother in law bough a crossfire and loves the car. The other day she drove to a store went in and came out and the car would just start and die. Twice this happened till no crank. Unhook battery and it will do the same sequence. Keyless entry works.... The dealler is trying to tell me that the pcm is corrupt and needs to be replaced along with the skreem and skim moduel and keeys to the tune of 5k. I'm having a hard time believing this is the necessary repair. Also limited mechanics with any knowledge of these cars up here in montana. Any help would be great
Old May 16, 2019 | 09:00 AM
Default Re: 04 crossfire with 26k problem.
It really does sound like a skreem issue, but 5K is a bit pricey.
From Rob at needswings the cost for a pre-programmed SKREEM is $700 ( 14% of the dealer price )
Old May 16, 2019 | 01:58 PM
See my sigline. I will let you off easily this one time.
And I would replace the car's battery and make DAMN SURE the battery posts and cables are clean and tight BEFORE changing the SKREEM.
I'd also do James' mod in this thread first as well:
https://www.crossfireforum.org/forum...le-engine.html
Old May 16, 2019 | 05:55 PM
68rabird's Avatar
They are saying that there is a PCM problem and they want to replace the PCM the skreem module and the skim module along with the keys
Old May 16, 2019 | 08:17 PM
They dealer really don't know, so if they replace everything, they have it covered. Listen to these guys here, they will set you straight and save you a lot of money.
Old May 16, 2019 | 11:07 PM
68rabird's Avatar
so my research is pointing to the skreem module is that what you guys think is wrong. I just want to make sure I am saving the most money I can. Also is a used module reprogramable to a different car. I have a complete parts car. Runs but was rear-ended
Old May 17, 2019 | 02:33 AM
Check with Josh Chase, he has stated that he can clone a failed module to a good one.
( he removes the eeprom chip I think )
He charges around $325
Call 7607931372
themercedesswapshop@hotmail.com
Old May 17, 2019 | 09:52 AM
You could replace the whole system from the parts car l think. What exactly is needed to be replaced is on this forum.
Old May 23, 2019 | 12:22 PM
68rabird's Avatar
Default Re: '04 crossfire with 26k problem.
The dealler is telling me that there is a tsb or bulletin thatthe PCM could have a malfunction and that's why they need to replace the whole system. Montana is not the place to brake down with one of these cars. No one knows how to work on em. I am thinking it's the skreem module. Is there anyone I could talk to over the phone and see if they can help. ??? Anyone input is greatly appreciated
Old May 23, 2019 | 12:47 PM
Your SKREEM appears to be the problem from your description, you can just replace it with a new part from NeedsWings or replace it, the keys and locks or the chip in the keys and ECM from the parts car. The details of it are on here somewhere. Your dealer is trying to milk your wallet.
The simplest way is to replace the SKREEM module, saves time on all the other work, it is not the cheapest though. Forget the tsb/bulletin and the PCM tale.
Dustin_Campbell
Feb 4, 2023 04:30 PM
Astrofriend
Dec 4, 2019 03:02 PM
Jhn-Dvd
May 27, 2019 09:34 AM
Candyman
Apr 26, 2019 09:24 PM
Dustin_Campbell
Apr 8, 2019 09:46 PM
