Cigarette lighter power issues
Old Jan 21, 2021 | 01:01 AM
Brian P's Avatar
Default Cigarette lighter power issues
Hi all, I noticed today while checking my tire pressure that the machine didn’t seem to make easy contact with the lighter. I confirmed that it worked in another car. I then checked if the plug-in for the USB converter to charge my phone worked and had the same, intermittent power issue. We don’t smoke & it doesn’t appear that the previous owner did (the socket is clean). Any suggestions to improve the connection? I didn’t want to just start pulling on the inside without asking. Thanks!
Old Jan 21, 2021 | 06:44 AM
Default Re: Cigarette lighter power issues
Just want to make sure you know that the lighter socket only works with the ignition on ......
Old Jan 21, 2021 | 10:58 AM
I turn the socket back and forth a few times to get a better contact, these parts are often chromed and chrome is not a good conductor of electricity, neither is rust if the chrome is worn off.
Old Jan 21, 2021 | 04:55 PM
Brian P's Avatar
Thanks, yes, the engine was running... 😉
I’ll try twisting it around some and see if that fixes it.
Old Jan 21, 2021 | 11:35 PM
That is, unless you do my "Always hot cigarette lighter and glove box light mod".
I had to do it, as I charge my phone and GoPro batteries while stopped for lunch.
Old Jan 22, 2021 | 12:18 AM
Brian P's Avatar
Ooh, do you have a link to that one?
Old Jan 23, 2021 | 06:40 AM
I'm on a business trip and it's here somewhere - I'll dig it up when I get home.
Old Jan 23, 2021 | 10:23 AM
steve1189's Avatar
Try this
Glove box light and cigar lighter powered all the time.pdf
Sorry, link isn't working for me but it is there on the forum.
Old Jan 23, 2021 | 04:11 PM
This works. CLICK
Old Jan 23, 2021 | 08:38 PM
Brian P's Avatar
That’s great, I’m looking into it. 🙂😎
Old Jan 28, 2021 | 04:00 PM
g wheels's Avatar
The "cigar" lighter in mine wasn't working when bought. I pulled it out and the bottom rivet for the hot wire was loose. I had to drill it out and replace it with a small bolt and nut.
Old Jan 29, 2021 | 08:45 PM
Brian P's Avatar
Any things that make doing that easier? How do I remove it, etc.,? I appreciate any help. 🙂
Old Jan 30, 2021 | 07:38 AM
g wheels's Avatar
I think I initially found a thread or two on the topic so a search could help you..
I ended up getting to the socket from under the passenger side of the console. If memory serves me, I was able to get my large hand up to the socket. This stresses the plastic of the center console quite a bit and was risky. Before getting to the socket you need to pop the side panel outward where there's a fragile retaining arm that protrudes from the side. Once this was dislodged I was able to get to the socket from the bottom and push it up enough to use a plastic trim tool from the top to lift the socket upward and out. Some lubricant helped at this point. Then, there's a little trick disconnecting the connector because it goes on sideways. I highly recommend searching the topic thoroughly because the plastic is getting brittle. There may be some help on youtube as well as here.
Old Jan 30, 2021 | 01:07 PM
Click this link - see post 7 and after:
Click here.
PLEASE READ:
DO NOT use our search feature on this forum, use Google and search "Chrysler Crossfire Cigar Lighter Removal", it's not hard to find this stuff but you MUST use GOOGLE.
ashleymark
U.K.
Apr 5, 2020 09:31 AM
onehundred80
Sep 11, 2017 07:34 AM
yorktown4
Sep 5, 2014 07:32 PM
jamespsnl
Mar 21, 2006 03:13 AM
TivoBuddy
Jun 26, 2004 08:21 AM
