Limp mode / misfire help
Old May 29, 2021 | 08:57 PM
aaronmb52's Avatar
Exclamation Limp mode / misfire help
Hello,
I've Had my SRT6 for the past 4 months or so and started getting this problem recently. Every once in a while the check engine light would come on, and sometimes in those instances, the car would feel like it goes into limp mode. The car doesn't go above 1000 RPM, it shakes, almost like there is a misfire. Usually turning off the car waiting a sec and turning it back on fixes the problem and I'm on my way.
UPDATE: The only code read so far is a P0410. The check engine light went away however the same problem still persists.
Old May 30, 2021 | 12:53 AM
zip439's Avatar
Default Re: Limp mode / misfire help
You can use the search box in the upper right corner of this forum to search for limp mode, hesitates and shacking, misfire etc and find many different possibilities. When the check engine light goes on it will set a code; read the code and start your investigation based on the code or codes. Vacuum leaks are often a cause of your symptoms, or the throttle body.
GET THE NUMBERED CODE; not just some wordy explanation as to what the code means. We need the exact numbered code or codes.
Old May 30, 2021 | 01:17 PM
UrbanE's Avatar
Originally Posted by aaronmb52
Hello,
I've Had my SRT6 for the past 4 months or so and started getting this problem recently. Every once in a while the check engine light would come on, and sometimes in those instances, the car would feel like it goes into limp mode. The car doesn't go above 1000 RPM, it shakes, almost like there is a misfire. Usually turning off the car waiting a sec and turning it back on fixes the problem and I'm on my way. haven't been able to read the OBD yet, but does anyone have any idea what's going on and how to fix it?
Thanks
It could be a plugged Catalytic converter.
I had that happen on the top cat, passenger side. The innards crumbled and plugged the exhaust. Limp mode, shaking
Old May 30, 2021 | 01:37 PM
You are really ignoring the obvious here, a check engine light means a code is set. That means the ECU sees something significant.
To post anywhere asking what is going on without telling us what the code or codes are, is wasting your time and ours. All you are getting is guesses.
Get the codes read and come back and give them to us - things SHOULD move along a lot faster that way.
More on the Codes;
It is entirely possible, you will have a P0410 and nothing else - the P0410 means nothing here and for the purposes of this discussion, can be ignored.
This brings us to the next item: If you have no meaningful code, (and the CEL is for an 0410 or similar), that means the issue with the car is not setting any code - even THAT tells us something. It tells us that the failure is not of a nature the ECU can discern, which sends us to look at items outside the ECU's direct vision.
Reading the code(s) will get us started.
Old May 30, 2021 | 01:44 PM
Also, there are some CHEAP options for getting codes read. Your local parts store is one, but there are kinda cool 'dongles' you can buy online that transmit via bluetooth to your phone - not the best, but they do read simple codes, which right now, is all you need.
Is $17 cheap enough?
https://www.walmart.com/ip/Ancel-AS1...ll&athena=true
Old Jun 1, 2021 | 08:45 PM
aaronmb52's Avatar
Hey There, more information finally.
The codes read P0410. The check engine light is not on now, however.
Old Jun 2, 2021 | 07:29 AM
zip439's Avatar
Click on this link. It will give you all the info you need as to what to inspect and how to repair: clearing clearing P0410
Old Jun 2, 2021 | 09:42 AM
NeedsWings's Avatar
is your coolant reservoir low? email me pictures, rob@needswings.com
rancher1983
Jul 2, 2015 08:09 PM
SRT6-Man
May 25, 2015 04:24 PM
Tie Fighter +Fire
Mar 29, 2013 08:34 PM
SoftballJunnkie
Jul 1, 2011 08:42 PM
bobo54545
Nov 17, 2007 04:52 PM
