Windshield washer fluid tank is leaky...?
Old Mar 4, 2025 | 11:10 AM
Myopic's Avatar
Question Windshield washer fluid tank is leaky...?
When I added windshield washer fluid to the tank in my car, at some point it started pouring onto the ground from somewhere in the wheel arch.
So I have a question, does this mean that the tank is leaky, or maybe the tank has something like a hole/drain above the 4 liter capacity ?
Old Mar 4, 2025 | 11:34 AM
Default Re: Windshield washer fluid tank is leaky...?
You will have to remove the fender liner and check the tank, filler tube and hoses.
https://www.crossfireforum.org/forum...ttle-pics.html
Old Mar 4, 2025 | 11:37 AM
Myopic's Avatar
@ZERACER Thank you. From your answer I conclude that in this car the tank does not have something like an additional overflow hole above 4 liters ?
Old Mar 4, 2025 | 11:41 AM
I would assume it does. If the fluid doesn't leak out a lot, I wouldn't mess with it.
Old Mar 4, 2025 | 12:10 PM
Washer fluid will spill out the side before it will fill to the top
It can hold about 1 gallon and if you try to keep filling it at some point it will begin to spill in on the ground as you experienced
Most likely it's not a leak !!
Old Mar 4, 2025 | 12:19 PM
Myopic's Avatar
@Valk Ah... Thank you.
Yes, the fluid does not flow out through the upper filler opening, but somewhere to the side.
Old Mar 4, 2025 | 09:04 PM
The first time I filled mine this happened to me.
I thought that I had a crack in the reservoir! LOL
But as Valk said, it has an overflow hole like a sink does. It comes out of the bottom of the fender.
Old Mar 4, 2025 | 09:31 PM
Wadsworth's Avatar
Hopefully it just overflowed, but the tanks have failed in the past.
Old Mar 4, 2025 | 11:28 PM
Myopic's Avatar
@M60A3Driver Thanks for confirming Valk's diagnosis.
@Wadsworth I'll keep an eye on the tank next time I fill it up, but it's most likely as Valk and John wrote.
Old Mar 5, 2025 | 07:46 PM
I always suspected this. Fluid always leaks out whenever I filled it up. Most likely because I fill it up before the low level alarm comes on. I'm guessing that when the low level alarm comes on the IP, you can add 1 liter of fluid w/o spilling any. Duh!
Old Mar 11, 2025 | 01:53 PM
Goldwing's Avatar
If after the filling (and overflow) experience you do not see any fluid on the ground, then the issue was overflow only.
Old Apr 17, 2025 | 12:00 AM
tervic's Avatar
I'm a little late with my two cents but I thought I had this problem with my car when I first got it. So I ordered a new washer tank and went about installing said tank. It lives in the fender well behind your right front tire. The wheel well liner has to come out, I removed the right front wheel for more room. What I found is that there is a separate fill tube (what you see in the engine bay) that plugs into the actual reservoir. When you add enough fluid to reach that junction, excess fluid runs out at that joint as it is not sealed. My reservoir was fine, I just needed to learn not to try to fill all the way to the top of the fill tube.
dodgemahal
Jan 29, 2018 12:45 PM
VIPER0076
Aug 5, 2011 09:58 AM
zy123456
Jul 17, 2009 11:41 AM
Joevano
Jul 30, 2005 10:44 AM
bobawhoie
Apr 3, 2004 06:24 AM
