Top not working
Old Sep 21, 2025 | 05:13 PM
Claude88394's Avatar
Default Top not working
Every time I try to raise or lower my roof the fuse blows. Has anyone had this problem before?
Old Sep 21, 2025 | 06:40 PM
Default re: Top not working
That is an ambiguous question. Do not use the term "roof fuse", give us the fuse number.
There are three fuses that can blow when you try to move the top:
Roof Motor Fuse (fuse 6, 40 amp)
Power Top Control Module Fuse (fuse 5, 25 amp)
BCM FUse (fuse 19, 40 amp)
Fuse numbers are for 2007 Limited cars because that's the service manual I have. Your fuse location numbers may vary, so tell us what year/trim level your car is as well.
Old Sep 22, 2025 | 04:06 AM
Default Re: Top not worqing
it is the roof motor fuse (fuse6, 40 amp)
Old Sep 22, 2025 | 10:07 AM
Default Re: Top not working
Where are you located? How long have you had the car and what year, and model is it? Has the top ever worked for you? It is imposable to diagnose without more info.
Old Sep 22, 2025 | 12:46 PM
i am in Québec, canada. I have the car for 1.5 year. Yes it was working very well. I make rebuilt all the hydraulic cylinders and it was move perfectly but now every time i try to operate it, the roof top fuse (fuse 6, 40 amps) blow up
Old Sep 22, 2025 | 03:12 PM
I defer to the experts, but it sounds like possibly a failing pump motor?
Old Sep 22, 2025 | 11:55 PM
The 40 amp fuse powers ONLY the motor thru the two rotation relays. A bad motor would be my assessment.
The power top hydraulic assembly is generic, I'd grab one from a parts car and give it a try.
crossfiremaniac
Jul 14, 2022 08:19 PM
Rains05Crossfire
Jul 13, 2021 01:16 PM
X-F
19
Aug 2, 2016 07:01 PM
toia6407
Aug 3, 2012 12:58 PM
valiant106737
Apr 26, 2011 08:31 AM
