How to program your own key. SAVE $$$
Old Oct 16, 2018 | 05:40 PM
  #221 (permalink)
cg80's Avatar
Thumbs up Re: How to program your own key. SAVE $$$
Originally Posted by Shawnkey
This is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Shawn
Thanks, Shawnkey...worked perfectly.....saved big bucks!!!Carl
Old Oct 21, 2018 | 08:22 AM
  #222 (permalink)
RON-L-RAC's Avatar
Talking Re: How to program your own key. SAVE $$$
Shawn
God Bless. Shawn, thank you for not being selfish, but instead sharing your info with other Crossfire owners. Again, that was a very nice thing to do for others. Way to MAN-UP!
Old Oct 21, 2018 | 08:55 AM
  #223 (permalink)
RON-L-RAC's Avatar
Default Re: How to program your own key. SAVE $$$
God Bless. Thank you for being so selfless and sharing your info with other Crossfire owners . Way to MAN-UP and be a good human being. Again, thank you!
Old Oct 21, 2018 | 09:59 AM
  #224 (permalink)
These instructions are in the owners manuals of every car, and have therefore been available since 2003.
No man up required from anybody just the ability to read your manual. There is a lot to be learned in these manuals, so get one from this site as a PDF and get reading.
Old Dec 11, 2018 | 09:47 AM
  #225 (permalink)
Padgett's Avatar
OK so to be complete you need four things in a complete fob:
1) Case. $6 on ebay with uncut key
2) Key: included in case, most locksmiths can cut.
3) Circuit Board. Does remoter lock/unlock/panic requires battery. Can program on car.Range up to about 30 ft.
4) RFID chip. Used by SKREEM to permit car to start. Special program required. Range: an inch or two.
So the only real issue is the RFID chip that is present in the fob and the valet key. To replace the SKREEM, you must program the SKREEM to both the VIN and the RFID keys. if the SKREEM is working, can you just clone the RFID chip ? YWTK.
I have some RFID chips coming in. What tool (preferably PC based) is required to read from one RFID chip and copy to another ?
Old Dec 11, 2018 | 08:11 PM
  #226 (permalink)
Mrmiata's Avatar
"An inch or two".. mine slipped back in the new case about 1/4 inch on my first transplant.. 2 no starts and I was back in the house looking to see what was up. And good luck on the "reader - programmer".. I spent an evening with Google and Mercedes based groups looking for a path.
Old Dec 12, 2018 | 12:03 AM
  #227 (permalink)
I have never seen a valet key or read about one in any manual. What gives?
Old Jan 2, 2019 | 07:55 PM
  #228 (permalink)
Tripster's Avatar
I purchased a key fob on Ebay had the key cut using my original key, this system to program the key did not work for me, anyone have any ideas. Thank you
Old Jan 2, 2019 | 08:16 PM
  #229 (permalink)
Was it a new fob with no electronics in it, a used fob or ?
We need a description of what it was you purchased.
Old Jan 2, 2019 | 10:28 PM
  #230 (permalink)
Tripster's Avatar
It was a new key fob, with a blank key that I had cut. I followed the steps and it did not work. Just to clear thins up for me when you press the unlock button do you do it with the key in the ignition ? Then turn the key to the run position ?
Old Jan 2, 2019 | 10:38 PM
  #231 (permalink)
Tripster's Avatar
It had the circut board and chip inside it.
Old Jan 3, 2019 | 12:00 AM
  #232 (permalink)
The chip has to be the one from your old key or an identically programmed one.
The chip from another car will not work in your car, for security reasons.
Old Feb 9, 2019 | 11:58 AM
  #233 (permalink)
He,sreal's Avatar
Help... I lost my key, call dealer and they said 800.00 to replace. Anything else I can do anybody
Old Feb 9, 2019 | 12:47 PM
  #234 (permalink)
One may be a little cheaper from Needswings? You can not just buy a key on E-bay. They are programmed for your car only.
Old Feb 9, 2019 | 01:38 PM
  #235 (permalink)
Moore2575's Avatar
Not totally true
Old Feb 9, 2019 | 03:54 PM
  #236 (permalink)
Originally Posted by Moore2575
Not totally true
What is not true, please explain to what you are referring to.
If you do not quote the post you are referring to only you know what could be in errror.
Many people do this and others cannot understand the reply.
Old Feb 9, 2019 | 06:00 PM
  #237 (permalink)
There was a time you could get lucky and buy a nice ‘winter beater’ car for that money, times change.☹️
Old Feb 9, 2019 | 06:17 PM
  #238 (permalink)
Moore2575's Avatar
If you buy a used keu/fob get the vin the key/fob came from call chrysler dealer give them both vins theu will beable to tell you if it is compatible for your car and can be reprogrammed to your car. If so buy a new blank key and they can lazer cut the new key for your car.
Old Feb 9, 2019 | 08:10 PM
  #239 (permalink)
Yes, they can laser cut the key - and that will unlock and lock the door, you can even program the lock/unlock buttons to your car.
But you cannot program the RFID chip to your SKREEM, therefore, the car will not start and run.
Old Feb 9, 2019 | 08:52 PM
  #240 (permalink)
Moore2575's Avatar
And that my friend is why i said not "totally" true
