Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Old Mar 28, 2013 | 10:53 PM
  #541 (permalink)
Mrmiata's Avatar
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
And replacing it instead of "fixing it" is what this sounds like.. so you can play the same game a 3rd time unless you sell it?
Old Mar 28, 2013 | 10:55 PM
  #542 (permalink)
Easley15's Avatar
Just did this fix and it went great!! except 2 springs fell out near the steering wheel adjustment and im not sure where they go
Old Mar 28, 2013 | 10:56 PM
  #543 (permalink)
Originally Posted by genovese4321
If I new what a headache I have with this sticky ignition key problem I will never buy this car is the second time I have to change the cylinder ignition lock on my 2004 Crossfire . I have 60000 miles on my car ... My car is in a shop now i had to go to the dealer and order the part I have to wait 3-5 days ( is a special order by your VIN NR. ) and was $ 310.00 included tax then I have to take it to the shop where my car ............ and so on .
If you searched the forum you would find how to fix this problem for absolutely no cost and be assured that you would never have the problem again. It does not get much better than that these days.
The part you have changed is the problem, modify it for no cost and be happy.
Go here for the cheap and permanent solution.
No need to buy another one.
Old Mar 28, 2013 | 11:17 PM
  #544 (permalink)
genovese4321's Avatar
Every body that had this problem with the Ignition PLEASE do this ... go to HTTP://WWW.SAFERCAR.GOV and make a complain . This needs to be a recall. If they have so many complains this will be fix t by Chrysler for free .
Old Mar 28, 2013 | 11:19 PM
  #545 (permalink)
They have three complains o ready . PLEASE WE NEED YOU ... to help with this problem .
Old Mar 28, 2013 | 11:25 PM
  #546 (permalink)
Home | Safercar -- National Highway Traffic Safety Administration (NHTSA) Manufacturer : CHRYSLER GROUP LLC Component : ELECTRICAL SYSTEM : IGNITION
This is what you need to file the Complaint . Plus your VIN nr etc .
Old Apr 3, 2013 | 12:01 AM
  #547 (permalink)
sillysanford's Avatar
Originally Posted by reliableron
don't think you will find any relationship between the battery and thesticky ignition switch - no one has ever mentioned anything and i had no battery issues. Battery may help it start better - sorry but i think your still gonna have to fix it!
hi.....i ben driving my crossfire for two months with a scewed up key swith....i turn my off till the radio goes out.....leave the key in it....when i come back to the car i turn the switch all the way to left then turn to start as normal...with out turning or touching the steering wheel.....works fine......don sanborn 231 557 9481
Old Apr 3, 2013 | 07:46 AM
  #548 (permalink)
Too late for this, three complaints so far? They'll put it down to wear.
Would you want the dealer to touch your car anyway and put in another faulty part?
Old Apr 3, 2013 | 08:04 AM
  #549 (permalink)
Yea, they'll put in another of their deffectively engineered assemblies. No thanks - I fixed mine in 90 minutes for free and I'm mechanically incompetent!
Old Apr 3, 2013 | 08:06 AM
  #550 (permalink)
Your's is not "frozen" yet, the fix is easy. Go follow the procedure and you won't need to be so careful, or print the fix and pay some local garage about $150 to fix it for you!
And stop being silly. Sanford.
Or come to the Dragon this weekend and we'll fix it for you - if it's raining and we can't ZOOM ZOOM!
Old Apr 3, 2013 | 09:35 AM
  #551 (permalink)
Mrmiata's Avatar
Thought that just separated the men from the boys?
Consider it drift practice! That's big in CA isn't it?
Old Apr 14, 2013 | 11:26 AM
  #552 (permalink)
bikerlifeetc@hotmail.com's Avatar
just a couple of notes about the fix posted here, when i did this project, it was easier for me to remove the 10mm bolt in the clamp with a wrench as opposed to a socket. Also, make sure you re-install your transponder ring BEFORE you try to start the car, or it will definately send you into a panic!! if you try to start th car without this ring in place, it may start the first time, but then die, or not start at all! Also, if you are repairing the key switch you already have instead of buying a new one, make sure you remove the tumblers, or your locking pin will NOT push in t release your assembly. Just a couple of things i wanted to share with the community. Happy motoring, and enjoy not having to wory about your key not turning!!!
Old Apr 14, 2013 | 12:39 PM
  #553 (permalink)
Moham_us's Avatar
Hi
i would like to thank you for the great money saving and great help, i did everything and i had to drill the pin and i managed to get the ignition out but the black cylinder still not coming because the key is not moving at all . after all day and i purchased new tools and i fail to get it work , any one know this issue or how to get the black cylinder out (everything is back to the place and the wheel is unlocked but the key is not turning)
Old Apr 21, 2013 | 12:38 PM
  #554 (permalink)
girlcrushcar's Avatar
Do you follow these same directions when the steering wheel is into place? My ignition switch was just being sticky in the winter but when it was amazingly hot outside it decided not to turn at all. As I was turning the steering wheel slightly back and forth and trying to turn the key simultaneously it totally locked up the steering wheel. Thank you in advance for any help.
Old Apr 21, 2013 | 02:23 PM
  #555 (permalink)
Moham_us's Avatar
Hi girlcrushcar
well , it was a mistake that i followed the instruction in the forum to the letter , everything is great in the instructions but no one told my that the ignition is two parts (the black cylinder key and the ignition where the black cylinder goes into)
my wheel was luck and the key was not turning (and here is the missing part) i just needed the black cylinder key (the document said if the key is not turning you have to drill the pin ) ) after drilling and taking everything out i notice that the problem was on the black cylinder means that i should order a new key 270$ , but by drilling i damaged the ignition and by the way the ignition in the dealer cost 520$ but in Mercedes 180$
the best is to check the Cylinder black key part and then the ignition if you need any help let me know i did the fix my self
and thanks for the replay
Old Apr 21, 2013 | 02:40 PM
  #556 (permalink)
Hi Moham_us,
Thanks for the heads up. My boyfriend is doing the repair and just left to pick up his Dremel tool from his friend. So now I want to know what is the best step by step way to do this where I do not have to take my car to the dealership and pay excessive amounts of money. He was trying to do this where we can use the same ignition switch and everything. I am confused and trying to gather all the information on this repair but it makes me very apprehensive to know that my boyfriend might have to use a drill on my baby. All of your knowledge is helpful and appreciated.
Old Apr 21, 2013 | 03:01 PM
  #557 (permalink)
aschrager's Avatar
I spray some WD 40 in the ignition switch every few month since I first heard about this problem back in late 04. I never had a problem with a sticky switch..
Old Apr 21, 2013 | 03:08 PM
  #558 (permalink)
Moham_us's Avatar
-girlcrushcar
can you stop the drilling and call me 215-847-6769,
Old Apr 21, 2013 | 03:41 PM
  #559 (permalink)
Hello aschrager, Thank you for the reply and we are going to start doing that after we finally get it to unlock.
Hello Moham_us, Thank you so much and quick replies and we will be calling you in about 15 minutes.
Old Apr 21, 2013 | 04:45 PM
  #560 (permalink)
Moham_us's Avatar
you r welcome anytime just give me a call , please notice that you may have some issues with the battery if the car didn't run for a week this may cause the alarm system to be off . after fixing the ignition if the car start then everything is done the alarm and other electric issues are easy .
this is good link (manual)
http://www.majormotorshotrods.com/_d...ice_Manual.pdf
