2005 Won’t Start
2005 Won’t Start
2005 is the year I tried all the post pertaining to the crossfire no start
I turn the key and there is nothing happens the electric stuff works fine the top goes up and down,and the key locks the car
and the panic button works too.
I solder the RCM where the relays are at. But no luck, checked all fuses.
Could it be a bad starter.
My baby has 170,000 miles and still going strong.
Any ideas will be appreciated.
Note:
The Chrysler dealership in Fort Myers has 2 mechanics the been to Germany for training on these cars.
Re: 2005 Won’t Start
Note:
on
Turn key to "ON", wait 30 seconds.
Does the engine cooling fan slowly run up to warp speed? If so, the engine control relay on the RCM is not closing, or a solder land between the relay and the connector on the edge of the board is your problem.
If the fan DOES NOT warp to high speed, this is, possibly, going to get complicated.
The only fan running is for the cooling RCM box where the relays are, through a small tube at bottom of box
Note:
And lo and behold, I found it !
And it's located inside the box by the battery :
Many many many thanks
Ok I test for current at the pulse module at 1F turn the key and lights up release the key the light turns off in a second or two.
Went to the C106 connector #4 and #6 and found when the key is turn to start there is current.
I’m thinking I have a bad starter.
Tell me what you think or I’m missing something else.
You have been great you really know that car. Thanks again
In my case, the car (SRT) started just fine like it always had and I drove the car to a car show and parked it. It sat for about 5 hours. I came out to leave and got the "all lights work but no-crank" symptom. I had done the RCM resolder years ago but thought that I didn't do a good job so I pulled it out and soldered the 3 contacts again. Still no joy. Sent the RCM to DJ and asked for a complete rebuild thinking that some relays had gone bad. He said it worked fine when he got it, but did what I asked and it worked fine (again) in his car. Still didn't work in my car. Put a charger on the battery to make sure it was fully charged and still got nothing. After searching on here I saw that the pulse module might be suspect and then I found this thread.
Would like to know what the final outcome of your problem ended up being.
Thanks!!
Thanks!!
Solution achieved ... I think. As the months wore on, the issues became more like the SKREEM problems as I could get the car to crank a couple of times if I unhooked the battery cable and reconnected it. But, sometimes by doing this, it would start, so I wasn't convinced that it was the SKREEM. Reading the FB posts from people that had used SOS Diagnostics and Precision ECU, I finally bit the bullet and went with the immobilizer delete that Precision ECU offered. It was a couple of hundred cheaper than SOS and I was OK with not having the SKREEM in there. Got the parts back today, installed the ECU (left the SKREEM on the bench), followed the instructions to let the car recognize the now reprogrammed ECU and then tried to start the car ... AND IT FIRED RIGHT UP!! Shut it off and tried again and it started right back up. So, for now, I hope this issue is now behind me and I will never have to worry about that stupid SKREEM again. Curiously, one of the problems that I noticed as all this was going on was when the car would crank, it would only crank if I held the key in the start position. Now, I can let the key fall back to the RUN position and the car will still continue to crank until it starts. Not a big deal, but I found that interesting that the "auto crank" (or whatever you call it) was starting to not work as the symptoms worsened.
Side note: without the SKREEM, your FOB will no longer lock or unlock your doors - no biggie to me - at least for now it's not.
RL
RL
lovecross (08-13-2020)
