Best Size Spring Pads!!!
Old Mar 11, 2010 | 01:54 PM
JoshShowAh's Avatar
Default Best Size Spring Pads!!!
Hey all,
I just bought some Eibach/Konis, and was wondering what the best combo of spring pads are for the setup. Let me know what worked out best for you; and yes I want photos...
Old Mar 11, 2010 | 01:58 PM
Airscape's Avatar
Default Re: Best Size Spring Pads!!!
HERE 5dot front 1dot back.
NA same size comfirm here
Old Mar 11, 2010 | 02:25 PM
velociabstract's Avatar
With the dot 5 in the front and dot 1 in the rear, Koni's and Eibach's the car will be approximately 1/2 inch lower in the front and 1 1/2 inches in the rear. If you lower more in the front you could have some rubbing. I have this setup but with tires that are 4mm taller and I have some minor rubbing. With stock tire size in the front it should be perfect.
Les
Old Mar 11, 2010 | 05:14 PM
mrphotoman's Avatar
has anyone tried smaller spring pads with stock springs to see if it lowers the car any? maybe 1/4" lol?
Old Mar 11, 2010 | 05:23 PM
These are the sizes available.
Front:
A 210 321 01 84 (5mm)
A 210 321 02 84 (9mm)
A 210 321 03 84 (13mm)
A 210 321 04 84 (17mm)
A 210 321 05 84 (21mm)
Rear:
A 210 325 01 84 (5mm)
A 210 325 02 84 (9mm)
A 210 325 03 84 (13mm)
A 210 325 04 84 (17mm)
Give me a few minutes and I'll let you know the stock SRT-6 sizes on my car.
But yes, you can lower the car a bit just changing out the spring pads.
Les
Just checked. Stock on my car was 2 dot in the front and 3 dot in the rear. So you can lower the car 4 mm in the front by changing to the 1 dot and 8 mm in the rear by changing to the 1 dot.
Old Aug 15, 2010 | 06:16 PM
Germany's Avatar
Hi. I know ths is an old thread, but its perfect for what I want to ask.
I am just getting the Eibachs installed, without Koni's. I guess the "perfect setup" will still be the same with 5dot in the front 1dot for the rear?!?!
So the part numbers I need are:
Front: A 210 321 05 84 (21mm)
Rear: A 210 325 04 84 (17mm)
I guess I can get these pads at a normal Chrysler or MB Dealership? Does anyone know how much they cost?
Thanks for the help and the info so far.
Old Aug 15, 2010 | 06:31 PM
32krazy!'s Avatar
the rears you have are wrong thats a 4 dot you would want these A 210 325 01 84 (5mm) which are 1 dot look at the 01. that corresponds with the dots on the pads
fwiw i have 4 dots on the front and 2 dots on the rear. oem on both 13dog's srt6 and my 32 were 2 dots front and rear.
mrphotoman you are looking at 4mm per dot drop so fronts and rear only drop 4 mm from oem
you also cant use the front pads on the rear and viceversa
Old Aug 15, 2010 | 06:35 PM
Germany's Avatar
Thanks for the info.
Yeah, I have an NA crossfire, I just that the post was in the SRT 6 section.
Does that make a difference if its an SRT or the NA? Just wondering becuase isent the SRT a bit heavier?
Old Aug 15, 2010 | 07:32 PM
32krazy!'s Avatar
we actually did the springs on jhm2k's limited. 2 dots on his as well but different springs than the srt-6. we installed cut srt-6 springs on his limited and completely changed the way the car handles.
Old Aug 15, 2010 | 08:16 PM
The SRT springs are much stiffer than the N/A springs but I believe the ride heights are the same. The Eibachs are somewhere in the middle but the ride height is quite a bit lower. The 5 dot on the front and 1 dot on the rear are to prevent rubbing. If you use the stock spring pads the front tires will rub the inside of the fender well. You can use a taller spring pad on the rear, the problem is the front. Most people that lower the car want it as low as possible without rubbing, therefore the 5 dot on the front and 1 dot on the rear.
Interestingly, the Eibach's are longer than the stock springs when you put them side by side.
Les
Old Aug 15, 2010 | 08:59 PM
MikeR's Avatar
I have the 3 dot in the front and 1 dot in the rear on the Aero......but I am using 10mm spacers in front to clear the C32 breaks...otherwise I would be eating my tires with the control arm bolt... (12mm spacers in back FYI)
Old Aug 15, 2010 | 09:23 PM
Sometimes I think the 05's and 06's are not the same. I have 10 mm spacers on the front with dot 5 pads with stock size tires, almost no rubbing. With 235's I had too much rubbing. On the rear I can't fit even a 5 mm spacer without hitting the fender lip. I had minor rubbing with a dot 1 and 265/35/19's and a dot 1 pad.
Les
Old Aug 15, 2010 | 09:50 PM
Germany's Avatar
Thanks for all the input. I will run to the dealership tomorrow and get the 5 and 1 pads, hopefully Chrysler will have it in stock otherwise I'll run to MB.
Hope it all works out with lowering
Old Aug 15, 2010 | 10:40 PM
32krazy!'s Avatar
chances are neither dealer will have the pads in stock . order online or at the dealer and wait!
RojoGTO
Feb 6, 2016 11:14 AM
Law3dog
Aug 20, 2015 10:16 PM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
