HID Install Lows and Fogs with Pictures
Old Oct 19, 2008 | 09:48 AM
maxcichon's Avatar
Lightbulb HID Install Lows and Fogs with Pictures
I'll try to make this short, but detailed.
pdf file now attached here: HID Installation Instructions.pdf
Tools I used:
45 deg Needle Nosed Pliers
7/8" Socket (for cutting Caps)
10mm Deep Wall socket w/ratchet
Wire Stripper/Crimper
Materials I used:
4 Male spade connectors
2 1/4" Stainless washers
2 M6 Stainless Locknuts
Preparation
  1. Every bulb assembly I've seen comes with a grommet integrated. There are 2 types of wires involved: High Voltage (to the bulb) and Low Voltage (to the OEM connector). They all seem to have 2 extra unfinished holes for the 12VDC wires to reach the connector inside the headlight housing. Use a 1/16" drill bit to complete these holes.
  2. The Radiator overflow tank must be moved to gain access to the passenger side housing. It is very easy to move. Remove the 2 M6 nuts with a 10mm deep wall socket. Remove the Washer Fluid Level connector on the bottom. The release tab is on the side of the connector. It can be stiff, just don't twist! Pull sraight back. The tank itself is held in place with a barb on the bottom which engages a rubber grommet. Once the nuts are removed, just put your hands underneath and pull/twist/rock the thing until the barb is free. It can seem very hard to do, but it DOES come off. Unclip the hose and move the tank to the center of the engine bay.Remove the caps from the back of the headlight housings you plan to install your HID's in. Clean them using WD40 or equivalent. Measure the INNER diameter: the size at the inside of the slot (NOT the outside of the whole grommet) of the pre-installed grommets on your new bulbs. (See Pictures). Mine were exactly 1". (See Pictures). Using an Exacto knife and an appropriate sized socket or other round object, cut a circular hole in the CENTER of the cap. (See Pictures). This will provide a watertight and attractive seal for the wires.
Removal of old bulbs
  1. First, and some find difficult, is pulling the connector from the back of the bulbs. If you look closely, you will see an "H" shaped area. I used a medium sized 45 deg bent-nosed needle pliers to grab the center of this "H" and pulled straight back with a little rocking action. DO NOT TWIST! DO NOT PULL ON THE WIRES! It comes off, but can fight a little.
  2. Next, undoing the bulb retaining clips is for some a bit baffling. On the low beams, the clip clamps at the bottom and swings UP. Press the very bottom of the clip and push to the side to unhook it from the retainer. Remove the bulb. Repeat for other side.
Installation of new bulbs
  1. To take advantage of the nice watertight grommets provided, one must thread the 2 High Voltage wires AND the grommet through the bulb retaining clip. This takes a little patience, but it works. for the low beam bulbs, you will be threading them UP through the clip. First, remove the protective plastic jar from the bulb. It is fragile, so don't bang it around. Slide the grommet all the way to the bulb end of the wires. Then, one at a time, push the connectors through the clip being careful not to unhinge the clip itself. When both wires are through, slide the grommet about mid-way up the wires. Push the grommet through just like a coin in a slot machine. It fits easily. If you have touched the bulb, even with the back of your hand, clean it gently with a cotton ball and alcohol.
  2. Seating the bulbs can be a challenge. On the low beams, the "tab" points straight DOWN. It really doesn't "fall into place" like some say, it just sits a bit more flush. My tab was aligned with the wires so when the blue wire was up, it seated properly. Engage the retainer clip.
  3. Now we get to use the 2nd pair of little holes in the grommet. There is no way to push the male spade connectors through the little 1/16" holes without tearing the rubber, so I cut the connectors off, pushed the wires through, and installed new connectors. Basic stuff, but some may just want to cut small slits for them to push through. The male spade connectors push into the connector that you pulled from the back of the OEM bulb. RED (+) to SINGLE WIRE and BLACK (-) to DOUBLE WIRE. (See Pictures).Install modified cap on the grommet, sliding the edges of the hole in the cap into the slot around the edge of the grommet. Slide this assembly up the wires, push the OEM connector into a space inside the housing, and replace the cap as original.
Mounting the Ballasts
  1. I took some pictures showing a double (lows and fogs) installation of the ballasts. On the drivers side, this stack can, with a bit of hassle, be installed below the headlamp housing. There are even 2 holes that match the bracket perfectly. It would involve 2 people, one to work from below (through the foglight access panel in the wheelwell), and the other working in the engine bay. For a single (lows only) installation, I used the M6 stud on the wheelwell. On the passenger side, they can be stacked under the now removed Radiator Overflow tank. An M6 stud is provided.(See Pictures). Mine was a single. Pictures provided. In my gallery, they are labeled "HID Install".
Follow the HID suppliers directions for connections.
I would be glad to answer any questions.
Here is a decent explanation of HID's and Halogens:
intellexual net · m k i v
Daniel Stern Lighting Consultancy and Supply
Last edited by Valk; Apr 8, 2010 at 10:05 PM. Reason: pdf file now attached with instructions and photos
Old Oct 19, 2008 | 09:50 AM
maxcichon's Avatar
Default re: HID Install Lows and Fogs with Pictures
I'm going to add 4 photos at a time to save you some hassle:
Driver side ballast installed showing 4 wire feedthrough.
Same
Passenger ballast installed showing wire routing
Double (stacked) ballast. Driver's side. (Not under the housing. 1st choice)
Old Oct 19, 2008 | 09:52 AM
maxcichon's Avatar
Cap with grommet installed
Same
New spade lugs inserted in OEM connector
New spade lugs crimped in place
Old Oct 19, 2008 | 09:54 AM
maxcichon's Avatar
Wires sripped for spade lugs
The infamous "barb" on the bottom of the Overflow Tank
1/16" drill to clear 2nd holes
Showing a grommet installed in the modded cap
Old Oct 19, 2008 | 09:55 AM
maxcichon's Avatar
Modded cap and grommet
Where to thread the wires and grommet
Sorta' same
Double stacked ballasts, passenger side under Overflow Tank
maxcichon's Avatar
Stacked assembly showing threaded spacers
Fuzzy closeup of clip and wires
Bulb ready for insertion
Sorta' same
Old Oct 19, 2008 | 09:56 AM
maxcichon's Avatar
Socket and caliper for cap mod
Cable tied hose out of the way
Where to put the Overflow Tank
Old Oct 19, 2008 | 09:57 AM
maxcichon's Avatar
Nut #1 for tank
Nut #2 for tank
Old Oct 19, 2008 | 10:28 AM
Good thread Max. This should be a sticky.
Old Oct 19, 2008 | 10:41 AM
Thanks Max. Thanks for your contributions to this forum.
Andrew, can we make this a sticky?
Old Oct 19, 2008 | 01:08 PM
Great job Max.
I have saved it to my PC favorites section as well.
Even if just replacing the OEM bulbs this will be helpful.
Thanks,Valk
Old Oct 19, 2008 | 02:06 PM
maxcichon's Avatar
I went back and captioned the photos.
I sure hope this helps!
I would REALLY like to redo this with embedded photos. In order.
I'm not too proud of the disjointed way it comes across.
BUT, thanks for the kudo's, gents!
Old Nov 8, 2008 | 11:36 AM
Buran's Avatar
I installed using these directions and I must say they are very helpful!
I did a couple things different though:
I used an 11/64 bit to drill the holes in the grommet that is on the hid bulb wires.
The hole is big enough that you can push the male plugs through (with a lilttle force) without having to cut them off and re-splice. The hole is still small enough to provide a waterproof seal.
I had no need to move the overflow tank. Perhaps my hands were small enough. It was never an issue for me.
I mounted my Ballasts in the same place but again I still had plenty of room under the tank to install it without moving it. You may want to give it a shot to save you some time.
Here is a quick pic with my phone. 6k bulbs.
Old Nov 8, 2008 | 09:44 PM
maxcichon's Avatar
You, sir must have some truly small hands!
Glad it worked!
Old Nov 27, 2008 | 08:34 AM
maxcichon's Avatar
I'm bringing this back to life-kinda'.
Yesterday I installed HID foglights, matching the color temperature of the low beams (4300K) I wrote this thread about last month.
I also have "White" inverted-cone LED's installed in the parking lamps and clear side-marker lamps. This makes the entire front end white with a touch (the LED's) blue. Stealth (mirrored) bulbs for both the front and rear turn signals rounds it out. I really like the effect.
What I thought was going to be a slick "stacked" set of ballasts was not to be. The cables wouldn't reach, and I left my cable stretcher at the lab. I ended up opening the wheel shrouds (after removing the tires) and working from there. I used existing holes in the framework with stainless hardware to attach the ballast brackets.
A little more work, but it looks OK to me. Pictures follow:
Old Dec 10, 2008 | 07:28 AM
oceans2c's Avatar
Awesome post!!!
I'm going to exercise it and install a kit. I ordered these. I'll let ya know how it goes!
I did some research and feel these xenons were the best bet. Riken is a german vendor matched with mercedes and the kit is of a higher quaility.
on http://rikensport.com/
Old Dec 10, 2008 | 08:02 AM
maxcichon's Avatar
I looked at those too. I'm just too cheap!
Old Dec 10, 2008 | 03:04 PM
07bluezx14's Avatar
I have used 4 kits off of ebay, and they work great. and are very easy to install, once you can get to the passenger side. I would suggest you do that side first, as it is the more diffucult to get to. Try using something like robo grips, to lift the overflow resevoir from underneath, I tried to just pull it out, but 1 hour later, and the robo grips lifted it right out of the grommet. good luck, chris
And save your self a trip to the parts store, and pick up the m6 nuts. your going to need 4 most likely.
Old Jan 18, 2009 | 07:49 AM
maxcichon's Avatar
Bring it back, I used this vendor:
http://cgi.ebay.com/ebaymotors/HID-C...5409QQtcZphoto
Old Feb 10, 2009 | 07:26 PM
Forza1's Avatar
OK, maybe I'm daft, but I'm having a hard time with these two steps:
What are you talking about removing the connector? I have two wires that appear to have spade connectors into the back of an H7 bulb. Are they going into the connector?
For step two, I can unhook the clip OK, but how do I removed the bulb? Does it go through the clip? Or does the connector first have to be removed(step 1) to get the bulb out?
