key in ing chime and door lock questions
Old May 3, 2011 | 07:17 PM
green-ghost's Avatar
Default key in ing chime and door lock questions
Either Im getting feeble minded or just dont drive my xf enough but I seem to be noticing things that never bothered me before but now they some how seem to be a PITA.
First of all, I really dont remember turning the car off and hearing the key in ing chime go off until i pull the key out, Its annoying to be driving -stop and shut her down ot hear that anoying chime until I pull the key out...did I overlook this before?
Secondly, I could of sworn that before when I shut the car off and opened my door that the pass door and trunk unlocked at the same time. Now they stay locked until I hit unlock on the fob. They only thing Ive done to the car recently is pulled the door console out and then pulled the door latch/lock mech. Its back together except for the door panel is still off.
Old May 3, 2011 | 07:31 PM
bluecoupe's Avatar
Default Re: key in ing chime and door lock questions
Pooly, mine chime only with the driver's door open and the key in the ignition. Also the doors and trunk unlock when the car is in park and I open the Driver's door.
Old May 3, 2011 | 07:45 PM
The fob can be programed to open the drivers door only with one press and the passenger and trunk with two presses. Or, open all doors and the trunk with one press.
Instructions to change the programming you have now.
Press both lock and unlock buttons at the same time and hold them down until the red light at the top of the key fob blinks twice. Repeat this operation and the change to the programming is undone.
Old May 4, 2011 | 05:35 AM
The fob works ok, its just that when I turn the car off the darn thing starts beeping at me and when I open my door to get out the trunk and pass door stay locked. Just thinking its because my door panel is still removed and something may not be connected for now.
Old May 4, 2011 | 07:43 AM
Read my post, the fob can be programmed to open ........
Instructions.
My beeping only starts if when I open the door with the key in the ignition as Bluecoupe says above as well.
Old May 4, 2011 | 08:06 PM
Thanks 180, I just tried that and all I get, on both fobs, is a quick barely visable flash right as soon as I press both keys. Also noticed my dome lights arnt coming on when unlocking car but they do work when I press their on button. BTW, both fobs are very functional and work from quite a ways away. All this started when they removed the door lock actuator. I'll search and poke around just as soon as this rain stops.
Pooly
Old May 4, 2011 | 08:13 PM
Pooly
It takes about 6-7 seconds to get the double flash and it is quite bright.
Old May 6, 2011 | 05:37 AM
OK got the fob to flash twice. Still having issues though. Again when I shut car off it starts to beep at me (its supposed to do this when I open the door with key still in ing) The doors all stay locked even when I open my door the hatch and pas door stay locked, dome light doesnt fade out either. I read theres a chime generators located throught the car and one is in the door in close proximity to the latch/handle I just had issuse with last week.
Im thinking the door chime thingy is thinking my car door isnt closed or just messed up. I see where the vacum airline goes into the latch as well as some whires seem to plug into the top portion of the latch, by the door pin that pops up. I dont know what these wires do as the tech at work buttoned it all in when he fixed my lock/latch mechinism deep inside the whole latch assembly. Anyone whos taken one of these apart knows what I mean...its a metal roller that causes the door handle to shut after you open the door...mine was all jamed up and my door handle went inop due to this roller assembly located within the latch assembly.
So can anyone tell me what the afore mentoined wires to the latch are for?
Old May 6, 2011 | 12:18 PM
I have had the door panel and the plastic membrane off and I have looked at the photo and can see no wires to the lock area, only the pneumatic tube.
The manual does mention wires to that area. These wires are not in Euro versions, but NA cars have them and are for "driver cylinder lock switch', but I cannot see them in the photo below.
Old May 6, 2011 | 06:44 PM
Yes exactly. the door latch actuator on my n/a is behind a metal piece and the wiring to it goes in above the latch cable. Also the wires tee off from the airbag wirinng to the latch. Tomorrow we're taking the handles off for painting and I'll do some trouble shooting
Old May 6, 2011 | 07:57 PM
Can anyone point me to where the door adjar switch is located on my 04 drivers door!?
Old May 6, 2011 | 09:42 PM
mferreira3417's Avatar
when you put your door panel back on all will work ok the little screw on the cover by the door latch that is attached to the door actuates the door ajar switch. of corse the bcm takes a while to recognise the door is open and turns on the dome lite open and close the door a few times after you put door panel back on and you will be fine. with out the little screw in, the bcm (body control module ) does not know the door is open and so it does not turn on dome lite
Old May 6, 2011 | 09:49 PM
SNAKEWOLF's Avatar
Page 8b-3 2004 Service Manual
Old May 6, 2011 | 09:51 PM
haha...thanks, I just finally got my butt off the couch and found the door agar switch...How did I ever miss that thing?! you are right, with the door panel pulled off the switch isnt getting pressed in all the way. I held it in and the dome light faded. Problem solved!!!!
Old May 7, 2011 | 07:09 AM
It is the molding around the latch on the door that operates the door ajar switch by pushing it in, not a screw.
With this molding off, as when the door panel is removed, the switch is not activated, the interior lights will switch off when the timing for them activates to save the battery.
Green-ghost, do you have the same layout as shown in my photo, or are more or less wires visible?
Old May 7, 2011 | 03:02 PM
More wires from what I can see. I thought the latch in your pic was in front of a metal support but it looks the same as mine...the black on black threw me. Like I mentioned, Ive some wires that tee off the airbag and go to the latch. Im thinking its the power to unlock the door upon an accident
REYMARTZ
22
Aug 7, 2021 12:37 PM
pioneer4x4
Mar 25, 2019 10:35 AM
gtjl
17
Jul 22, 2015 06:28 PM
Bayukbros
Jul 17, 2015 04:22 PM
66L72M21
Jul 15, 2015 04:23 PM
