Low coolant light
Old Oct 18, 2018 | 08:25 PM
alexdc's Avatar
Default Low coolant light
Hi everyone,
Since I've owned the car, the coolant light likes to come on and off. The service manual says that it is a low coolant light. Temp is still showing good, right in the middle. When I look at the coolant tank, that's where I get confused. Am I totally blind because I can't see a low and max line on the tank itself. I don't even know if my coolant level is fine. It seems low in one part of the tank.
Then I looked at the coolant flush tutorial to get to know which coolant was recommended. You guys seemed to recommend G05 which is not carried by any auto/department store around here. Why G05? what does it even mean? I would like to know. All I could see is HOAT rated coolant (which was recommanded in the other thread as well), 50/50. It was recommended to use 3/4 of anti-freeze concentrate with 1/4 of distilled water? Can any of you guys elucidate me on that.
Thanks
Old Oct 19, 2018 | 02:09 PM
alexdc's Avatar
Default Re: Low coolant light
I guess I am asking for too much haha.
Old Oct 19, 2018 | 03:09 PM
The coolant level in the tank should be level with the white plastic post inside the tank
There are no lines on the tank indicating low and high
Old Oct 19, 2018 | 05:09 PM
Originally Posted by alexdc
Hi everyone,
Thanks
The ratio is 50/50, antifreeze/distilled water. Most use Zerex G-05 it is a HOAT (Hybrid Organic Acid Technology). I cannot remember where I got mine though. You are best to use distilled water, it is cheap enough at the grocery store.
The light flickering is not only caused by low coolant, put ‘coolant light’ in search and see what Pizzaman says about it among others.
Old Oct 19, 2018 | 07:14 PM
alexdc's Avatar
I found the G05 HOAT coolant. I will take picture of what we can see of the tank to show you guys the level. It's probably low.
Old Oct 19, 2018 | 09:16 PM
Hi everyone,
THe service manual says that it is a low coolant light.
The manual is wrong. Ok, let's call it "misleading".
The light indicates that something is wrong:
  1. The coolant level in the reserve tank is low.
  2. The coolant level sensor in the reserve tank is defective.
  3. The engine temperature is above 2xx degrees (not sure what temp, I believe above 220F)
  4. The Fan Control Module is indicating that the current flowing thru the engine cooling fan is either lower than expected or higher than expected.
  5. The Fan Control Module is not communicating at all with the ECM.
And probably other stuff I don't know about.
From what you describe, I'd suspect the most likely issue with your car is (in descending order of likelihood) 2, 1 or 4.
Old Oct 20, 2018 | 11:59 AM
alexdc's Avatar
Thanks you!
Old Oct 31, 2018 | 04:23 PM
alexdc's Avatar
Here is the inside of the tank. I think it's
low.
Old Oct 31, 2018 | 06:51 PM
Does not look low to me. (Show us the level from the OUTSIDE view.)
With a cold engine, the tank must not be very full, because as the engine heats up, coolant expands and the tank level will rise considerably.
Old Nov 1, 2018 | 12:51 PM
alexdc's Avatar
There you go
Old Nov 1, 2018 | 01:02 PM
There you go
That is low, the coolant when cool should be level with the top of the white post visible through the fill hole as mentioned by Valk. Which makes it level with the top of the white tank section.
Old Nov 1, 2018 | 02:29 PM
alexdc's Avatar
Thank you sir!
Old Nov 1, 2018 | 06:26 PM
alexdc's Avatar
I was able to put around 1.8 L until it reached the top of the post. No coolant light yet. I've filled it a bit more after that because I didn't have anywhere to get rid of what I had left (2L in total). Hopefully that's fine. I will report back if the light comes back on. If it doesn't I won't. I will make sure I don't see any leaks as well.
Old Nov 2, 2018 | 07:23 AM
MAGNATUDE's Avatar
Check for any leaks where the return hose attaches to the reservoir. A common issue with the reservoir tank is that the return hose nipple tends to break or crack over time and leads to coolant leaks. Some guy here has a nice detailed write up on how to repair a broken coolant tank nipple.
Old Nov 2, 2018 | 09:33 AM
When you put too much in it will blow out when it gets hot. You need some air in the tank to take up the expansion, water does not compress but air does hence the need for it. So you may see some under the car at some time.
Old Nov 2, 2018 | 01:40 PM
alexdc's Avatar
it barely goes over the top of the post.
Old Nov 9, 2018 | 09:22 AM
Have you solved your problem? Presumably you did from your previous post.
Old Nov 14, 2018 | 01:53 PM
alexdc's Avatar
I did the tensioner, both pulleys and belt service and now my battery is dead. I'm trying to charge it with a low cost 2amp battery maintenance charger (it takes forever and it's quite cold here) so hopefully I don't need a new one. I will report back soon when I can drive it.
Old Dec 5, 2018 | 03:03 PM
alexdc's Avatar
I have a coolant leak 😞
sweetjamesjoness
Mar 30, 2018 04:46 PM
figgy7935
Mar 28, 2013 10:19 AM
billvp
Feb 1, 2011 11:06 PM
AlG
15
Jun 23, 2010 02:11 PM
NeverEnough
Oct 20, 2007 08:12 PM
