Lost power and died
Old Mar 12, 2020 | 08:53 AM
Old phart phred's Avatar
Default Lost power and died
Engine cold 55 approx drove one blockLost power
cranks well but starter stays engaged untill key is fully off
did not see any unsual dash lights
Can I tow it home in nuetral auto tranny
I suspect electrical gremlin
Swapped RCM
2005 coupe NA
Old Mar 12, 2020 | 09:58 AM
Default Re: Lost power and died
Swapped RCM
2005 coupe NA
Starter will stay engaged until the engine starts or until some specified time has elapsed.
Owners manual says no towing, flat bed only. I guess if it was a couple of yards it would not matter, so how far is a block? More than a couple of yards?
Old Mar 12, 2020 | 11:40 AM
Obd2 codes
p2311 ignition coil 4 secondary circuit isufficint ionizationization
p2312 ignition circuit low
Old Mar 12, 2020 | 11:46 AM
Towing 30 miles below 30 mph per manual, so 200 yards does not seem unreasonable, unless member experience has shown otherwise
Old Mar 12, 2020 | 11:58 AM
Disconnected battery for a reboot, got same codes, will see if can locate crank sensor
Old Mar 12, 2020 | 05:16 PM
twanger's Avatar
It is at the rear of the left cyl bank on the block w/ a metal shield around the back & lower side . Must pop off top engine cover to access it .
file:///C:/Users/Sandy/AppData/Local...r-%20Rev.4.pdf
Old Mar 12, 2020 | 10:33 PM
Swapped out the crank and cam sensors at curbside, kept the old ones, disconnected the negative. Still no joy, and still throwing the same obd2 codes, will have to dig deeper into the control module s. Manuals.
Old Mar 13, 2020 | 12:09 AM
Switch the coil for one on the other side of the engine and see if the error moves to the new position.
Old Mar 13, 2020 | 11:27 AM
Easy enough to swap coils, but none of them appears to be firing, haven't stuck my nose at the exhaust, or pulled a valve cover off to see if anythings moving or fueling. Starter sticking may make that simple to do.
fire triangle fuel air ignition
Old Mar 13, 2020 | 11:39 AM
Did it suddenly lose power or did it just fade away?
Can you hear the fuel pump when you turn on the ignition to the position just before the start position with the doors closed and the window down?
Old Mar 13, 2020 | 10:12 PM
More like died and rolled to a stop, was only going about 15-20 at the time, yes I can hear fuel pump cycle and it sounds normal. Was cold and raining today, and I'ma fighting a cold so didn't swap coils today. Neighbor helped me push it into his driveway. Hope to get it back and into my garage tommorow. Service manual is on my office computer. BTW 180 your write up on crankshaft sensor replacement was excellent, but bolt was too tight for my flex extension, and had to buy several short extensions to get enough slop to get it broken free. Thanks for your reply.
Old Mar 14, 2020 | 08:10 PM
Pulled fuse #11 which appeared good and put in spare, engine started and ran for 30 seconds and quit. Would not start again, both fuses test good. Will attempt to get to back of fuse panel.
fener88
Mar 12, 2020 08:59 AM
XF1RE
Aug 31, 2019 11:13 AM
thegarman
Aug 24, 2018 10:32 PM
Kanadoos
Apr 20, 2015 08:42 PM
acrispy1
Oct 4, 2007 02:56 AM
