Automatic Transmission Adapter Plug
Old Apr 16, 2024 | 01:06 PM
Nelson G's Avatar
Default Automatic Transmission Adapter Plug
I changed the trans fluid and filter and the adapter plug about a month ago. The other day when I was pulling the car out I noticed some trans fluid. I put the car up on the lift and noticed the area were the adapter plug is is wet with fluid. I looked around and did not see any fluid around the gasket area. I re-torqued the pan bolts. I removed the adapter plug and fluid came out which I caught in a pan. The gaskets look good and it seemed it was seated right. I cleaned the area up and put the adapter in and button everything up. Add fluid back into the trans and took the car for a run to get the fluid up to temp and rechecked the fluid level. everything was fine. I did not see any fluid leaking. The next day I came out and there was fluid.
I have ordered another adapter plug. Does anyone have any idea of what I have done wrong? Or have something I have over looked? There are no old gaskets, as when I took out the old one they were on the adapter plug.
Thanks
Old Apr 16, 2024 | 01:39 PM
Ronman's Avatar
Default Re: Automatic Transmission Adapter Plug
Thanks
Those transmission connectors are super super annoying. That happens to me every time I have had transmission service done if the connector was replaced. You will have to replace the connector again, it is best to buy one from a local Mercedes dealership since the list price is about 16.50. In the future it might be best to leave the previous connector alone if it is not leaking when doing transmission service.
Old Apr 16, 2024 | 01:53 PM
Nelson G's Avatar
I would have but it did have the old clear gaskets. I have ordered from two different supplier I will see what happens.
thanks
Old Apr 17, 2024 | 06:48 PM
Oldschool's Avatar
I will be doing the transmission flush next week and will heed your advice about the connector and leave well enough alone.
Old Apr 18, 2024 | 08:36 PM
bc75's Avatar
Make sure its Mercedes brand. I've tried different brands they always leak,
Old Apr 19, 2024 | 08:38 PM
machfivecrossfire's Avatar
thanks
I use FCP Euro for crossfire parts. Put in 2004 mercedes slk 320 / or AMG depending on NA or SRT. Mercedes dealers never have the part here in San Diego or do not realize most xfire parts the same as an slk 320.
Old Apr 20, 2024 | 03:44 PM
Nelson G's Avatar
Check out the TSB: SB_21_002_05_Transmission_Leak
Old May 10, 2024 | 02:36 PM
Ray S.'s Avatar
Just did the transmission fluid, filter, adapter plug and the conductor plat I have 82,000 miles i had to get a dipstick first time to look ay it and it was low and real dark almost black so it was time got my kit from FCP Euro all German parts so far no leaks yet. Quite a job when on jack stands you tube helps a lot. Xfire good for a long time now I hope.
syfi
Mar 28, 2026 04:14 PM
Donkeyface
May 8, 2021 11:01 PM
15Spokes
Nov 29, 2018 03:04 PM
huudoo
Jul 17, 2013 08:54 PM
CrossfireLTD
Nov 28, 2005 11:37 AM
