replace crank and cam sensors together?
Old Sep 22, 2011 | 12:28 PM
  #41 (permalink)
Default Re: replace crank and cam sensors together?
Originally Posted by Lance1337
Anyone know where the air intake temp sensor is located? I'm gonna replace it myself.
The AIT sensor is part of the MAF sensor. (Mass Air Flow) It is at the rear of the air cleaner.
Old Sep 22, 2011 | 12:35 PM
  #42 (permalink)
Lance1337's Avatar
The dealer seems to really have me by the ***** because now they say the car won't run...sigh what a joke taking things to the dealer. So I'm going to replace this sensor in their parking lot, are there any special tools I need? The cps replacement was somewhat easy, will this be just as easy? I'm wondering why they want $150 to replace this IAT sensor.
Old Sep 22, 2011 | 05:08 PM
  #43 (permalink)
Lance1337's Avatar
Ok, a little update. I talked with the guy at the dealer and he let me use the tools needed to replace the cps so i went and bought another cps from NAPA auto parts instead of autozone or advance, put it in and now the car runs and seems to run fine so far. I will know by tomorrow if this has done it.
Total cost: $100 diagnostic fee+$67 cps from napa
$167. A lot better than $642 that the dealer wanted.
Old Sep 22, 2011 | 06:08 PM
  #44 (permalink)
If you need to remove the MAF sensor you will find two tamper resistant screws will need to be undone. These are a rare type of Torx screws in as much as they only have five lobes, not the normal six.
You can see that they are a bit chopped up as I managed to use a tamper resistant straight bit screwdriver, the slotted type.
Beaner said he used a regular slotted screwdriver. The screws are a bit tight so be careful you do not stab yourself.
Old Sep 23, 2011 | 10:25 AM
  #45 (permalink)
Lance1337's Avatar
I don't think i have a MAF, mine looks nothing like that. The IAT sensor is located below the throttle body and it looks like it just clips in on my car. Are you referring to a n/a crossfire?
Old Sep 23, 2011 | 11:04 AM
  #46 (permalink)
No MAF on the 6.
Wow! did we wander of track or what?
Old Sep 23, 2011 | 11:34 AM
  #47 (permalink)
Lance1337's Avatar
Lol, a little bit. I appreciate all the info and the pics though
Old Sep 24, 2011 | 05:36 AM
  #48 (permalink)
Lance1337's Avatar
Okay, this issue is now solved. Advance auto parts sold me a bad cps. So my conclusion is buy parts from NAPA or another high quality source because Advance and Autozone sell crap. Thank you everyone for all the help and guidance you have given me.
Sincerely,
Lance
2005 crossfire srt-6 95,300 miles
Old Sep 24, 2011 | 07:54 AM
  #49 (permalink)
Security torx screws...Harbor Frieght has the security torx bits...
Old Sep 24, 2011 | 09:48 AM
  #50 (permalink)
These have five points with the pin in the middle not six points with the pin in the middle.
Wiha 5 Point Security TORX Plus Bits
IPR - 5 Point Security Torx Plus Bits
Available for authorized OEM's and their certified service reps. Call Our Customer Service Department At 800-494-6104 for information.
IPR
8 - 40
WIHA is the seller of the bits shown, there are other sellers.
http://www.wihatools.com/indexes/indxsecuritytorx.htm
Old Sep 25, 2011 | 12:33 AM
  #51 (permalink)
tighed1's Avatar
What do I win?
Originally Posted by tighed1
Someone once replaced their bad CPS and their problems continued. Turns out the "new" CPS was also bad.
Just sayin.
Old Sep 12, 2016 | 12:43 PM
  #52 (permalink)
POS's Avatar
POS
Default stalls around 2500-3500 rpm help!
2004 Crossfire Cuts Off Everyone I Drive It Past Let's Say 3000 Rpm I Ran The Codes And Got The Crankshaft Position Sensor So I Replaced It ,But It's Still Doing The Same Thing Please Help
Old Sep 12, 2016 | 09:16 PM
  #53 (permalink)
Default Re: stalls around 2500-3500 rpm help!
Sounds to me (not knowing what exact code you are getting, there are several that pertain to the Crank Sensor and they do not all mean the same thing) - I'd say it's the Crank Sensor.
Did you go to Autozone or NAPA and buy some generic off-the-shelf sensor? Or did you order the RIGHT PART?
Here is the RIGHT PART:
https://www.germanautosupply.com/sto...sensor-96.html
I have carried one for five years, when mine died, I put the spare in and ordered another. They are not easy to find locally - and this has come up several times before - those generic sensors do not ALWAYS work and they do not always NOT work - you just never know with them.
ALSO - SEE POST 51!
Old Sep 13, 2016 | 07:10 AM
  #54 (permalink)
They are like a box of Choc-o-lit - ya never know what you are gonna get.
KDW4Him
18
Sep 1, 2021 05:47 PM
PNA
Nov 12, 2020 04:44 PM
oldvintagedude
Aug 14, 2015 06:20 AM
Jul 29, 2015 06:13 PM
Mark McKay
Jul 17, 2015 01:18 PM
