Alternator Help
Old Apr 28, 2010 | 05:49 AM
Kagen's Avatar
Default Alternator Help
I'm currently trying to replace my alternator in my 04 nonsrt. It's hooked up to connectors but can't get it to bolt in. It won't fit in between the holes. To get the old one out I had to use a wrench as leverage. Are there any tricks?
Old Apr 28, 2010 | 01:36 PM
Kagen's Avatar
Default Re: Alternator Help
bump for answers
Old Apr 28, 2010 | 01:40 PM
Kind of wonder if you got the right one, I mean physically the right one. Amperage rating has to be right, but the PHYSICAL configuration has to be right too.
Sounds like it isn't the same as the old one.
Old Apr 28, 2010 | 05:00 PM
I have yet to remove the alt from a Crossfire so this is all a guess. On a lot of cars, the mounting bracket uses a bushing to keep the alt tight in place so the case doesn't get crushed or cracked when tightening.
With the alternator off, you can get a small hammer and punch in there and knock it back a tic or two to allow the alternator to fall in place.
James
Old Apr 28, 2010 | 05:20 PM
As indicated in the above post the gap that the alternator fits in is adjustable and the bolt pulls the back clamping nut toward the front of the car and maintains the pulley in alignment with the belt. The distance between the front and rear faces on the mounting shoulder can be different and the clamping distance is automatically adjusted by this design. The rear post does not move just the part sliding inside it.
Old Apr 28, 2010 | 05:25 PM
94Bravada's Avatar
Just wondering how much does a new one run?
Old Apr 28, 2010 | 05:47 PM
Kagen's Avatar
A new one online was like $1800, I got a remanufactured one from checkers for $195 with a $70 core charge. I'll go try with a hammer now and let you guys know.
Old Apr 28, 2010 | 06:12 PM
blackcrossfire07's Avatar
1,800 for a new alternator??????? THAT IS SCARY!
Old Apr 28, 2010 | 07:09 PM
94Bravada's Avatar
195 is not bad but 1800 that is a little much for me haha
Old Apr 29, 2010 | 05:02 PM
Kagen's Avatar
Seems like that will work but I can't seem to get a hammer or punch down there. Has anyone actually done this themselves? The thing is really in there and it seems like it would take a lot to move it.
Old Apr 29, 2010 | 05:16 PM
waldig's Avatar
Talking Re: Alternator Help
PM Rob at needswings, he is very helpful, Woody
One day till the weekend..........................ZOWIE
Old Apr 29, 2010 | 05:59 PM
Just screw the bolt in 5 or 6 turns and tap the head of the bolt, that should do it.
Old Apr 29, 2010 | 06:33 PM
MikeR's Avatar
I did mine about a month ago and didnt have any problems... it was a snug fit but went right in....
Old Apr 29, 2010 | 07:04 PM
ChuckNorris's Avatar
Your problem is on the water pump. There is a floating shim that needs to be adjusted out with a socket and c clamp. Kinda like pressing the pistons on your brake calipers back in when changing pads.
I have a good alternator(38k) I would have shipped to you for $105.
Old Apr 29, 2010 | 11:41 PM
Sorry I was wrong (that's the second time in my life ) and Chuck is correct. The sliding clamping bushing is in the front not at the back as I had said. This bush needs to be pulled toward the front of the car so that the gap is a bit bigger than the width of the alternator that goes in it. When the bolt is tightened it clamps against the alternator.
Put a bit of penetrating oil on that round bushing in Chucks photo and pull it forward.
Chucks suggested method.
Old May 2, 2010 | 03:51 AM
Kagen's Avatar
Couldn't get a C-clamp in there but used a crowbar and a hammer to get them.
blackpepper
Oct 4, 2017 06:09 AM
RiderJC
Oct 5, 2015 06:34 PM
skeet370
29
Sep 18, 2015 05:53 AM
RiderJC
Sep 7, 2015 11:19 PM
nickwe21
39
Jul 31, 2015 01:48 PM
