How do I remove the rearview mirror???
Old May 17, 2018 | 08:23 AM
Default Re: How do I remove the rearview mirror???
See the hole in the mirror mount ?
You put the largest Allen wrench that will fit in it and turn 90 degrees either way, that will remove the mirror.
Then you tighten up the spring mount.
Reverse for re installation.
The mirror is self tightening as I recall.
Here is how to detach and reattach the mirror.
CLICK See posts2 and 4.
Take it off and see what the problem is maybe the attachment is broken or bent
Old Apr 29, 2023 | 05:54 PM
magicjay's Avatar
Smile Re: How do I remove the rearview mirror???
Originally Posted by yodaforce
I've searched and found nothing. In the process of trying to remove it, I have successfully broken off a chunk of glass which is still attached to the mirror. Not really a huge deal because I have someone coming over to replace the windshield, but now I need to disconnect the piece that is apparently glued to the glass. I saw where someone said "turn it 45 degrees" to remove it. Well, that's how I broke the chunk of glass off, prying and twisting.
There is a link below that shows photos and how to remove the mirror. I did as instructed but it would not budge. I was afraid that I was going to crack my windshield. I sprayed WD-40 into the hole in the back using a w-d straw, I let it soak for a few minutes and then it twisted right off. I did use the allen wrench to help turn the mirror. I wanted to remove my old mirror to install a new dash cam mirror. Good luck to you.
Old Nov 16, 2024 | 09:48 PM
guitarguy's Avatar
Originally Posted by BisB
How does one tighten the mirror to the windshield mount? It is still "attached" but wobbles.
I had this problem also. The mirror wobbled side-to-side while still attached. Others were correct about how to remove, just turn the base 90 degrees. Once removed, you will see an odd shaped, metal fitting in the base. This is the piece that creates the pressure fit with the mount that is permanently attached to the windshield. This metal fitting is connected with a torque screw. I figured the mirror wobbled because the metal fitting has become sprung, and I was correct.
I took the fitting and heated it on a gas stove burner (holding with pliers). Then I crimped in the sides ever so slightly so that it would fit snugly to the mount on the glass. It was a little bit difficult to re-attached - probably because I overdid it with the crimping. Eventually got it re-attached and it fits nice and snug now.
Old Nov 18, 2024 | 12:11 AM
Great tip, thanks!
Old Nov 9, 2025 | 06:09 AM
Romad's Avatar
Great tip, thanks!
Thanks I'll give that a try. Seems like such a weird attachment for a mirror! Once removed I guess I'll have to crimp on the spring attachment to tighten it up. Appreciate the help!
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
55chevy
Sep 13, 2015 07:38 PM
