Key stuck
Old Oct 31, 2018 | 05:32 AM
Default Re: Key stuck
Originally Posted by Larry Hitze
I've never done my 04, so far no problems with it.
Then by all means don't do it.
You will enjoy answering all the questions about the Crossfire when you are stuck in the Walmart parking lot with a locked up key.
Old Oct 31, 2018 | 06:49 AM
RED DOG's Avatar
Originally Posted by Ed Mahoney
No I didn’t sell CROSSFIRE ! Just playing with member who tries to lowball ya when you need help !!! My son-in-law is service mgr. for Mercedes ��
Well Ed, I am happy to hear that you did not sell your Crossfire over the Sticky Key Fix issue . . . One that you knew about and did not fix until it left you stranded. I was really upset thinking that you would sell your Crossfire over a simple fix issue. Welcome back to the good graces of this forum and its members . . .
Old Oct 31, 2018 | 09:19 AM
Ed Mahoney's Avatar
Take it from me it’s going to happen when you least expect it too ! Do it now ! Mine showed no signs at all of sticking or getting stuck, 29K miles on her ! Now that’s it’s fixed can’t beleive how easy it turns , like a knife going thru soft butter ! Key has never turned this easy !
Old Oct 31, 2018 | 09:30 AM
Tom3120's Avatar
Ed, what year is your car? I’ve read that this issue affects 04-06 models. Does this happen on the 07&08 models too?
Old Oct 31, 2018 | 11:45 AM
RED DOG's Avatar
'07 & '08 models have a "corrected" ignition switch . . .
Old Oct 31, 2018 | 11:46 AM
No. The 7's and 8's (and very late 06's) were built without the two offending items.
Old Oct 31, 2018 | 10:53 PM
Ed Mahoney's Avatar
Yes mine is a 04 , but yet when you order a new ignition housing they still have the spring & pin ? Why ?
Old Oct 31, 2018 | 11:43 PM
If you ordered the old part number you may get an old part, sometimes you are told the new relevant number. I am sure that the later cars were fitted with a part with different number. A very similar number but a different one. Mercedes altered the part number according to its revisions., I believe the numbers changed would be the 4th and 3rd from the end. I’ll check the part numbers for the 2004 and 2007 years and compare.
Old Nov 1, 2018 | 12:05 AM
Larry Hitze's Avatar
Didn't say I wasn't going to do it, I just said that I haven't done it and have had no problems.
Old Nov 1, 2018 | 08:37 AM
In that case I retract whatever I said, even though that doesn't matter as no one listens to me anyway.
Old Nov 1, 2018 | 08:45 AM
Ed Mahoney's Avatar
Yup me to , then stuck in parking lot !!! LOL
Old Nov 1, 2018 | 09:11 AM
I listen and learn from you all the time, my advice is to do it now as well; the older you get the harder it is to get under the dash and do the job.
I learned that it is easier for a fit sixty year old to get in the trunk and put the five trunk panels into place than a man in his late seventies who failed to do the same whilst leaning into the trunk. My car would still be without those panels unless bluecoupe had not driven an hour or so to help this old geezer out. For which I am eternally grateful.
Old Nov 1, 2018 | 01:15 PM
I listen to you, that's how I knew to reply
GA crossfire
57
Jun 2, 2014 12:51 AM
mattsmed
Apr 18, 2009 07:24 PM
gtrtekcraig
Apr 14, 2009 09:32 AM
Roadrunner
Jul 24, 2008 01:14 AM
FUNONE
Jun 3, 2008 02:01 PM
