Don't start, don't lock unlock door, fun run without key
Old May 20, 2022 | 05:08 AM
giaiu79's Avatar
Default Don't start, don't lock unlock door, fun run without key
good morning everyone. My Crossfire does not open the doors with the remote control, the car does not start and without the key inserted the fan starts running. I checked the fuses and changed the battery but the problem persists. can you help me?
Old May 20, 2022 | 08:28 AM
Default Re: Don't start, don't lock unlock door, fun run without key
That's not helpful. Does the starter engage or not? If you can't tell us that, we don't know what we are chasing.
without the key inserted the fan starts running. ?
This is very odd. Read that partial sentence, is that what you meant to type? If so, the Fan Control module is bad.
If you meant "WITH the key inserted and turned to "on", the fan runs very fast after about 30 seconds" then your RCM is failing to power up the ECU - easy fix.
Old May 20, 2022 | 10:09 AM
giaiu79's Avatar
starter engage is ok. I have the feeling that there is no petrol reaching the engine
no no .... without key the fan the passenger compartment cooling system start but this doesn't always happen.
Old May 20, 2022 | 12:20 PM
There are three fans on the Crossfire, it is best to say which one you mean.
Old May 20, 2022 | 01:07 PM
giaiu79's Avatar
problem almost solved.
broken fuel pump relay.
fans is ok.
there remains only the problem of the doors that do not lock or unlock with the remote control
Old May 20, 2022 | 02:24 PM
fans is ok.
If you have been struggling with electrical issues, it is quite common to see the sync between the key fob and SKREEM get lost.
To re-sync the fob to the SKREEM, do this:
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Old May 23, 2022 | 06:28 AM
giaiu79's Avatar
To re-sync the fob to the SKREEM not workig.
the car start but the immobilizer not working.
what can i do?
thank's all.
Old May 23, 2022 | 04:42 PM
what can i do?
thank's all.
To my understanding the immobilizer is the SKREEM.
Nekers12
Nov 11, 2017 10:57 PM
mark anthony
Jul 2, 2017 03:01 PM
valley89
Apr 29, 2017 11:06 AM
buniqueXF
Apr 21, 2011 01:14 PM
mdaniels4
May 21, 2009 04:41 PM
