Chrysler to Replace '05 Convertible Tops Under TSB - YAHOO!!
Old Aug 7, 2012 | 12:17 PM
  #521 (permalink)
xFireFlyx's Avatar
Default Re: Chrysler to Replace '05 Convertible Tops Under TSB - YAHOO!!
Originally Posted by lildaddym
I would be interested in seeing the entire bulletin...did anyone notice that there is no mention of a specific year?
That part I posted is all that the bulletin says. I got this from my warranty guy and have attached the full file here. It shows all of the service bulletin's for the 2005 Roadster, I am guessing my warranty company did a check that was specific to my car. I called the Chrysler dealership today and this is what he said:
It is a warranty extension good up to 100K miles. If your car has over 100K miles on it then you are unable to make a claim on this. It doesn't matter if you bought an extended warranty or not, just as long as your car is a Roadster and has less than 100K miles on it.
He did not mention a specific year model. I have an apt at 3 today to take it in and let them check it. He said you don't just automatically get a new top bc of this bulletin. They have a test they can do on the window and if it checks out ok then they won't replace it. So, it has to actually need replacing to get replaced.
Old Aug 11, 2012 | 12:34 PM
  #522 (permalink)
arejohn's Avatar
After 3 weeks my top is finally finished. Worth noting: Top is so tight that I can just get it to close. Interior of top appears to be vinyl with an embossed pattern. Rear window has a plastic interior frame. I'll post pictures after I pick it up.
Old Aug 11, 2012 | 12:39 PM
  #523 (permalink)
xFireFlyx's Avatar
Glad you were able to get it replaced post pics
Old Aug 11, 2012 | 07:37 PM
  #524 (permalink)
Was your replacement top part of the Chrysler replacement program? Are you saying the replacement is different than the original?
Old Aug 11, 2012 | 07:44 PM
  #525 (permalink)
JohnnyE's Avatar
Your mention of a "plastic interior frame" is the first thing I have heard about the new top being different from the original 2005 top. My window is separating and Chrysler won't cover it. Rather than just gluing in the window, can you tell me about the plastic frame, how it may improve on the original installation, and, give us pictures!
Old Aug 11, 2012 | 07:54 PM
  #526 (permalink)
Iamfink2's Avatar
I got tired of waiting for Chrysler to fix my top after the window came loose 3 times the last time half the window came out. I reported it to Chrysler and also took it to the dealer to look at it and they checked with the district manager and the answer was I don't qualify for a new top. So I bought a new top from eBay and installed it last Sunday. Fits like a glove.
Old Aug 11, 2012 | 08:24 PM
  #527 (permalink)
lildaddym's Avatar
What kind of time did it take you to install it yourself?
Old Aug 12, 2012 | 07:16 AM
  #528 (permalink)
Iamfink2's Avatar
About 6 hours but I took my time and didn't rush to avoid any mistakes. I also had to replace the 2 stay pads (the 2 straps that run on each side of the top) because the drivers side was dry rotted I think because of the leaking rear window.
Old Aug 12, 2012 | 09:34 AM
  #529 (permalink)
smfrycruzr's Avatar
Going on three weeks now, still have not heard as to when the new top will be in stock...
Old Aug 12, 2012 | 10:42 AM
  #530 (permalink)
skarlet's Avatar
What top off of eBay did you get. The only ones listed are Chrysler replacements and how did you know how to replace it. Pretty much everyone says that you have to send in the original top. My wife's rear window fell out completely for the 2nd time and we had a lot of water damage I need to replace the whole thing. Tried gluing it in but it is a bear when the whole window falls out.
Old Aug 12, 2012 | 10:53 AM
  #531 (permalink)
Iamfink2's Avatar
The one I bought was a Chrysler top if you go with an after market top you need to send several parts needed for the new top.
Old Aug 12, 2012 | 10:56 AM
  #532 (permalink)
skarlet's Avatar
Was the Chrysler top just a simple take the old one off and put the new one on. and did it come with any directions or is it rather straight forward.
Old Aug 13, 2012 | 07:20 PM
  #533 (permalink)
topless SRT's Avatar
OK, so my "new" 2005 Crossfire SRT6 Roadster does have a rear window issue. The top is perfect accept the window is separating from the top on the drivers side edge. I spoke with a Chrysler Customer Service rep this afternoon. So far I have found this:
X31 is very real, but it only applies to Crossfires delivered to dealers in AL, FL, GA, LA, MO, NC, SC, TN and TX. Pretty strange to me. Mine is from CA.
The representative is doing more research for me. But it sounds like I am out of luck.
Old Aug 13, 2012 | 09:40 PM
  #534 (permalink)
Iamfink2's Avatar
I felt that it was not that difficult you have to drill out the old rivets and replace with new that were supplied with the new top and remove some of the weather stripping. The directions I used were from the service manual which is available on the right here on this site.
Old Aug 13, 2012 | 10:07 PM
  #535 (permalink)
xFireFlyx's Avatar
I bought my CF in Oklahoma and now live in Wisconsin....mine was covered...although I didn't have it replaced bc it didn't need to be replaced. Took it in and the dealer said it would be replaced if needed, then they did some tests on it, didn't need it luckily.
Old Aug 13, 2012 | 11:06 PM
  #536 (permalink)
toia6407's Avatar
Hello topless SRT,
My name is Michael and I live in Palm Desert,Ca. I bought my SRT6 roadster in Phoenix, Az........which is where it was originally delivered in 2005. The Chrysler people gave me the same explanation regarding the xx31 notice. They told me I would not be eligible since Arizona was not one of the eight states as referenced. I challenged them that the eight relevant states were all warm states where heat was causing the delamination .........and then asked them what part of Phoenix wasn't considerably hotter than any of the included states???? At that point their position began to change and within a couple more days they approved my entire top. You really have to keep on them and elevate to a higher authority if required. I would also call them out on their lack of consistent treatment of this problem as the precedent has clearly been set that they have approved claims from outside the states originally called out in the bulletin. Don't give up on this and fell free to contact me on a PM for additional details of my transaction. Good luck..........Michael
Old Aug 16, 2012 | 03:16 PM
  #537 (permalink)
greedisgood's Avatar
Got a new top today ! Very nice. Was about a 2 week process between Chrysler, Dealership, and me. A lot of confusion between the rep for Chrysler and service manager. She called me 3X saying service manager hadn't looked at the car yet. But I already had the car back in my hands with the new top when she was calling me ! Strange.
Pretty nice having a new good looking top
Old Aug 17, 2012 | 08:22 AM
  #538 (permalink)
smfrycruzr's Avatar
Top came in last week...
We're still waiting for the dealership to coordinate with the shop that's going to do the work...
Old Aug 21, 2012 | 08:14 AM
  #539 (permalink)
smfrycruzr's Avatar
Yesterday, finally got the time for the appointment for the installer people.
August 29th, 2012.....will have update sometime afterwards....
Old Aug 24, 2012 | 08:10 PM
  #540 (permalink)
grascon7777's Avatar
Had my new top installed this week. The local dealership had a bit of a time installing. After 3 days they failed in installing the weather stripping adequately. They forced it into the tug and groove. I am sure that it will eventually fall out. I will be taking it to a few shops this week for appraisals. And will submit to Chrysler US for approval.
FYI.
Chrysler US was very amenable. The top was ordered from Germany and paid for entirely via the TSB.
Anyone else with a problem with the weather strip install?
Peace,
Gino
