Radio Removal
Old Aug 2, 2012 | 10:31 AM
gcong's Avatar
Default Radio Removal
I need to replace my radio on a 2006 Roadster. In order to be sure I get the correct replacement I need to remove the radio I now have. In an earlier forum someone mentioned keys that fit in the lower right and left corners of the radio that allow the radio to be removed.
My question is, where can I find the keys to remove the radio? I would appreciate any help I can get regarding this issue. Thanks! gcong
Old Aug 2, 2012 | 10:34 AM
Default Re: Radio Removal
Wal-mart has a set that has both the ford and chrysler removal tools in it. Its about 4 bucks (last I got it was I think $2.49 plus tax). They are detailed in here search for radio tools and the pictures will come up. The audio sound kiosk at Wal-mart has them cheap!
Old Aug 2, 2012 | 10:35 AM
Mrmiata's Avatar
Rumor has it Walmart has them.. do a little more searching on here and you will find what they look like. I copied the picture on here and plasma cut some at work to get mine out.
Old Aug 2, 2012 | 10:36 AM
Gotcha Mr M!!!
Mrmiata's Avatar
JINX.. you owe me a coke..LOL
turbomar's Avatar
AUDI VW MERCEDES STEREO RADIO REMOVAL TOOLS SET RRK132 | eBay
Or if you are in a hurry, you can fab out of 1/2" s/s strapping. Cut to same profile and bend the ends 90 degrees instead of the finger loops
Old Aug 2, 2012 | 10:38 AM
Mrmiata's Avatar
We must be bored.. this thread is getting more attention than a road kill rabbit on Vulture Island !
Old Aug 2, 2012 | 10:41 AM
turbomar's Avatar
WoW.... that was some fast clicking guys!
Old Aug 2, 2012 | 10:42 AM
gcong's Avatar
Thanks for the help. I'm on my way to Wal Mart now.
gcong
Old Aug 2, 2012 | 12:24 PM
gcong's Avatar
Okay, I ran to Wal Mart and picked up the keys for the radio. I have removed the radio and retrieved all of the info I will need (I guess?). Can the keys be removed without damaging anything? The radio still plays, but the amplifier apparently is causing a short which drained the battery. I don't know if the amplifier can be repaired. I have been told to replace the radio. At the dealer, they estimated $600 to $800. I have seen replacements on the internet and needed the model # etc. to make an usable switch. Until I do that I would like to continue to use this radio. The problem is, when the fuse was removed to stop the battery from being drained, I now am without the electric door locks.
My question now is, can I remove the keys from the radio without damaging anything? Thanks for the help!! gcong
Old Aug 2, 2012 | 12:29 PM
Mrmiata's Avatar
if I'm not mistaken you push the tabs on the side in and remove the key..
Old Aug 2, 2012 | 12:43 PM
So, you took out a fuse and the battery does not drain down now? Good! But if the fuse feeds more than one item, how do you know it's the Amp and not something else fed by that fuse? Are they guessing or did they measure the current and prove this?
And if they DID measure the current, did they offer to leave that wire cut so you would not drain the battery while keeping the locks working? (Does not sound like it).
Pardon me, but I'm suspicious, cynical and just a pain in the ***.
Old Aug 2, 2012 | 12:44 PM
and THEN you slide the radio back in the slot. You don't need the 'keys' in the radio to re-install it.
Old Aug 2, 2012 | 01:04 PM
And, the door locks are NOT electric, they are pnuematic .....
Old Aug 2, 2012 | 01:20 PM
gcong's Avatar
No, they didn't measure any current, just removed the fuse. There is a description of what the fuse feeds in the owners manual, I think. Anyway, after talking to a service rep on the phone he came to the conclusion that it was the amplifier. Simply because it was the only radio related function related to the fuse removed.
Does anyone know of a good, independent Crossfire mechanic/electrician in the Lansing, MI area? How about a reliable auto-radio repair person?
I appreciate all of the information, although it is not what I necessarily wanted to hear. I was suspicious from the beginning, but have little basic electrical knowledge to work with. I've rewired a 1949 Ford, but that was straight forward, wire/fuse, wire/fuse,,,,,,. gcong
Old Aug 2, 2012 | 01:43 PM
Am I missing something? Your battery is being drained and this means it MUST be the radio? What - no need to check anything else, just replace the radio and amplifier for $800 and all will be well?
Or am I not understanding something?
Again - If someone did not get in there and MEASURE THE CURRENT and watch it go to ZERO when the radio or amp was unplugged, you have not proven what is draining the battery.
Take the damn thing to Troup Electronics in Jackson (the Motorola shop) and tell them you will pay their guy Greg Richardson to grab his meter and PROVE where the current is going. Be prepared to pay $95 or so an hour for up to two hours for him to figure this out. THEN you can go buy what you need.
I know Greg personally, call down there and ask him to do it at home for, like $50 an hour!!!
Tell him that Mark in Georiga sent you.
Old Aug 2, 2012 | 03:03 PM
gcong's Avatar
Yo! Pizza Guy! Simply put, they found the location of the fuse where the leak was occurring. Logic (according to Chrysler) says, pull the fuse, problem solved. Thanks for your information about the guy in Jackson!!! gcong
Old Aug 2, 2012 | 04:17 PM
Was it fuse 23 in the under hood accessory block ?
23 for the amp, 5 & 8 for the head unit.
Old Aug 3, 2012 | 08:27 AM
gcong's Avatar
Because I have the 6 spd. roadster, cheaper model, I have a number of fuses missing. 23 is missing and I think this is the one they removed for the short (soundbooster). The rest of them come with the more expensive model (1, 4, 9 12, 13, 21, 22, 24). Number 9 is missing, but I have a horn and I know when I put the car up on jacks for the winter I cannot start the car and an alarm goes off. Number 9 indicates it is for roof light, horn, anti-theft-alarm, trunk light, tire pressure control. gcong
Old Aug 3, 2012 | 12:28 PM
Yea, that's my experience with dealers - for sure.
syfi
Mar 28, 2026 04:14 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
