Multi Tool location
Old Jul 22, 2013 | 05:06 PM
AmysXFire's Avatar
Default Multi Tool location
Sorry guys, I'm at the dealer and I don't ahve a owners manual, what is the location of the multi tool for lowering the top?
Thanks,
Bud
Old Jul 22, 2013 | 05:21 PM
Default Re: Multi Tool location
Thanks,
Bud
You may, or may NOT have that tool. YOU WILL NOT HAVE A 5mm HEX WRENCH, THEY DIDN'T EVER INCLUDE IT, ALTHOUGH IT IS NECESSARY.
Like I said earlier, you need a 5mm hex wrench to release the rear window bow lock, then a 10mm thin open end wrench to release the tonneau cover.
Old Jul 22, 2013 | 05:38 PM
AmysXFire's Avatar
Thanks again. Yep, guess whats NOT there. Guess I'll put out the HELP message to see if anyone local has one so I can get this done. Seen a few in the area, maybe luck will be on my side!
Bud
Old Jul 22, 2013 | 05:42 PM
Bud
I didn't have that tool for the first 2 years I had my roadster.
I did just fine with the 10mm open end wrench - that's all it is, plus a long screwdriver.
Old Jul 22, 2013 | 05:43 PM
AmysXFire's Avatar
I have the drawing, guess its off to the shop to make one.
Old Jul 22, 2013 | 06:19 PM
See thread https://www.crossfireforum.org/forum...gency-key.html
It has a part number and a picture.
Old Jul 22, 2013 | 09:06 PM
AmysXFire's Avatar
Well, after 1.5 hours and a cutting disc, some filing, and a couple of coats of Perma-Blue gun blueing, its all done! Not bad if I do say so, just hope the 10mm cut is ok. If not, nothing a file can't fine tune! Thanks Dad for all the time and skills you taught me!
Old Jul 24, 2013 | 12:06 AM
Indelibility's Avatar
I found mine wedged between the windshield and dashboard on the drivers side. Took me 2 months to find out it was there...always thought it was a reflection from my windshield wiper lol.
Old Jul 27, 2013 | 05:21 PM
TopHydraulics's Avatar
Sponsor
Amysxfire, congrats on making your own tool! Why are you having to use it?
For future reference, Mercedes sells a tool for the W208 CLK-Class that should work very well for the Crossfire: p/n 2088990080. Dealer price ~$20. It looks much like the Crossfire tool with the angled, thin 10-mm wrench at one end, BUT it also has the needed 6-mm hex wrench aka Allen wrench at the other end. Thus, this tool can be used conveniently for both tonneau cover lock and rear bow lock.
Instead of a 6-mm Allen wrench, a T40 star wrench will work on the rear bow lock, as well. Turn clockwise to unlock manually.
Part number references:
Rear bow latch 05142957AA aka A 193 750 0184
Tonneau cover latch 05166559AA aka A 193 750 0183
Folding top rear bow hydraulic cylinder 05142640AA (left side)
Folding top rear bow hydraulic cylinder 05170014AA (right side)
Main drive cylinder 05142639AA (left side)
Main drive cylinder 05170015AA (right side)
Tonneau cover lift cylinder 05142641AA
Hydraulic pump 05142638AA
Old Jul 27, 2013 | 05:57 PM
A
$29.50 from here.
Old Jul 27, 2013 | 06:35 PM
From http://www.jbtoolsales.com/ you can get the 10mm wrench and the 5mm hex for less than $10 shipped.
Old Jul 27, 2013 | 06:58 PM
Sponsor
From Automotive Tools for Sale | Best Hand Tools | Auto Tools Online you can get the 10mm wrench and the 5mm hex for less than $10 shipped.
Awesome. I agree, I would not spend the extra money just to have Allen wrench and 10-mm thin wrench in the same tool. Mercedes makes the special wrench because its angled design works best to unlock the tonneau cover lock on W124 ('93-'95) E-Class convertibles and W208 ('98-'03) CLK-Class convertibles. I don't own a Crossfire - I take it that the wrenches you are showing are thin enough, and that the angle on them is sufficient to grab the 10-mm flat spot on the tonneau cover lock?
Also, please double check - the rear bow lock should require a 6-mm hex wrench.
Klaus
Top Hydraulics | Rebuilt and Upgraded Convertible Top Cylinders, Pumps, Hydraulic Lines - Top Hydraulics, Inc
Old Jul 27, 2013 | 07:15 PM
You sir, are correct : it is 6 mm, NOT 5 mm hex wrench for the bow lock as I previously posted.
I used an old Chinese 10 mm open end for the tonneau lock until I got the top tool from another member.
It was a tight fit, but it did work OK for locking and unlocking.
Old Jul 27, 2013 | 07:48 PM
Sponsor
Default Manually locking and unlocking the rear bow latch
ala_xfire, thanks for clarifying that.
Below is a photo of a rear bow lock to clarify how manual locking/unlocking works.
Everyone, please remember that the hydraulic system is not that difficult to fix if you run into trouble. The original seals in the seven hydraulic cylinders of the Crossfire roadster top have a limited life, but they can be upgraded by Top Hydraulics to last decades longer. The design life of the original seals is ten years.
Every owner of a modern convertible or roadster will eventually have to go through cylinder replacement or upgrade if they keep the car long enough. Cylinder replacement is not really an option on Crossfires, with the parts not being made any more. Upgrades from Top Hydraulics are actually cheaper than new parts would have been, anyway. We have shipped tens of thousands of similar upgrades already for multiple brands - it's routine for us...
Once you see the first cylinder leaking (or notice the hydraulic fluid level being low in the reservoir, which indicates a hydraulic fluid leak), the others will not take long to follow. They all use the same seal material, and its decay is a function of time, temperature, and contamination in the fluid. Removal and re-installation of the cylinders is not very difficult. We are now having more and more customers sending us their full sets of cylinders for upgrade, so that they will not have to worry about it any more and have the car down only once.
Klaus
Old Jul 27, 2013 | 08:28 PM
MoparFreak69's Avatar
Day late and a dollar short here but, I found mine in the pouch on the bulkhead between the seats. It was at the bottom flat against the wall so I couldn't tell it was there until I stuffed my hand all the way down inside looking for a paper I had put in there. Mine now resides in the glove box where it belongs.
Old Aug 1, 2013 | 06:37 AM
kjwinston's Avatar
That is also where I found mine...in the pouch. Blubird did not have one, so we bought one on eBay. Wasn't much and we keep them in the pouch.
KJ
Old Sep 6, 2022 | 08:54 PM
STL06XFire's Avatar
Question Re: Multi Tool location
Does anyone know where may I find a 10 mm open thin wrench to open the tonneau cover in order to manualy close the top?
I left mine in the trunk which is locked /will not open? I live in St Louis, 2006 convertible
Thank you!
Old Sep 7, 2022 | 12:52 AM
UrbanE's Avatar
Thank you!
a bike shop should have what you need
Amazon too, search ultra thin 10 mm bike wrenches.
They might be a lot easier to locate if you guys would finally join the world and use the metric system.
Old Sep 7, 2022 | 11:21 AM
Surely the cheapest way is to get your trunk opened as you will have to do that some time any way.
There are threads devoted to explaining how this is done and starts with the removal of a license plate light and pushing the latch inside the trunk lid. Easy peasy.
Old Sep 7, 2022 | 03:57 PM
Open-Ended Metric Bicycle Wrench, 8/10 mm"><span style=Open-Ended Metric Bicycle Wrench, 8/10 mm" /> Open-Ended Metric Bicycle Wrench, 8/10 mm">Open-Ended Metric Bicycle Wrench, 8/10 mm
papajerry
Jan 13, 2020 06:34 PM
papajerry
May 7, 2019 11:02 AM
ala_xfire
Apr 30, 2018 08:47 PM
sdsantos
Aug 21, 2013 08:39 AM
rivetts
Jun 2, 2012 04:59 PM
