05 Roadster Convertible Top Issues
Old Jul 23, 2024 | 08:26 PM
Default Re: 05 Roadster Convertible Top Issues
Originally Posted by JJFinFla
Another update on the mystery top issue. For review, one evening I had the top down and it stopped working. It would not go up or down. After reading many posts here I checked the voltage at Pin 7 C1 on the PTCM. The voltage went to ground when I undid the D ring.
Pin 16 of C1 is at ground until you turn the D ring, it then goes high (5 to 8 volts is "high"). Pin 7 goes to ground when you pop the top away from the windshield frame IF and only IF the divider switch is also closed (that is, the divider is up and pressing on the switch leaf).
[quote]The windows go down when the D ring is released as well.[\quote]
Proving that the latch release switch is OK, and that the PTCM and BCM are communicating.
That eliminates the divider switch, the Top Release switch and the top open switch from the issue.
I'm not so sure, unless some of your text above is a typo.
Windows going down also seems to eliminate the CLP and the BCM as they are communicating.
No, it eliminates, largely, the PTCM and BCM, but not the CLP/SSM.
I swapped out the CLP with a known good unit and also the PTCM as well. Still inop. I was able to acquire a complete trunk lock and removed the micro switch. First I tested the switch to make sure it opened and closed, then I unplugged the existing switch and plugged this one in both the open and closed positions. Still inop.
So in my diagnosis I believe I've eliminated the:
Top Switch in the header Agreed.
Top Open Switch on the right side of the TOP Not sure.
Trunk Divider Switch
CLP
PTCM
Trunk lock
BCM
Can Bus
If any of these presumptions are incorrect, please advise.
This morning the car threw me a new curve ball! I had the roof down manually and put it up manually (always with the engine running). The light on the dash switch started flashing quickly and for the first 30-45 seconds of driving the car beeped quickly, then stopped. When I slowed down to under the 9 mph limit I got a slow flashing light and a slow beep until I sped up, then every time I went under 9mph it beeped until I finished my trip and shut the car off. This entire time the light on the switch flashed while driving. When I got back in the car a little bit later and started it, no light on the switch and no beeps!! What the heck!
When I got home, I shut the car off and then restarted it and released the D ring. Windows went down. When I hit the top switch I could hear the trunk lock but the roof did not move and after about 2-3 seconds holding the switch down I got a slow steady beep and a slow flashing light.
I seem to have a moving target and it really frustrating. Any direction would be extremely appreciated.
Would my next course of action be the check the voltage at the solenoids at the hydraulic pump?
Sounds like you did not use the tool to lock the lid or rear bow in place.
IT's been a long thread, have you ever tried putting the top down manually and trying to put it UP with the button?
Old Aug 8, 2024 | 01:20 PM
Thread closed
Original member (post) started another thread - SAME TOPIC
05 Roadster Convertible Top Issues Vol 2
Jbr121212
May 25, 2023 03:31 PM
Platterus
Dec 2, 2022 01:06 PM
mrbluesman
May 30, 2019 10:11 AM
150MPH
23
Aug 14, 2018 11:51 AM
xme
May 21, 2014 03:24 PM
