Check Engine Light
Old Sep 16, 2015 | 12:59 PM
  #41 (permalink)
maxcichon's Avatar
Default Re: Check Engine Light
Originally Posted by pioneer4x4
Maybe the air pump is running when it shouldn't and that would cause a lean code, correct? You might have found a cause. Before you pulled the fuse, could you hear it running after initial warm-up?
Yeah, it should only run until the coolant temp gets up a little bit, then shut off.
Old Sep 16, 2015 | 02:06 PM
  #42 (permalink)
jgreen's Avatar
I am not sure what to listen for do you know the location of th pump?
The engine light came on again this morning. I will run the code to see if it's just posting P0410 error. I'll upload the results later tonight.
Thanks pioneer4x4 for your reply
Old Sep 16, 2015 | 02:07 PM
  #43 (permalink)
jgreen's Avatar
Understood. Thank you
Old Sep 16, 2015 | 02:09 PM
  #44 (permalink)
jgreen's Avatar
Originally Posted by waldig
This has impressed the helll out of me, just bought the Bluedriver code reader.........Wow. WOODY
Hi woody,
It's a great reader! If you can please post your O2 sensors I would like to compare my data to yours.
Old Sep 16, 2015 | 02:57 PM
  #45 (permalink)
maxcichon's Avatar
Front, center, top of the engine. It has a lifting ring cast into it.
Old Sep 16, 2015 | 06:20 PM
  #46 (permalink)
pioneer4x4's Avatar
And when I first heard mine, I thought something was wrong, it is a pretty noticeable sound.
Old Sep 16, 2015 | 10:44 PM
  #47 (permalink)
Yea, you can't miss the sound. With the fuse pulled, the car will generate a P0410 or P0401 code (can't remember which and I'm too tired to look).
If that pump runs when it shouldn't, then yes, the O2 sensors are going to see stuff they should not.
Old Sep 18, 2015 | 01:40 AM
  #48 (permalink)
jgreen's Avatar
I now see what it looks like (via the service manual) I will put the fuse in tomorrow and see if the pump stays on.
Old Sep 18, 2015 | 02:06 AM
  #49 (permalink)
jgreen's Avatar
Just a thought.... When the O2 sensors were replaced could they have plugged them in backwards. Bank 1 Sensor 1 is plugged into Bank 1 Sensor 2 on the PCM?
Old Sep 18, 2015 | 08:40 AM
  #50 (permalink)
pioneer4x4's Avatar
Ooooh, if that is it, that would be a great call, it does sound like it could cause his odd readings. I'd have to look and see if the wiring is close enough to reach, have you?
Old Sep 18, 2015 | 08:56 AM
  #51 (permalink)
jgreen's Avatar
I am not excatly sure where to look. I l
Old Sep 18, 2015 | 09:02 AM
  #52 (permalink)
jgreen's Avatar
I am not exactly sure where to look. I looked at the wiring schematic in the service manual but, not sure where to look under the hood.
Could you snap a pic of your 02 sensors connecting into the PCM. I will verify mine matches the same color code.
Old Sep 18, 2015 | 10:57 AM
  #53 (permalink)
maxcichon's Avatar
They are both located right after thier respective catalytic converters.
I doubt the wiring would reach. But I was wrong once.
It was a Thursday, I believe...
Old Sep 18, 2015 | 10:58 AM
  #54 (permalink)
pioneer4x4's Avatar
I'll have to wait till tonight or tomorrow morning to look. Anybody else have theirs handier?
Old Sep 18, 2015 | 11:05 AM
  #55 (permalink)
pioneer4x4's Avatar
Does this help?
And I don't know what color WL is, According to the Service Manual the only thing close is "WT" for White
BR = Brown
DG = Dark Green
YL\BK = Yellow & Black...
Old Sep 18, 2015 | 01:18 PM
  #56 (permalink)
maxcichon's Avatar
White/Lavender
Old Sep 19, 2015 | 12:49 AM
  #57 (permalink)
jgreen's Avatar
Does this help?
BR = Brown
DG = Dark Green
Great schematic thank you for posting it. As for the O2 sensors I wanted to see how they connected into the PCM inside the fuse box. I am not sure if there is a way to miss wire it.
Old Sep 19, 2015 | 01:40 AM
  #58 (permalink)
jgreen's Avatar
At time 377.2, notice how both bank 1 O2 sensors go to 0V, you might have a ground issue, or a short to ground issue. Just a guess, but I have seen an engine harness rub through and cause issues only under full access when it rubbed a certain way, but looked fine under the hood parked.
A weird ground issue may also explain the other sensor going weird. But as you mentioned Bluetooth OBD2 isn't perfect either.
Is there certain areas of the harness to inspect for wear?
Old Sep 19, 2015 | 07:38 AM
  #59 (permalink)
waldig's Avatar
Talking Re: Check Engine Light
You can swap the connectors on the upper o2 sensors, takes some effort to reach. I did it to test something out and it made richer readings but it did run. WW
Old Sep 19, 2015 | 10:53 AM
  #60 (permalink)
jgreen's Avatar
Thank you for your reply. I'll check it out later today.
