Strange transmission issue
Old Jan 1, 2019 | 09:37 PM
sirharper's Avatar
Default Strange transmission issue
Normally my 2004 Crossfire would be in storage right now but I could not find a nearby storage unit the right size so looks like it's staying out this year.
It was a pretty mild day here in Cincinnati so I tried to take it for a spin. Here's what happened:
Seemed to go into reverse just fine and I backed out. Put it in drive and noticed it was in limp mode. Then I noticed the dash gear indicator still said R with the shifter in D. Was still in my neighborhood so I pulled over and tried to put it in Park..it would only go into N and D with the engine running. I turned the car off and was immediately able to put it back into Park. Started the car again and was able to to go back into D still in limp mode. Fortunately I was able to get back into my driveway but once there I again could not put it back in Park until I turned the car off.
Any obvious thoughts? There are no codes being tripped and no fault lights on.
Old Jan 2, 2019 | 09:19 AM
Default Re: Strange transmission issue
I had to limp mode on the same basic tranny in a 300 and it was a sticky solenoid in the tranny electrical plate. Limp mode uses 2nd gear only if I recall correctly.
Old Jan 2, 2019 | 07:00 PM
David M's Avatar
Have you ever changed your transmission fluid? I know it might seem excessive but it is supposed to be changed every 30,000 miles. I made the mistake of not changing it well beyond that interval and my transmission started doing weird things.
Old Jan 3, 2019 | 11:16 AM
The Owners Manual says you should change the tranny fluid at 80,000 miles, which is a much too excessive mileage for sure but 30,000 is too little I would say. Maybe 40 to 50,000 unless you have had trouble with worn mechanical parts in the tranny, or the oil looks burnt.
Old Jan 3, 2019 | 04:01 PM
I did it at 50,000 along with a new conductor plate and Pentosin tranny fluid
Amazon Amazon
smokey847
Apr 16, 2020 10:01 PM
gragonese
May 26, 2017 09:20 PM
Scraper
Dec 26, 2013 10:10 AM
Coyote
Jul 8, 2010 11:38 AM
pdjmwj
Jun 16, 2008 09:47 PM
