Transmission Upgrades
Old Jul 30, 2009 | 10:43 PM
ChuckNorris's Avatar
Default Transmission Upgrades
Came across this site.
IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles
Looks like these parts will work for SRT6's
Old Jul 31, 2009 | 02:02 PM
Moparrbust's Avatar
Default Re: Transmission Upgrades
Don't waste your time with a custom torque converter............they do no good on these cars.
Old Jul 31, 2009 | 10:14 PM
Hadn't planned on it, but I'd like to here more, sounds like you have some experience with it. I'm more interested in diagnosing my eratic shifting problem, I think I have a bad conductor plate(speed sensor) and possibly a broken spring in my tranny. I'm tearing it down tomorrow.
Old Jul 31, 2009 | 10:55 PM
Moparrbust's Avatar
I had/have the first custom built TC for a 6 and it does feel a little different and more "snappy" on the street it yields no gains so far at the track(that have been proven by me or anybody else). There was also a lot of hype about some peoples' "custom super modded TCs that'll knock .5 seconds off your 1/4 et" that have never been talked about again since actually being installed in a car. I don't know about you..........but if I had a product that could actually do what I claimed it could do(once it was actually built)...........I would let you know with some nice timeslips and customer endorsements. I don't know how to explain it but custom TCs don't seem to do anything in a M-B vehicle, maybe it has to do with the ECU/TCU getting pissed off and telling it not to perform any better.
Old Jul 31, 2009 | 11:58 PM
ProjectMayhem's Avatar
Apparently its a TCU issue, these transmission electronically control limit the amount of torque, but i did come across this on the MB board and wondered if some settings were changed on the TCU if you would see improvements, i thought of you when i saw this. Kleemann Transmission Control Upgrades - MBWorld.org Forums
Old Aug 1, 2009 | 04:08 AM
jturkel's Avatar
this has proven useful, though no guinea pigs yet for the M112k motor. anyone wanna try it out?
Transmission solinoids solved all my problems! - MBWorld.org Forums
Old Aug 1, 2009 | 08:02 AM
not to butt in, but this is the first time I have seen this info...I have a friend, retired mechanical engineer from Allison Transmission. Designed M1A1 tank trannies. He is a consultant for Jasper Transmission in Jasper IN right now. If you could give me all the particulars on our little trannies, I could have him research what they could do for us. He spent time in Germany working on their tanks as well, so he may have connections to someone over there as well. I have always wanted a quicker, more firm shirt out of my vert, so I would love to help on this...
Old Aug 1, 2009 | 01:48 PM
So far from what I have read, since the transmissions are totally electronically controlled you have to change the programming in the TCU in order to gain any benefits from mechanical modifications. I'll look into this more when I'm done with my disassembly, I'm about to drop the valve body from mine. I think we need to pull some of the info off the other forums and make stickies on here.
Old Aug 1, 2009 | 02:00 PM
velociabstract's Avatar
Southern Hot Rod has a valve body upgrade that you may be interested in. I've heard of them through LX Forums and SRT Connection. Their website is not up yet but they are known in the LX circles as one of the best in modding our NAGI transmission. Give them a call. (888-big-hemi)
Les
Old Aug 1, 2009 | 02:21 PM
jturkel's Avatar
the solenoids helped people without having to mess with the TCU programming on a CLS55 (M113k) so i can't agree with you fully there.
Old Aug 1, 2009 | 07:42 PM
Yup , I just read that. So far I can't figure out what is wrong with my transmission. I'm not getting any codes, feels like the transmission misshifts and than it will buck after shifting. Downshifts surge twice like letting out a clutch twice in a row. Couple times it has felt like the torque converter has completely locked when coming to a stop. The fluid level was good. There was some brass color in the pan from bushing wear and some fine metal dust. Nothing out of the ordinary. I think if the speed sensors were bad I would get at least a 700 p code. Anyone have any ideas? Kind of got off topic here but I need help!
I'm going to see if the fluid wicked into the TCU in the morning, its the only thing I haven't checked.
Old Aug 1, 2009 | 09:17 PM
BlUEMDsrt6's Avatar
The CLS55 that had the old solenoids was an 02. Some guy with an 04 e55 just tried to change out his solenoids to fined out he already had them stock from the factory. I'm wondering since ours are 05's if we already have the blue top solenoids?
Old Aug 2, 2009 | 01:43 AM
Ringmaster's Avatar
I had an older Benz that did the same thing. It also felt like it sometimes got "hung-up" when shifting and was searching for the right gear. I had
the transmission fluid changed and it solved all the problems.
syfi
Mar 28, 2026 04:14 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
rfourt
Sep 25, 2015 01:38 PM
RacerXofFL
Sep 15, 2015 05:00 PM
