Battery Dead. Should I expect any issues after replacing it?
Old Apr 18, 2011 | 07:44 AM
  #41 (permalink)
Larry Hitze's Avatar
Default Re: Battery Dead. Should I expect any issues after replacing it?
Originally Posted by FP
Rob is sending me a new one. I think I got one that was DOA. In the meantime I was able to recharge my old battery off the car. It starts just fine now, but have the water coolant light on. I don't know if it will go away eventiually. My radio wont power on.
Have any of you had these sympoms as a result of a dead battery?
I wondered about that. Shipping=abuse sometimes.
Old Apr 19, 2011 | 08:01 PM
  #42 (permalink)
Well my replacement battery from Rob came in today, and it fired right up. I still have the issue with the coolant light on, and my radio wont power up. I checked the fuses for the radio and they are fine. I never new we had 2 radio fuses. Anyone have this issue with their radio not coming on after a battery was dead? I will be having all the fluids replaced soon, so I'm sure the coolant light will be resolved, but I'm concerned about my radio.
Old Apr 20, 2011 | 08:38 AM
  #43 (permalink)
FP,
The only thing that comes to mind is to either pull the radio out and unplug it's harness for a few minutes or disconnect the battery for a few minutes. When you re-connect battery or radio, TRY to make it a quick, "clean" reconnection, not a shaky "connect-disconnect-connect" affair that can confuse the microprocessor in the radio.
Maybe when you changed the battery, you made-and-broke the connection a few times and confused the micro-P.
Were either of the radio fuses blown? If so, that does not sound encouraging.
Old Apr 20, 2011 | 10:03 AM
  #44 (permalink)
You just list Nav on your options and mods, I assume that is the factory nav unit. Some other radios need a radio code. There is a fuse on the back of the radio, did you look at that one?
Old Apr 20, 2011 | 11:07 AM
  #45 (permalink)
Mine is a factory NAV. I'll pull the radio out and check the fuse.
Thanks for your help.
Old Apr 20, 2011 | 11:27 AM
  #46 (permalink)
FP,
The fuses in the box are fine.
Old Apr 20, 2011 | 10:00 PM
  #47 (permalink)
Originally Posted by JaneBridges
It fit perfectly. It was a Duralast. I specifically requested the same OEM dimensions. It cost $216.00.
Battery Replacement - Interstate MTP-91 $125.00
A little shorter but works just fine.
Old Apr 21, 2011 | 05:53 PM
  #48 (permalink)
yes sir...I may go this route. The shuryken is dead again...won't hold a charge. I am going to take it up to autozone, and have them test it...if she's dead, then I will put the roadster's in the coupe and buy an interstate for the roadster...not sure what happened, 'cause I do drive them some over the winter and keep a battery tender on them...who knows....Gary, the farm is an Interstate dealer, I will see what dealer price is on that model....thanks...
Old Apr 21, 2011 | 08:01 PM
  #49 (permalink)
The weight of a battery is a sign of how much power it can hold, lead is the weight and the more the merrier.
The more plates in the battery the greater the CC numbers, less plates gives more reserve power storage. That is battery basics 101.
Cheaper batteries may be the same outside dimensions but it is the weight that shows how much less you are getting for your money.
Granted that when you push a car with a light weight battery it is an easier task.
Old Apr 22, 2011 | 04:52 PM
  #50 (permalink)
Granted that when you push a car with a light weight battery it an easier task.
yeah, I know...it's like the motorcycle and the lawn mower, maybe two years if I'm lucky....Rob may warranty it, if not, I knew what I was buying, no biggie.....
Old Apr 22, 2011 | 05:23 PM
  #51 (permalink)
NeedsWings's Avatar
i got ya covered doc. these batteries have fiberglass plates not lead
Old Apr 22, 2011 | 07:23 PM
  #52 (permalink)
All these batteries have lead in them.
Old Apr 22, 2011 | 07:52 PM
  #53 (permalink)
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
The Shiriken has ............:
Shuriken: High Performance Batteries
Old Apr 22, 2011 | 08:18 PM
  #54 (permalink)
IBLUBYU's Avatar
Basically like the OPTIMA battery ..... great for marine use because it can be installed in any position, even upside down. I'm old school ..... the heavier the battery, the more lead, the better .... (at least in most cases).
The Shuriken appears to be a DEEP cycle unit, and as stated in their write up, when properly set up with your regular starting battery, it limits the draw on that unit when powering other things like stereo's, winches, anchor windlasses, and other high draw options. Just my take on it...
Old Apr 22, 2011 | 08:20 PM
  #55 (permalink)
Regardless, Rob, as usual, is all about customer service. This is why you buy from Needswings...Thanks, Rob.....and for the record, he saw my post, I had not contacted him yet, but he took the time to contact me...that just doesn't happen in todays world my friends...thanks again Rob...
Old Apr 23, 2011 | 11:52 AM
  #56 (permalink)
Totally agree. Rob is a true gent.
KDW4Him
18
Sep 1, 2021 05:47 PM
Kodebuster
Nov 5, 2020 04:06 PM
Roty135
17
Oct 11, 2018 10:11 AM
oldvintagedude
Aug 14, 2015 06:20 AM
BrenLW
Aug 5, 2015 04:53 AM
