My P0410 secondary air code fix
Old May 26, 2015 | 11:43 PM
Default Re: My P0410 secondary air code fix
I disbanded the high mileage club when my 116,000 mile car was totaled two weeks ago.
It looks like my NEXT one will have about 33,000 on it.
Old May 27, 2015 | 12:05 AM
Originally Posted by Fla_Xfire_SRT
We got rid of the code by filing the contact points of the relay with sandpaper. They were burned and noticeably looser than the other relays on that board. I would never have known to go to the relay box and pry off the cover if I had not read about it here. Thanks for the tech info. Peace
Once the points have been filed they will not last too long, so be prepared to replace that relay or the RCM.
Old May 27, 2015 | 11:56 PM
Ditto, relay contacts that are exposed to high current do not 'file/burnish' too well. Start looking for the relays (if your able to replace them) or sending the RCM to one of the members who 'refurb' them for the members. 180 is right-on!
Old Sep 19, 2016 | 09:41 AM
ChrisA's Avatar
Will a RCM from a 320 SLK work in a Srt6 Also do you need to disconnect the battery when switching them out?
Old Sep 19, 2016 | 01:01 PM
Yes it will work. It should have the correct number (Part # A 170 545 03 05) but I would check maybe someone made a mistake in the first place so you should try and make sure it is what it is supposed to be.
Actually some other RCM work as well and they have different part numbers.
I would disconnect the battery, maybe not required but better be safe than sorry.
Old Sep 19, 2016 | 02:17 PM
I never do, and DJ ( tighed1 ) never does. Neither of us have ever had a problem.
Just sayin.
But, yes, better safe than sorry anyway.
Old Sep 19, 2016 | 02:36 PM
ChrisA's Avatar
Ok about the battery I hear lots of problems from disconnect batteries
Old Sep 19, 2016 | 05:00 PM
Steve Jr's Avatar
No, lots of problems with not disconnecting battery and working on the electrics by shorting out live circuits, even with the key off.
Old Sep 19, 2016 | 07:21 PM
The RCM contains no sensitive parts, just resistors, a few diodes and relays. Also, the connectors are well covered so "shorting out" anything is not likely.
I yank RCMs all the time with the battery connected. Just about any OTHER electrical work in the car I DO disconnect the battery - just not that.
Old Sep 20, 2016 | 12:54 AM
Steve Jr's Avatar
That's the phrasing, I should have used, sorry!
Old Oct 9, 2016 | 01:57 PM
ChrisA's Avatar
Ok Little help please.. I have tried 2 rebuilt RCM,s but i cant get that secondary air pump to work.. Things I have tried.
Rebuilt Relay modual From DJ.
12 volts straight to the fan it ran
Pushed over the contacts manually while motor was running.. Nothing
Getting scared now..
Old Oct 9, 2016 | 02:18 PM
There is nothing between the relay contact and the + fan pin but the wire and the connector pins at connector A4 of the relay module. The ground for the fan is on the mounting bolt on NA's, not sure about SRT6's but would assume it is a local body ground point.
Meter the wire from A4 to the fan connector for ohms, should be very close to 0.
Old Oct 9, 2016 | 03:05 PM
ChrisA's Avatar
ok this seems strange.. I dont have a OHM meter just my fluke Voltage tester on me right now it does continuity...
Anyway the SRT 6 air pump has 2 wires One Kind of a brown color and a larger black wire both on the same plug.. I ran my continuity tester from pin 4 on the plug. and then to the brown side of the fan plug and got nothing. i then put it in the black side and i had good continuity..
Old Oct 9, 2016 | 03:07 PM
ChrisA's Avatar
One other thing I had thought the brown wire was positive on the fan when i hooked it up to 12 volts yesterday. Could i be mistaken? The black wire is larger..
Old Oct 9, 2016 | 03:38 PM
The brown wire is ground - see the above schematic.
Old Oct 9, 2016 | 07:30 PM
ChrisA's Avatar
Thank you ala
Old Dec 21, 2017 | 12:34 PM
Ricerice's Avatar
Originally Posted by bieber
Thanks guys, it has all worked out well, no P0410 codes after 1000 miles on my repaired RCM. This car is my daily driver, your help gets me to work.
I bought a few relays per your information.
I used the the "W210" (inexpensive) junkyard RCM as a backup during repair of my original RCM without issues.
An aerospace spark-chaser friend changed the air pump relay on my original RCM and re-soldered the "mystery no start' connections (they looked bad under magnification).
I then re-installed my now "repaired" orgininal RCM, stowed the junkyard item as a backup with the spare CPS in the box 'O stuff I keep in the car, and it all seems to be working well.
where can I get relays with out having a 50.00 min cost?
Old Dec 21, 2017 | 01:23 PM
  #38 (permalink)
Ricerice's Avatar
Old Dec 21, 2017 | 02:44 PM
  #39 (permalink)
Are you SURE you want to tackle the relay replacement ?
I can tell you it's not an easy thing to do, I have done 3 and will do no more.
tighed1 will replace it and do all the necessary re-solders for $37, just send him an email at :
tighed1@hotmail.com
Old Jan 7, 2022 | 02:41 PM
  #40 (permalink)
Robster1's Avatar
For those needing to replace the check valve, here is a link to the MB site where you can get an oem replacement for about $15:
https://www.mboemparts.com/oem-parts...lve-0021408460
northwest_crossfire
May 30, 2016 05:19 PM
toob
Aug 19, 2015 07:31 AM
gtjl
17
Jul 22, 2015 06:28 PM
axnguyen
Jul 21, 2015 11:41 AM
Beeker
Jul 20, 2015 03:46 PM
