Supercharger add on
Old May 3, 2020 | 07:37 PM
reb's Avatar
reb
Default Supercharger add on
Curious if anyone has ever installed a SRT supercharger on a non supercharged xfire?
Old May 3, 2020 | 08:31 PM
Default Re: Supercharger add on
This comes up about four times a year - and the answer never changes: "Do it if you want to... but you better have a LOT of money and time..."
I know our search function here SUCKS - so, use Google and just put in "Crossfire Supercharger Modification" and you get all sorts of links right here on this forum.
Probably the best one is this one:
https://www.crossfireforum.org/forum...ercharged.html
Today, you can BUY an SRT for what it would cost to mod your car. And no, I am NOT exaggerating.
Old May 3, 2020 | 08:33 PM
OOPS: TO answer your question - YES. It has been done at least twice.
Old May 5, 2020 | 01:02 AM
UrbanE's Avatar
You’ll need the complete Power train from a donor car.
Unfortunately, it’s not as simple as bolting on a supercharger.
If you want to go faster/ sooner, Pizza guy is right. You can buy an SRT for the price of the swap
probably less
Old Jun 14, 2020 | 06:40 AM
Lord Twaddle's Avatar
I too am curious about this modification, I wouldn’t mind trying it.
I am aware people will say “just buy an SRT6” however that is a lot easier said than done in the UK where they only sold 150 units plus I want to swap my 03 Sapphire Silver Coupe automatic for a Blaze Red Roadster with the 6 speed manual.
They never made a red manual SRT6 so specifically for my desires it would probably be most cost effective to supercharge the engine in a stock red manual than to convert an existing SRT6 to manual and have it painted red.
Old Jun 14, 2020 | 10:06 AM
UrbanE's Avatar
If the issue is availability then you may need to import wrecked unit or at least all the components. The handing of the donor car should not matter
What you CAN NOT DO is to attach a manual gearbox to a SC engine. If you do a search, you’ll find lots of inquiries about this.
I did the swap and I collected all of the parts from 7 wrecks. It would have been cheaper to just buy one complete. When sourcing parts/components it was like buying two cars. Buying one complete donor with have been the easiest/fastest with respect to plug and play. Buy one with a bad back end. The front end is the most critical with respect to power plant and electronics then locate the Rear pumpkin And driveshafts from another
There is a complete car on Cars.com for 8k USD
The component parts for your conversion will easily cost that much
If you can put this together with components, awesome but it’s going to be a large shipping container with parts.
Looking forward to seeing how it goes
If you can dream it, you can do it. It will just take time and money
Old Jun 14, 2020 | 11:11 AM
Can’t the stock 6 speed transmission take the extra 50% power increase? Surely just an updated clutch and some careful driving could preserve the gearbox with a supercharger upgrade.
Also nice Walt Disney quote.
Old Jun 14, 2020 | 11:55 AM
UrbanE's Avatar
Lord Twaddle (great handle)
Mating the manual gear box to the Supercharged engine has been attempted by many members way smarter and far more talented than me and it’s always been a no go.
My understanding is that the ECU for the supercharged engine and TCU had never been set up from the plant to talk to one another. And I believe none of the members (so far) have been able to work it out.
As I had indicated, there are many posts about the swap and the mating of a manual on this forum. but it’s still a really fun ride with an automatic.
if your car makes you smile now, more power, even with an auto trans will turn a simple smile into a Maniacal grin
Anyone who’s tried both versions (NA/SRT) will understand this
hit the search bar, you’ll find several threads. Unfortunately, none to date have been successful
if you figure it out, please share, you’ll have lots of inquiries as to how you pulled it off
we’re always rooting for enthusiasm
If you do decide to go down this road , feel free to reach out. I’ve been down that path. It took a long time but I really like the end result
Old Jun 14, 2020 | 12:06 PM
If I wanted to be ambitious then things get.... messy. Trust me I’ve contemplated squeezing the 65AMG V12 biturbo engine into the Crossfire, so I can be downright insane on a bad day. A supercharger conversion to an N/A V6 is normal for my brain.
Old Jun 14, 2020 | 06:27 PM
CL770's Avatar
Hi
I'm not sure why a supercharger conversion on a manual NA Crossfire isn't possible? I think it would be a great topic for discussion.
This is how I would try and do it:
1. Start with a manual car (a manual car has the pedals, clutch, and its body wiring is set up for no TCU)
2. Fit an SRT6 engine with SRT6 engine wiring harness.
3. Use an SRT6 ECU (coded to cars SKREEM and for a manual gearbox).
Potential issues:
- The bolt spacing pattern on the SRT6 crankshaft may not be the same as the NA crankshaft, there's two different patterns used on M112 & M113 engines (it could be the same but if it isn't just get the flywheel modified).
- You could supercharge the NA engine but its higher compression ratio would limit how much boost you could run (stick with stock pulleys) and make it harder to tune. You'd still need to get the SRT6 wiring harness and all the other parts to fit the supercharger, so I think it's uneconomic.
- The manual transmission coding is an option in the SRT6 ECU, but I've never tried it. The same coding method does however work on the NA ECU and it's tried and tested on manual NA V8 conversions.
Any comments?
Old Jun 14, 2020 | 09:30 PM
UrbanE's Avatar
It sounds like you’re really onto something. Knock yourself out.
Please keep us posted. If you use the search bar you’ll bring yourself up to speed on all of the thoughts and actions on the supercharger issue.
If you can get the manual trans to work with a supercharged engine there will be many forum members beating a path to your door.
Old Jun 14, 2020 | 11:17 PM
CL770's Avatar
Hi UrbanE
I've read quite a few of those old posts. Most responses to people that asked about manual or supercharger conversions were just told to go and buy an SRT6 as it's too complicated or will be too expensive and that the manual transmission wont be strong enough. I can't find any reason why it can't be done! Most of the conversions have been on cars used for competition and have used stand alone ECUs as people have assumed it would be too complicated to adapt the OEM ECU.
I don't plan to try this type of conversion myself as I'm not interested in a manual SRT6, but I've converted 3 V8 Crossfires (NA and Supercharged) and have been involved with the ECU coding of at least two others. I haven't come across anyone that's actually tried to mate a manual transmission to an SRT6 engine, but if someone wants to try, I'm more than happy to help them with the ECU coding.
Old Jun 15, 2020 | 02:32 AM
Originally Posted by CL770
Hi UrbanE
If you’ve successfully done M113 V8 engine swaps and coding, then I have one simple yet ambitious question.
M275 V12 AMG engine swap in a Crossfire, is it possible?
Old Jun 15, 2020 | 03:23 AM
CL770's Avatar
Hi
Not with the OEM ECU and I'm sure there's not enough room in the engine bay (the M113 only just fits).
The M275 V12 uses a Bosch ME 2.7.1 ECU. The firmware for this ECU does not have any setting options for the Crossfire (C193 Chassis) ie. you can't set up the right wheel sizes and chassis codes for the Crossfire, and its likely to have different starting circuitry. The only transmission option available is the NAG 5 speed auto (so no manual transmission).
Old Jun 15, 2020 | 11:53 AM
ANYTHING IS POSSIBLE! Just ask Jay Leno with his electric crossfire... You have the bucks, its possible.
Old Jun 15, 2020 | 11:55 AM
Jay Leno has an electric Crossfire?...
Old Jun 15, 2020 | 12:05 PM
See ( Jay Leno's vehicles - Wikicars ). Car # 17! I don't know if he built it but he owns it...
CROSS_PHIRE
Jan 8, 2011 10:32 AM
TonyLondonUk
Mar 9, 2005 03:01 AM
andrew
Sep 14, 2004 04:55 PM
WesMichaels
Aug 2, 2004 04:50 AM
landho
Mar 23, 2004 09:51 AM
