07 Crossfire overheating!
Old Jan 16, 2021 | 09:33 PM
Jininy's Avatar
Default 07 Crossfire overheating!
Hello guys,
I have purchased 07 XF few weeks ago.
car was running fine, I haven't touched anything yet.
Today when I was driving on highway w some traffics, I have noticed temp gauge was reaching slightly over 50%, which usually stays around 46~8%. I turned on A/C on then I heard fan running and temp went down to normal. I wasn't sure so I tested few times, temp was keep trying to rise if I turned a/c off.
So... heres some Qs need to be ruled out..
1. Does XF uses 2 fans? 1 for cooling, 1 for ac?
2. Assuming XF is using 1 fan, and if fan runs on AC, it means fan and fan module or fuse is all fine.. then what could the problem be?
3. No warning lights lights are on, connected reader to see if there's anything pending, nope.
Please helppppppp
Thank you!
Old Jan 16, 2021 | 10:27 PM
Default Re: 07 Crossfire overheating!
1. No, only one fan.
2 & 3 - just how high does the temp gauge go ?
( I am assuming you have checked the coolant level, right ? )
Old Jan 16, 2021 | 10:33 PM
One mark above half is about right for traffic or at the Dragon. James
Old Jan 17, 2021 | 02:58 AM
Jininy's Avatar
Hmm.. if XF uses only one fan and fan runs fine when AC is on, I guess its not fan motor. Water temp gauges working fine, so I'm eliminating coolant temp sensor. I have checked coolant reservoir, it was in between max and min, I am not seeing any coolant leaking evidence on under tray..
One mark by u mean "orange" line in my picture? it has never gone that high, usually sits at "blue" line no matter how long I've driven the car or jus idling in parking lot for hours. Today it went up to "purple" line, and went down to "blue" as I turn on ac.
Please check attached photo and confirm.
Hmmmmmmm its getting very very stressful now. I can drive with ac on all time to make sure preventing overheat,, but it cant be a solution.. helpppppppp
Old Jan 17, 2021 | 05:08 AM
That is all normal, I don't think you have a problem, but if you want to be sure get TorquePro for your smartphone and
a relevant bluetooth OBDC dongle, or get an ultragauge like I have run for 8 years now.
You can get the ultragauge in non-bluetooth or bluetooth for around $80. I prefer the non bluetooth :
https://ultra-gauge.com/ultragauge/ultragauge_wired.htm
or
https://ultra-gauge.com/ultragauge-blue.htm
Old Jan 17, 2021 | 09:43 AM
dcskmail's Avatar
If you want to be sure everything's good you might want to change your thermostat and flush and replace the coolant especially if it's original . Most vehicles that are + 15 years old probably needs all the fluids change . It's not a waste of money but required service. There is also a products to add to your coolant one is called wetter water which lowers your operating temp maybe 10%. If you have a auto lower temps are better.
Old Jan 17, 2021 | 11:07 AM
Before you wast money ,,here is what u should see,,,,,,, normal or hottest it should be ,is one needle width above the half mark. the fan will or should turn on when needed when AC is on fan is needed. the fan runs at different speeds u may only notice the fan at high speed because at high speed it is noisy ,
Old Jan 17, 2021 | 02:20 PM
Jininy's Avatar
Thank you all!
I'm guessing I'm running bit hot but not overheating so far (w ac off it is fluctuating between 199 and 202 when idling. About needle width above 1/2 mark) I'm planning to take it to shop and get a coolant flush with maybe thermostat change if needed. Upper rad hose felt hot and pressurized so I believe thermostat opens up when needed but just want to make sure. Its still funny that it never went up to this temp. Maybe I haven't noticed or didn't have a chance since I turn on heaters pretty often with ac on? Hmm anyways.. thank you all for your inputs!
Old Jan 18, 2021 | 05:32 PM
zip439's Avatar
Do you trust the "shop" to put in the correct anti-freeze??????
Old Jan 18, 2021 | 07:19 PM
Jininy's Avatar
Lol whats ur suggestion then?
No offense, jus open to different thoughts haha
Old Jan 18, 2021 | 07:23 PM
dcskmail's Avatar
Depends on the shop, I don't trust shops that have kids working on your car but I think you can trust most reputable shops. You can always specify a antifreeze that is a different color than the one that's in your car. I've seen green, blue , orange etc.
that way you know it's been changed .
Old Jan 18, 2021 | 08:21 PM
I would prefer the proper coolant verses what color it is...
Old Jan 18, 2021 | 10:06 PM
maybe this will help https://www.crossfireforum.org/forum...air-shops.html
don't go to a dealer unless you have to.. other members have gone to the ones in the repair shops above and they should give u a discount if ask for and they are suppose to know what top do on the crossfire(same as a mercedes c320 1999 to 2002)
Old Jan 18, 2021 | 10:07 PM
dcskmail's Avatar
Various manufacturers make antifreeze to comply with the specifications for our cooling system . Thus the difference in color
Old Jan 19, 2021 | 10:20 AM
this is true BUT-----BUT from our experience only use the mercedes for c32,,c320 slk32 slk320
Mercedes Coolant/Antifreeze Pink (1 Gallon) - Genuine Mercedes Q1030005 This fluid comes from Mercedes undiluted (100% strength). We recommend mixing this coolant with distilled water in a 50/50 coolant/water mix for most climates, for cold climates you will be better served mixing this coolant in a 60/40 coolant/water mix.
Old Jan 21, 2021 | 10:46 AM
I wonder how many Crossfire's are driving around with an anti freeze that is not recommended and in fact may be harmful to the car.
Why buy something just because it is cheaper than a recommended fluid, I used Zerex G-05, this is yellow. The original fluid was the Mercedes fluid and it was blue. I flushed my system really well and when I looked at the fluid it was greenish, there must have been just enough blue in the system to change the colour, it is now changed to the yellow colour.
The fluid has to have the correct chemical composition and concentration, normally 50/50 to protect the engine, the colour is of no consequence. The coolant should comply with the MB325.0 specification.
Old Jan 21, 2021 | 01:22 PM
Ronman's Avatar
Check/change your air filters. My car runs cooler after I change them so maybe your filters are clogged. I change mine every year.
Old Jan 21, 2021 | 02:20 PM
A lot of the 'specifications' written by manufacturers are primed to lure people into higher priced selective markets in cooperation with car manufacturers. It also 'scares' ppl into taking the car to the dealer to perform services easily done in a DIY environment. Oils, antifreeze, bulbs, air/oil filters, OEM parts vs aftermarket... The list goes on. Just what in a MB engine/radiator cooling system requires only OEM recommended antifreeze? People see an all aluminum engine and rubber hoses mostly. Heater core/lines, same thing. Valves 'O' rings, same? Please lets see what will 'degrade' if a universal grade Prestone is used (either 50/50 or concentrate)? No 'wiki' pages, just a simple question!
xffan
Mar 11, 2015 07:49 AM
Avantidude
Jul 31, 2014 05:45 PM
Robskytoon
U.K.
Jul 2, 2013 05:03 AM
Germany
May 9, 2011 06:42 PM
GNSVO
Jan 18, 2011 10:03 PM
