Battery drain and esp bas problems
Old Jun 3, 2025 | 11:44 AM
chargerwayne's Avatar
Default Battery drain and esp bas problems
In searching for my battery drain problem I found a draw on the rcm fuse for the engine control relay. I opened the module up and the relay contacts move freely. The battery will go dead in a couple days from this. I unhook the neg battery cable at home and make sure the hood doesn't latch.
The esp/bas light comes on as soon as I touch the brakes. If I restart it without brakeengagement and use the cruise control for at least an hour of driving the light goes out ,brake light works, cruise works for maybe two starts and back to esp bas lights.
Old Jun 3, 2025 | 11:53 AM
Default Re: Battery drain and esp bas problems
Do you refer to connector B pin 4? If the relay is not stuck closed, the issue is in the ECU. You can prove this by unplugging connector E, if the current drops to zero, the ECU is at fault.
Automatic or manual? And what year? (There are differences in wiring between 04-06 and 07-08; and manuals are not the same as autos.)
Old Jun 3, 2025 | 12:34 PM
2004 Automatic
Old Jun 3, 2025 | 12:35 PM
Also, many make some mistakes when measuring current in the Crossfire. I wrote the tutorial below to address this.
Make sure you are not fooling yourself....................
File Type: pdf
Old Jun 3, 2025 | 12:36 PM
I was checking power at the fuse that goes to the relay for engine control relay
Old Jun 3, 2025 | 12:38 PM
2004 Automatic
Use the 2005 SRT/Llimited Service manual in your case.
Get it here:
https://www.crossfireforum.org/forum...ollection.html
THis link:
Old Jun 3, 2025 | 12:41 PM
How much current did you have and do you mean fuse 3 of the RCM? It is not powered with the key off, you can't have current there with the key off.
PLease stop making generic statements, be specific as to WHAT FUSE EXACTLY you are referring to and how much current you see.
Old Jun 3, 2025 | 12:56 PM
Yes I checked the third fuse which is for the engine control relay
I reinstalled it and had no current at that fuse. I restarted it and turned it off and had 2 milliamps showing on the fuse with key off. Hunting for this drain has drove me crazy. ( short trip) . a lot of the fuses show miliamps for a second or two then go down to O. I didn't see the link about your electrical tips
Old Jun 3, 2025 | 01:04 PM
Link is in post 4.
And 2 milliamps has to be a meter error:
1) 2 mills is almost always a meter fabrication (it's an artifact of the A/D converter in today's cheaper meaters). With only 2 mills, the battery will last MONTHS.
2) There can be NO current with the key off unless the relay is sticking - replace teh RCM or send it to DJ for reworking in such cases, a stuck relay MUST be replaced before you proceed.
To verify this, measure the voltage at the fuse with key off, if it is not ZERO, yank the RCM and get it fixed or replace it.
Please see the diagrams in the service manual, wiring chapter, under "Power Distribution" and you will see how this works.
Old Jul 3, 2025 | 10:55 AM
drstubb1's Avatar
I'm having the same issue, but we thought our draining issue was a different fuse. Sadly that fix didn't last. Here I am a year later and still getting a battery drain. Did you ever fix your issue permanently?
thanks,
Steven
Old Jul 3, 2025 | 11:19 AM
Have you disconnected the alarm siren?
Old Jul 3, 2025 | 12:39 PM
Yes
RA112524
Aug 7, 2020 04:00 PM
blackpepper
Apr 27, 2017 10:00 AM
revival1
Jun 13, 2011 02:39 PM
rfors777
Sep 1, 2010 04:54 PM
cisa
Feb 13, 2010 05:39 PM
