Stranded! and looking for advice.
Old Aug 12, 2025 | 09:32 AM
luxige's Avatar
Default Stranded! and looking for advice.
Hi all,
I'm in a large parking lot and when I came to pick up my SRT6, the fob will not operate the central lock system. I think the fob batteries are good. When I turn the key in ignition, the dash lights work, also radio and climate fans, but engine does not crank. A few times it started a relay that flashed the corner lights for a couple of minutes. Three or four attempts caused the engine to crank for about one second without catching.
I removed the RCM and looked at the solder connections. They look to be very bright and solid, but I have no way of checking.
No tools on hand, and I'm 165 miles from home.
Any advice?
Update: Tried one more time and it started and is running with a slow, rough idle, about 500 rpm.
Ideas welcome.
Should I try to make the drive home?
Old Aug 12, 2025 | 10:30 AM
Default Re: Stranded! and looking for advice.
My first guess would be the RCM, do you carry a spare as is recommended? Second could be a failing battery. Do you carry a scanner with you to check for codes?
Old Aug 12, 2025 | 08:37 PM
luxige's Avatar
Thanks for your answer, I think you're right about the RCM. Your definitely right that I need to carry some basics and a small tool kit. I'm going on a trip tomorrow, I'll try to figure this out next week. I'll probably order a replacement RCM while I'm away so I can hit the ground running when I return.
Old Aug 12, 2025 | 08:40 PM
Originally Posted by luxige
Hi all,
Any advice?
Ideas welcome.
Go to an auto parts store and see if you can get a relay control module.
You don't need any tools to replace the RCM. Also, you don't have to disconnect the battery.
Here's how to replace it:
LINK - Relay Control Module Replacement
Old Aug 12, 2025 | 09:10 PM
luxige's Avatar
Thanks.
I'll have to deal with it next week, will try to hunt down a module while I'm away. I did take out the one in the car and it looked quite shiny and new, so I'm wondering if it was already replaced once.
Old Aug 13, 2025 | 08:32 AM
Many times the relays wear out or solder joints fail.
Old Aug 13, 2025 | 10:31 PM
Thanks.
You can get one try it. If it solves your problem keep it. You can return it, but I would recommend keeping it a spare.
Also, once you get back, if you can make it to an auto parts store have them use a scanner on your car. If the scanner doesn't read it as a Crossfire, use a 2003 Mercedes-Benz SLK 32 AMG for the scan.
Old Aug 15, 2025 | 05:58 PM
luxige's Avatar
Will do, thanks for the input!
Old Aug 20, 2025 | 01:57 PM
luxige's Avatar
Update, here's a mugshot of the culprits. The relay on the right is just a little degraded if you look closely. Obviously the other one caused the no-start.
I have a new module on the way, and I'll tune this one up and keep it in the car.
Thanks everyone for the help!
Old Aug 20, 2025 | 02:47 PM
Thanks for confirming the issue.
Old Aug 22, 2025 | 01:02 AM
I'm glad that you were able to get the problem resolved.
Old Aug 22, 2025 | 01:29 AM
tighed1's Avatar
luxige
If you haven't already, email me at tighed1@hotmail.com for the info on getting your RCM rebuilt.
For a third of the price of a new RCM I can rebuild your current RCM to BETTER than new condition!
I replace the relays, redo the poor solder joints AND add the Me So Horny mod. Can't get that on a new RCM!!
If the RCM your ordered turns out to be the JD-192Z version (it suks) Squeeze the pins together a bit. This will provide a better connection as the pins are skinnier than original RCM pins and don't make good contact causing issues.
Old Aug 22, 2025 | 04:53 AM
luxige's Avatar
Thanks for the advice! I'll get back to you soon_
Old Aug 22, 2025 | 09:34 AM
Highly recommended
Coedfan
May 10, 2021 02:39 PM
Heytherebeaux
Jul 30, 2020 06:08 PM
acambi
Sep 20, 2019 04:39 PM
Senja
May 9, 2015 02:06 PM
Speedy4x4
Nov 13, 2014 05:58 PM
