Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
  #941 (permalink)
Old 05-11-2016, 02:33 PM
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Hi guys,
I am Polish, and unfortunately caught me exactly the problem. The key, don't turn the ignition. I did everything according to the instructions v5, however, for I can not move the locking pin. Drilling does not give advice ... please inquire something ... This metal is so strong that nothing can move him.
  #942 (permalink)
Old 05-11-2016, 02:46 PM
Originally Posted by Reliableron
Just a note - I did my third one on Monday and it was locked up. I found that 2 of the three I've done were stickiest when it was hot out. The one I did this week was sitting in the sun with the windows up. I opened the doors and then took my silicone lube and put it in the freezer for half an hour, sprayed it in and got the key turned. Luck - yes. Repeatable - maybe , maybe not.... may be worth a try to do it in the morning when it is cooler and remember don't take the key out if it works! I also had a hard time trying to get the tumbler out so I left it in this time and it saved a step - no problems.
Pietia1990...have you tried Reliableron's above trick to get the key to move?
If it works you can skip drilling.
Good luck.
  #943 (permalink)
Old 05-11-2016, 02:52 PM
I do not fully understand ... can you tell me it somehow easier to explain?
  #944 (permalink)
Old 05-11-2016, 03:01 PM
Posts #936 and #940 from Reliableron and Steve Jr.
I imagine English is giving you a problem and, if I could, I'd tell you what to do in Polish.
  #945 (permalink)
Old 05-11-2016, 03:15 PM
Reliableron's Avatar
I tried google translate maybe this helps:
ylko uwaga - Zrobiłem mój trzeci poniedziałek i było zamknięte . Że znalazłem dwa z trzech robiłem byłeś stickiest kiedy to było gorąco . Jedynym Zrobiłem ten weekend siedziałem w słońcu z okien górę. Otworzyłem drzwi, a potem zabrał moją silikonowy lubrykant i umieścić go w lodówce przez pół godziny , spryskane go i dostał klucz odwrócił . Luck - tak. Powtarzalne - Może tak, może nie .... Może warto spróbować zrobić to w godzinach porannych , kiedy jest chłodniej i pamiętaj nie ma klucza , czy to działa! I aussi z trudem próbuje dostać szklankę się więc zostawiłem go w tym czasie i to uratowało krok - żadnych problemów .
  #946 (permalink)
Old 05-11-2016, 03:23 PM
Thank you, I understand, it's probably my last hope I'm optimistic, just spray cooling. I will write you the effects. Regards
  #947 (permalink)
Old 05-12-2016, 05:31 AM
Unfortunately, it did not help ... I have bad luck
edit
I am depressed, I tried another drill and still nothing. At the moment it looks as shown below. Maybe someone have any idea? I bought this car seven years ago, it has never failed me ...
  #948 (permalink)
Old 05-12-2016, 03:38 PM
Hi...I'm a new forum member and recent purchaser of a 2005 Crossfire Roadster Limited (23,000 miles - Sapphire Silver Blue Metallic) and have been reviewing the forum for issues/repairs, preventative maintenance. I've noticed some slight sticking with the key and have reviewed the procedure for modifying the old assembly. I've found a new lock assembly for $116 (Mercedes OEM Part 2024600904)
Mercedes Mercedes Benz 98 04 SLK230 Steering Column Lock Housing 2024600904 | eBay
Would I be correct in understanding the new OEM housings currently being sold don't have the issue that I believe was resolved with the 2007/2008 models? I'd prefer to replace the lock housing assembly then modify and remove the locking pin in the existing one. Is it easy to swap the tumbler and black cap? Does the cap come with the new assembly or does someone know the part number? Also, if there's anyone experienced in this fix in the Atlanta area, I'd be happy to pay them for the sticky key fix.
  #949 (permalink)
Old 05-12-2016, 03:47 PM
Define 'Atlanta area'
I've done 4 of these and I'm 110 miles away.
  #950 (permalink)
Old 05-12-2016, 04:17 PM
Ala_xfire - Linville, AL is within my definition of near Atlanta. Does it make sense to replace the housing with a new OEM one? I'd don't mind spending the money for the housing. I'd like to keep it as close to original as possible (with the exception of the radio that I'll be upgrading to a silver Kenwood marine radio next week. I'll message you directly so we can coordinate my coming out to Linville when it's convenient for you.
Thanks again!!!
  #951 (permalink)
Old 05-12-2016, 04:23 PM
New housing would be your choice, I've never had to replace that.
  #952 (permalink)
Old 05-12-2016, 07:38 PM
Don't waste the money on a new housing. I've done as many as George, never spent a dime on parts.
  #953 (permalink)
Old 05-12-2016, 07:39 PM
Um, George - it looks to me like he is drilling thru the collar that has the bolt in it - am I right?
Maybe if he removes the collar and THEN drills it? Do you agree?
edit
  #954 (permalink)
Old 05-12-2016, 07:48 PM
Mrmiata's Avatar
Haven't been there done that yet.. but this might help.. it's in the PDF..
Edit .. closer inspection of his pic shows where he has been attempting to drill the pin ..
  #955 (permalink)
Old 05-12-2016, 09:26 PM
KDW4Him's Avatar
I recall some posts that reported the brand new part also has the pin and spring so if you did buy new take the cover off to see.
  #956 (permalink)
Old 05-12-2016, 09:43 PM
I'm going to assume the pin is there. Hopefully this is a newer designed version used in the later production year runs that I understand didn't have this issue. Either way, I would expect to not have to worry about the key sticking for 5-10 more years.
  #957 (permalink)
Old 05-12-2016, 09:44 PM
KDW4Him's Avatar
If you remove the pin and spring it won't ever stick.
  #958 (permalink)
Old 05-13-2016, 11:39 AM
Hi guys ,
I succeeded, I'm mega happy, my crossfire alive again! thank you very much for your help, guide itc
Greetings from Poland
Piotr
  #959 (permalink)
Old 05-13-2016, 12:59 PM
Excellent!! Congratulations - now go and enjoy it!!
dennyandnancy (05-24-2021)
  #960 (permalink)
Old 05-16-2016, 09:05 AM
Hi guys ,
Piotr
Cool, Piotr, very cool!
Congratulations.
Quick Reply: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
