Coolant Reservoir Removal
Old Aug 26, 2012 | 02:24 PM
Bear505's Avatar
Default Coolant Reservoir Removal
Ok.. I tried the search function.. No luck.. I'm trying to remove the coolant reservoir enough to get it out of the way of the Passenger Side High Beam Headlight... I need to replace the bulb...
I removed the two nuts that appear to hold the tank in place, but it won't budge. There is a Post on the bottom with a grommet.
Does the tank simply pull off of the grommet? or is there a trick I haven't discovered yet? I've pulled on it hard enough that I'm afraid I'll break the tank... Any help?
Thanks
2004 Crossfire Coupe
Old Aug 26, 2012 | 02:42 PM
Default Re: Coolant Reservoir Removal
I never figured it out. Ended up changing the bulb with it in place.
Not easy, but it can be done. I also find that cutting the webbing between the two electrical terminals makes it easier - that way, you can remove ONE terminal at a time.
Use small, sharp diagonal cutters and just cut the material between the contacts. Look at the drivers' side light to understand where and what to cut.
Thirteendog's Avatar
Thanks
It does pull off the grommet. It's a ***** though to get off.
Old Aug 26, 2012 | 03:20 PM
Bear505's Avatar
Yea it is... I used the old addage, "If it won't move force it... If it breaks, it needed replacing anyway..."
It came off, the headlights changed.. a little WD40 to get it back on.. slid right together like it was supposed to...
Thanks guys for the Reply... Crisis Averted... LMAO
Old Aug 26, 2012 | 07:07 PM
I used WD40 on the post to get it out, eazy peazy.
Old Mar 15, 2026 | 03:58 PM
Kimmy85375's Avatar
I am having the same issue
Thanks
Old Mar 15, 2026 | 04:34 PM
It pulls off the gromet. I would try spraying a little lubricant on it if possible. At this age it is probably i bit brittle. I might even buy a spare, just in case.
https://www.partsgeek.com/catalog/20...sion_tank.html
Old Mar 15, 2026 | 08:11 PM
Spray WD-40 at the grommet under neath the reservoir. Then wiggle it so that the oil seeps into the grommet. Then pull straight up while wiggling the reservoir.
I had a tough time with mine, but eventually it came out.
Old Mar 15, 2026 | 10:39 PM
gblack32's Avatar
I also did this recently and it was a b*tch. Ended up breaking part of one the tabs. Probably should have sprayed some WD on there like people are saying 😑
Old Mar 16, 2026 | 12:43 PM
zip439's Avatar
@Kimmy85375 If your trying to replace the headlight bulb read this headlight replacement
This tool will make much easier and no tank removal:
what ever you are doing, Good Luck!
alexdc
18
Dec 5, 2018 03:03 PM
samo59
Jan 31, 2013 05:52 PM
xxfirerican
Nov 19, 2010 10:19 PM
RIOT
May 25, 2010 03:01 PM
