DIY Rear Cambers
Old Oct 2, 2019 | 12:00 AM
  #61 (permalink)
Default Re: DIY Rear Cambers
Originally Posted by Sussudio
Thank you 180, previous poster said 2 would be ok but 4 would be preferable. Is there a specific reason for that? Thanks in advance
One bolt at each end of the strut equals four required.
Old Oct 2, 2019 | 05:19 PM
  #62 (permalink)
Sussudio's Avatar
Received the rear camber parts set-up. Now I’m just waiting on the front ones that I ordered per 180 and zip439’s suggestions. Ready to be done with the inner tire wear. Thanks again fellas
Old Nov 2, 2019 | 04:28 PM
  #63 (permalink)
Sussudio's Avatar
Well, I’ve got the car at the body shop and my guy is putting may front and rear camber kits on, brakes etc. and look at this doozy he sent me when getting to the OEM rear camber arms.
The top is the worrisome part. It’s the passenger side. I can’t tell what the hell has been done to it. He thinks someone has welded the bolt in or that something is welded together. He won’t know until he gets the bolt out. Can anyone tell what’s going on in the picture? I know it’s kind of hard to tell, but any general observation would be welcomed. Thanks fellas
Old Nov 2, 2019 | 05:31 PM
  #64 (permalink)
zip439's Avatar
It looks similar to what my lower control arm did to the carrier frame on my limited. My lower control arm bolt was torn from it's location when I went off road and hit a rock. Your picture looks as though the camber control arm and bolt was forcible torn outward. You can see the missing metal from the carrier frame bracket. Your shop may be able to fabricate two new side pieces for the bracket and weld them in place. I dropped the carrier frame, bought a used one from junk yard and replaced the complete frame.
Old Nov 2, 2019 | 05:36 PM
  #65 (permalink)
zip439's Avatar
Here is a link to a PDF which will help you understand the front setup on the eccentric bolt install. DIY eccentric bolt install
Old Nov 2, 2019 | 05:59 PM
  #66 (permalink)
Sussudio's Avatar
Thank you, I have this already saved to my desktop🤙🏼
But those pictures I posted are of the rear. Not sure if you knew that or you were just posting this for the front setup?
Old Nov 2, 2019 | 06:27 PM
  #67 (permalink)
zip439's Avatar
YES, I know that the pic is of the rear. I posted twice above. Read both #64 & 65. The rear is totally different than the front.
Old Nov 2, 2019 | 06:36 PM
  #68 (permalink)
zip439's Avatar
That broken bracket is part of the "carrier frame" which is like a hand or claw that is bolted to the body of the car with four bolts. It is not all that difficult to remove the entire carrier frame and replace it. I did it myself with no help, but I do have a lift in my shop, and it does involve some man hours. look at a parts diagram to better understand how it attaches.
Old Nov 2, 2019 | 06:58 PM
  #69 (permalink)
Sussudio's Avatar
Oh ok gotcha, I appreciate that. Thanks for the info. There are a couple of wrecked Crossfires here OKC. I wonder if trying to get that part would be better than fabricating one?
My insurance is paying for all the front work being done to the car. The back work is coming out of pocket. I’ve wanted the camber fixed on the back for awhile now, I’m tired of replacing tires every 10-15,000 miles. In your opinion what is the best option that won’t kill me in the pocket? Thanks in advance
Old Nov 2, 2019 | 11:33 PM
  #70 (permalink)
zip439's Avatar
Best option may be to just leave well enough alone and let the rear end as is, so long as the shop thinks the current welds look good and it is safe to drive. here is a picture of the carrier removed from my car. it may help you make a decision.
Old Nov 4, 2019 | 01:52 AM
  #71 (permalink)
Sussudio's Avatar
He didn't think it was safe as he said if it was his he wouldn't drive his car if it was like that. I talked with him today and he said it looked way worse than it was. He said he's not sure WTH the previous person was trying to do. He said everything is tip top and the rear camber kit is installed. Everything is to the spec that I wanted it to be so no more wearing of the inner tires. Thanks again fellow members I appreciate your input
blackpepper
Dec 18, 2021 06:17 PM
Jonacross
20
Jul 17, 2017 11:19 PM
onehundred80
Aug 6, 2016 12:03 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
