Engine Swap Ideas
Old Feb 20, 2010 | 11:31 AM
Default Re: Engine Swap Ideas
Originally Posted by 70GT6
I need to finish mine... just no time for it....
1800 lbs
Sm chevy (built)
Corvette 6 speed
Corvette rear end
Nitrous (just in case)
now I like that, 1800lbs...wheely bars my friend, wheely bars...lol
Old Feb 20, 2010 | 11:35 AM
70GT6's Avatar
Nothing special in the traction or tire department - so instead of wheelie bars I am counting on "smoke on demand" at just about any speed.
Old Feb 20, 2010 | 11:38 AM
the only thing I had ever done close to this, was put a 454 chevy, 400 turbo auto...left the rear end stock, in a 68 firebird...it would smoke the stock tires just about anytime, anywhere...but if we had tubbed it, put in a narrowed 12 bolt chevy rearend and the big tires....well, I think she would have stood up....nice project....post some photos when done...
Old Feb 20, 2010 | 05:11 PM
Jeep2Xfire's Avatar
Something I'm kicking around is a little more wilder, not power-wise, but I guess from an engineering standpoint??? I've got a lead on a Volvo (Yamaha) V8. It's 4.4L of displacement and 32 valves. Because they're front mounted with a transverse style auto trans, I lose out on my stick. With the fuel tank right behind the seats and acting as a strength member I'd say that a full cage with some sort of integrated cradle for the engine to be laid out like an Audi R8. These motors are wayyyyy de-tuned, because of Volvo's hardon for safety (safe=slow to them) I have to replace a balance shaft in one so the whole motor is coming out and I will be taking measurements while out of the S80.
Old Feb 20, 2010 | 05:38 PM
ZAHANMA's Avatar
I'm still in the early (read: very very very early) stages of planning for an engine swap. Won't be on my current SRT, but most likely ono a second xf I pick up.
I'm sourcicng a 55k motor to put in. Should fit nicely (thanks to already seeing the N/A version go in) So it will all be to tuning and such. Should be a nice swap, however it will be a) about a $25k swap not including the donor car and b) a multi year swap as the plans sit right now...
Can't wait though. Several E55s are running in the high 10s right now. They weigh over 1000lbs more than the SRT. Should me for some fun times. I'm hoping for a 500lb savings when it is all said and done (read: new trans, rear, engine heavier, etc)
That's all I'll babble on about it until I actually get it up and running. Hope to have a donor car and the engine out by the end of this year... We'll see though.
Old Feb 20, 2010 | 05:47 PM
downwardspiral's Avatar
That's alot of money!! Just out of curiousity, what are you factoring into that figure?
Old Feb 20, 2010 | 05:51 PM
ZAHANMA's Avatar
[/font]
That's alot of money!! My buddy is selling an 01 e55 for 13k lol. Just out of curiousity, what are you factoring into that figure?
Maybe I was thinking $25k with donor car... my brain isn't organized today.
It would be engine, trans, custom shafts, rear end, LSD, HSTC, all the modifications to the 55K engine (from '04-'06), tuning time, misc parts, shipping parts, maybe even a custom hood if the XF hood is too low for the 55k motor (I don't initially think it will be though)
Old Feb 20, 2010 | 05:55 PM
that is always the problem with building cars...when I was in my twenties working nights managing gas station, I had access to everything I needed to do the work. I would work the day shift, take a few hours off, then work 6 hrs at the station...so I could get in some work on my days off...you have to do a lot of the work yourself, or it gets out of hand on cost. If you have to hire it all done, well, hell, why not just buy a fast car. Doing it yourself is part of the fun, and the challenge...to build something unique....
Old Feb 20, 2010 | 06:15 PM
lol I was going to say, maybe with the donor car thats reasonable.
Old Mar 19, 2010 | 09:22 AM
ChuckNorris's Avatar
I think I am going to use a Chevy 5.3 and trans out of a truck with a GTO front sump oil pan if it will fit. It has aftermarket support, its extremely affordable, and should get great mileage.
Old Mar 19, 2010 | 10:31 AM
Stogey's Avatar
misc-15.jpg I say if you gonna dream ... DREAM BIG !!!
click to enlarge
Old Mar 19, 2010 | 11:02 AM
Originally Posted by Stogey
Attachment 17222 I say if you gonna dream ... DREAM BIG !!!
click to enlarge
I'm pretty confident that any nelson motor would render any crossfire useless lol.
Chuck- good choice!
Old Mar 19, 2010 | 11:12 AM
rcompart's Avatar
That would be a great choice due to the shear number of parts available for that engine. One thing I thought of was that you're probably going to need to get your car to think it's a manual since you won't have any input from the transmission and that could make the whole thing a bit hairy when trying to get the electronics you're gonna keep in the car from going nuts.
Old Mar 19, 2010 | 04:22 PM
I think the only electrics I am going to keep/modify are the lights, stereo,power windows and HVAC. So no anti-lock brakes or stability control issues if you don't have them. I'm going to install an aftermarket keyless entry and security system as well. All the gauges are going to get replaced with gauges out of the truck.
Old Mar 19, 2010 | 04:37 PM
rcompart's Avatar
You could keep the gauges from the crossfire if you wanted to. just be a matter of fitting the replacements and getting one that went up to 160MPH and was a 270° sweeping face. same with the tach, the fuel and the coolant temp gauges. If you want to keep the stock heater controls, the body control module has to stay. I think it would be really easy to retain most of the electronics you need to keep the cluster if you found a wrecked manual that you could swap out the ECU, BCM, and key fob with. You wouldn't even need to tear the dash apart then, jsut switch the blade of the key with the one from the donor car and you're set. Knock you the CAN signals to the ESP/YAW sensor so you don't have any of that, knock out the dummy lights you never want to see, wire up resistors to the factory wiring for the coils and injectors and then just tap into the new engines timing signal for RPM and run that to the Crank MAG inputs.
Old Mar 19, 2010 | 05:52 PM
sonoronos's Avatar
I'm working on removing and parting out the engine and trans from my 04 Limited coupe and would like to hear some ideas on what to put back in it. I can tell you it won't be Mercedes built or without aftermarket support. So lets hear your ideas..
Hartley Enterprises H1 V8 (400hp @ 10,000 rpm)
Old Mar 20, 2010 | 02:27 PM
tighed1's Avatar
THANKS for making my swap plans sound impossible Rudy!
Guess I'll just take the money I just saved and put it into my Turbo Integra project. Able to beat ANY XF out there!
Old Mar 20, 2010 | 02:58 PM
  #38 (permalink)
rcompart's Avatar
Good luck with that. LOL
Old Jun 4, 2010 | 01:49 PM
  #39 (permalink)
Its time to do a lot of measuring and see what is actually going to fit.
The shifter is way farther back than I had guesstimated. Looks like a manual tranny might be out of the question.
Old Jun 4, 2010 | 09:27 PM
  #40 (permalink)
Bladecutter's Avatar
Ah, to heck with all this talk about Chevy this, or Mopar that.
I say gut the back end of the car, and slip in a Porsche Twin Turbo 3.8 Flat 6 Engine from a 911 GT2.
Then put in the front end drivetrain and suspension bits from a Carrera 4, and have the first AWD Twin Turbo Crossfire.
That would be a worthy, and probably pretty easy project, all things considered, and would make your car unique, and not some cookie cutter Chevy engine drop in project that has been done on everything from Yugo's to Metros.
BC.
