shifter stuck
Old Nov 30, 2010 | 09:33 AM
billybob's Avatar
Default shifter stuck
auto shifter will not move into reverse or park , starts in nuteral moves into drive
Old Nov 30, 2010 | 10:37 AM
Montana Crossfire's Avatar
Default Re: shifter stuck
If you have an owners manual it tells you how to fix it.
What you do is...
There is a little push in door or flap at the base of the shifter plate. Can't miss it.
Put the multitool that should have come with the car in the hole, If you don't have the tool use a phillips screw driver and just push down it will release the shifter.
Old Nov 30, 2010 | 10:39 AM
What you do is...
Something made this happen so check your fuses for a blown one.
This has happened on mine and I remember being temporarily freaked out.
Don't worry but if you don't have a owners manual, get one.
Mike
Old Nov 30, 2010 | 12:41 PM
billybob's Avatar
Thanks for trying to answer my question.
The auto stick is NOT stuck in park.
Upon stopping in parking lot I could not put it into park. It would only go into neutral. I only have neutral and drive. I can't get it into reverse, park or remove the key.
I have read the manuel about the multi tool. I tryed pushing down but it will not move. All the fuses are good.
Maybe it is a brake switch failed but I do have break lights.
Car is a 07 limited.
Thanks
Old Nov 30, 2010 | 05:50 PM
billybob's Avatar
Well I finally got it, maybe.
I checked the service manuel for anything electrical. I tryed the multi tool, again nothing.
Now, I'm getting pissed. After all day trying to figure out what's wrong, so I jerked the gear shift back & forth & it finally came undone. I sprayed with crc down in the hole and hope it doesn't happen again.
I still have no idea why it stuck.
Old Aug 6, 2014 | 09:01 AM
RED DOG's Avatar
I'm reviving this old thread because I have this problem intermittently with my SRT6 rescue roadster. Sometimes when I go to put the shifter up into park, the lever will not move beyond the neutral position. The only way I can get it back into park is to turn off the engine / ignition which frees the lever and I can then put it back up into the park position. It may function normally after that for some time or it may continue to do the same thing for awhile. It's obviously some sort of an electronic lock function that is affecting the shifter. Also this malfunction sometimes triggers the check engine light and puts the transmission into limp mode. Any thoughts on the cause of this problem before I go trying to replace the entire shifter assembly?? I'm going out to check for trouble codes and will update this post if I find anything.
Old Aug 16, 2014 | 08:01 AM
RED DOG's Avatar
Just posting a follow up to close out this issue I had . . . I ended up replacing the entire shifter assembly. All good now.
Old Aug 16, 2014 | 08:16 AM
This is a problem with the adjustment, see manual.
I guess you are golden now though.
Old Aug 16, 2014 | 09:10 AM
RED DOG's Avatar
Thanks for your follow up . . . Yes I did read about adjusting the lock out solenoid in the repair manual. After much diagnosis [and pulling the trouble code P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)], I don't think that was the issue as the shifter was sending out randomly incorrect position signals. (ie like when the shifter was in park it was would display "R" on the dash indicator etc.). I think the previous owner had accidently spilled some liquid into the shifter at some point. I found a replacement shifter assembly for only $145.00 delivered to my door so rather than continuing to mess around trying to fix or adjust the shifter I just replaced it (kind of the same way they fix things at the stealership) . . .
Old Aug 16, 2014 | 09:17 AM
Thanks for your follow up . . . Yes I did read about adjusting the lock out solenoid in the repair manual. After much diagnosis, I don't think that was the issue as the shifter was sending out randomly incorrect position signals. (ie like when the shifter was in park it was would display "R" on the dash indicator etc.). I think the previous owner had accidently spilled some liquid into the shifter at some point. I found a replacement shifter assembly for only $145.00 delivered to my door so rather than continuing to mess around trying to fix or adjust the shifter I just replaced it (kind of the same way they fix things at the stealership) . . .
That was the best thing to do in this case. Unfortunate.
Old Mar 9, 2020 | 12:59 PM
eddibinder's Avatar
your post helped 10 years later - thanks
Old Nov 9, 2021 | 04:34 PM
Loversandnerds's Avatar
Helped me too. I'm sitting in my car typing this wondering if I should sell my 05 srt 6. She keeps having issues that are so random. I'm dealing with this shifter situation and after checking fuses, changing bulbs and relays for my brake lights they randomly come on when I went to move it for service... it's like one magical issue after another but I love to here it purr when she starts up.
Old Nov 10, 2021 | 09:35 AM
zip439's Avatar
In reference to your brakes. There are two switches on a SRT6: one is near the top of the brake peddle under the dash and another is on the master brake cylinder under the hood. Either one could be acting up. You should get a good scan that will get into the Mercedes codes. It may even turn out to be the CAB module.
Old Nov 10, 2021 | 09:13 PM
nemiro's Avatar
If you get stuck, I have three shifter assemblies sitting on the shelf.
Old Aug 1, 2024 | 02:59 PM
Bzak1pgh's Avatar
I know this is old...but do u still have a shifter assembly fir 05 Chrysler Crossfire base? If so, how much?
Old Aug 1, 2024 | 11:54 PM
You would probably be better off sending him a PM.
Old Aug 6, 2024 | 09:36 AM
What the other guy said, PM him. He's our new "fearless leader" for the Fall event in the Carolina's so he DOES check in here, but right now he's really busy getting ready for the BIG MEET!
deerhunter
Jan 16, 2021 10:56 AM
LE Cross
Oct 17, 2016 06:35 AM
Selbyl
Sep 22, 2015 09:31 PM
Big Daddy
Sep 10, 2015 10:21 PM
chturner
Aug 23, 2015 06:14 PM
