No power to convertible top hydraulic pump
Old Nov 8, 2021 | 04:11 PM
MCPO's Avatar
Default No power to convertible top hydraulic pump
Dealer told me I needed a new module. I ordered on on Bay and it doesn't work either.
The pump doesn't appear to be getting any power. Any ideas out there???
MCPO
MINNESOTA
Old Nov 8, 2021 | 04:48 PM
Default Re: No power to convertible top hydraulic pump
What happens when you unlatch the top, do the windows go down? When you push the button, does it flash red? Are you sure the divider is seated on the trunk? Dealers do not know these cars. Did they buy and install the module?
Old Nov 9, 2021 | 10:55 AM
MCPO's Avatar
Thank you ZRacer.
Windows don't go down
Red light blinks and beeps
Divider is in place
I installed the new module and no response.
Thepump is not responding
The dealer charged me $287 to troll me it was the module.
Very frustrated
MCPO
Old Nov 9, 2021 | 11:31 AM
If the windows don't go down, it sounds like the sensor mounted in the windshield header has gone bad. The TCM is not being told the top is unlatched so it will now allow the pump to function. Do you know how to operate the top manually?
Old Nov 9, 2021 | 10:10 PM
Divider is in place
There is not enough information here to give you any advice. But your statements do raise questions.
1) What module did you replace? (The pump assembly? The Power Top Control Module?)
2) Does the light flash or stay on all the time or just when you turn the "D" handle? (If it's on steady all the time, the cycle probably did not complete the last time the top was moved, resync of the top often fixes this. If it blinks constantly, it is an indication of "major error", this is often an issue with the CLP-SSM (Central Locking Pump/Security System Module).
3) I'd remove the trim from the entire trunk, inspect for water intrusion in the passenger side wheel well - is the CLP-SSM OK or has it been wet? A wet CLP-SSM will disable the top and cause all sorts of odd indications. The last two non-working tops I managed to fix were not issues with the top at all, but were caused by water-logged CLP-SSMs - most dealerships have NO CLUE what to do or even what to look for.
You took the car to a dealer and spent money that got you no where, this is typical.
If you can find a Mercedes dealer that will work on the car, you are fortunate. If you take the car to a Chrysler dealer, they are not going to be able to diagnose or fix anything more than a flat tire or dead battery.
See my siglines and don't do that again.
TO RESYNC THE TOP:
Follow the instructions in this video and do the procedure THREE TIMES, fully, including the Hex Key. Have the engine running the entire time.
Old Nov 10, 2021 | 07:44 AM
MCPO
MINNESOTA
Thank you ZRacer.
Divider is in place
Very frustrated
MCPO
pizzaguy IS the word on the convert top system in the forum. Make sure you follow the steps CAREFULLY, if you have any trouble come back in and let him know. His advice on Chrysler stealerships is gospel, they will bleed you dry before they beat you down & then offer to buy your car towards a new car. I would stay away from them. There is an alternative to a MB service department (since most of them snub their noses at you, bad divorce after the XF was produced/sold), an independent European car shop that has experiences with MB's especially the SLK 320 series cars (the basis for the XF). Download the service manual (and the owners manual if you don't have one) from here in the forum. Also, if your inclined to 'self-help' a lot (or just curious), the search function is your friend (many use the google search, they say it works better). Good luck!
Old Nov 10, 2021 | 03:41 PM
MCPO's Avatar
PIZZAGUY,
I think we may become close friends as I try to get my Crossfire top working.I just put it winter storage at my next door neighbor, but I can access it at any time. My big problem is I don'y know how to check the relays and switches to see if they are working. Can you recommend a scanner for the crossfire and directions on how to use itI like you Chrysler Stealership comment. They have no idea on how to service a Crossfire. I could bring it to a Mercedes Dealership, however I like the challenge of doing it my self with help from guys like you.
All suggestions are welcome.
MCPO
Old Nov 10, 2021 | 04:20 PM
Mercedes dealerships usually will not work on Crossfires. Your best bet is an independent shop that works on Mercedes. The top, not so much.
Old Nov 11, 2021 | 10:01 AM
MCPO's Avatar
Thank for all of you great suggestions.
I'm trying to go one step at a time.
I know that the windows don't go down when I open the "D" lever and lift the top part way. The swittch on the console used to blink red and beeped. Now there is know red light or beeping.
Also, when I got the car the spoiler button worked, now it blinks red and nothing happens. It does engage while driving when I hit 62 mph.
I read that the spoiler malfunction could affect the top malfunction. I know how to check all the fuses but not sure how to check k switches, sensors and relays.
Losing sleep at night!!!
Old Nov 11, 2021 | 12:31 PM
Dont skip over what I said, get in there, unplug every connector from the CLP-SSM and look for corrosion/water damage.
Old Nov 11, 2021 | 12:34 PM
MCPO
The STAR Diagnostic tool that dealers had at one time, emulators can be found on eBay for around $3500, this is about the only option I know of.
DTC readers don't help here, because the top system is not part of engine management or emissions control.
Old Nov 11, 2021 | 02:13 PM
MCPO's Avatar
Thanks pizza guy.
hemi135
Nov 12, 2021 03:48 PM
Newbie 2
Sep 1, 2019 10:18 PM
Waterwren
Jun 5, 2019 02:06 PM
Cobrasrt8
Oct 21, 2017 10:30 AM
autumnmass
Apr 27, 2011 11:42 AM
