Centre Console
Old Jul 29, 2010 | 03:44 PM
Black03AR's Avatar
Default Centre Console
Could anyone please tell me how to remove the silver centre console trim by the handbrake, the piece where the eletrice mirror switch is located. The piece on mine is severely chipped. I have managed to prise off the front part with a flat screwdriver but something seems to be holding the panel in place towards the rear where it ends and the storage compartment piece takes over.
Old Jul 29, 2010 | 04:24 PM
cassidyrj1's Avatar
Default Re: Centre Console
You have to take out the center console. There is two bolts in the cubbie in the back and I think two more under the plate where the shift **** is. Then there are screws that hold that silver trim on.
Old Jul 29, 2010 | 04:27 PM
Black03AR's Avatar
The piece with the cup holder in it. Just the top silver trim. I'm going to trim it in leather if I can rfemove it without breaking it.
Old Jul 29, 2010 | 04:37 PM
He's just told you how it comes off, take out the whole console and remove the screws in the back face of the silver trim.
Old Jul 29, 2010 | 04:55 PM
ZORRO's Avatar
Two screws from the underside of console hold that silver part on. To get to these, pull the handbrake cover off (Dish soap and a butter knife) and remove the screws under the carpet inside the console. Also two screws holding the console together, just in front of the part you want to remove. If you have the silver part from around the shifter (with the window buttons) out you can see them. Just lift the console straight up a little and pull back. The console just hooks together with four tabs. The wires have enough slack so you can get at the screws you want by turning the console on its side. You will also have to unplug the mirror switch. If you have a cup holder this is the time to get rid of it! The silver part your after has two tabs sticking straight out of its front and two more sticking straight down at about the front of the cup holder plus the two screws mentioned above. Sounds hard but it's not, just go slow and do not force anything.
Old Jul 30, 2010 | 03:14 AM
Black03AR's Avatar
Thanks for your help guys. I will do this tomorrow and post pics!
Old Jul 30, 2010 | 11:58 AM
cassidyrj1's Avatar
I dont think anyone metioned pull the ebrake up before you try to take the console out.
Old Jul 30, 2010 | 12:33 PM
Getting the piece out from around the shifter can be tricky. (This is the part that the window switches are in). There are two screws under that, and there are two screws in the lockable storage thingy at the back, under the little piece of carpet. Taking those four screws out, and using the above advice on how to take the e-brake handle off (See Zorro's post) will get you ready to remove the console.
IF you are concerned about scratching anything, have at least one think towel ready to cover the shifter area after you pull the console up and forward, over the e-brake handle. There will be an air hose attached to the lock mechanism for the storage compartment, gently pull and twist it until it comes off. You can unplug the mirror switch harness (and if it's a Roadster, the top button switch harness) and pull the whole thing out to work on out of the car.
On an automatic, you remove the little trim piece from around the shifter first, then pop up the remaining trim from inside the shifter opening at the back. It then lifts out.
I THINK removing that piece from around the shifter in a 6 speed would be even easier - but unsure since I don't have a 6 speed. Seems like you could just stick your fingers down at the back of the shift boot and pop the piece free like you can in an auto once you get the little trim frame out.
Old Jul 30, 2010 | 12:42 PM
Larry Hitze's Avatar
Here is a few pictures that might be helpful.
Old Jul 30, 2010 | 01:05 PM
They are worth a 1,000 words, Larry.
SO... is removing the trim from around the 6 speed shift easy? Do we just pull up like with the auto?
Old Jul 30, 2010 | 01:08 PM
Pizza, I thought that it was extremely easy. I changed out the cupholder for a storage bin in about half an hour never having had any of that apart before. It took me longer to figure out how to post those pictures.
Old Jul 30, 2010 | 01:11 PM
The piece around the shifter just popped up, I used a piece of hard wood so not to scratch it, but a soft touch with a small screwdriver with no sharp edges would do the trick.
Old Jul 30, 2010 | 01:33 PM
Well, with the auto, I WORKED AND WORKED to get the LITTLE trim piece off around the shifter so I could pry up the other part!
I guess the stick IS easier.
But I also didn't know the Roadster console had a lock hose on it. Scared me, thought it was part of the top controls - I didn't know I had pneumatic locks. If he has a Coupe, no air hose to deal with.
I want a Coupe!
Old Jul 30, 2010 | 01:35 PM
I forgot about that air hose, mine doesn't have it so my brain failed me.
Old Jan 27, 2018 | 07:28 AM
ccoverley@aol.com's Avatar
Thumbs up Re: Centre Console
There are at least three operations, probably more than 3
Changing the mirror stitch
Replacing a broken cup holder
Replacing the cup holder with the small bin
I have just changed the cup holder for the small bin
Mine is a manual
Pull the gear stick cover up (not off)
Lever up the gear stick surround
Undo the two Phillips screws which appear
Pull the back end of the storage bin carpet up to uncover two 10 mm nuts
Remove the gear stick rubber sleeve - it will come off, just a bit tight, use WD40 or other to loosen if neccessary
Move the centre console vertical and then you can do whatever it is you want to do
Old Jan 27, 2018 | 10:11 AM
Mine is a manual
Always look at the date of the post you are answering, this one is 7 years old, so I guess the problem has been long solved, probably sold the car as well.
For your interest there is a PDF on how to do his. CLICK
Old Jan 12, 2021 | 05:42 PM
Benzin's Avatar
Hi,
Can anyone tell me where I can buy the front right turn signal? I am unable to find it.
Old Jan 12, 2021 | 05:52 PM
Originally Posted by Benzin
Hi,
Hi, are you looking for a 'bulb' or the headlight assembly? Your post is kind of uninformative and not related to the OP post, to say the least, it seems. What does this post has to do with a console, exactly?...
Old Jan 13, 2021 | 12:46 AM
Benzin's Avatar
Apologies. I made a mistake. I was in a thread on spare parts but changed to this don't know how.
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
55chevy
Sep 13, 2015 07:38 PM
davidc90
Sep 6, 2015 10:37 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
