Quick Mods for Performance
Old Feb 15, 2013 | 12:40 AM
  #61 (permalink)
klb.kenneth's Avatar
Default Re: Quick Mods for Performance
The SRT is way faster straight out the box, with no CAI needed.
But then you just have a stock SRT ... It isn't all about speed. I thnk that something that is fun to play with and that can stand out is much more impressive (unless you are just trying to say you have the lowest number on the clock).
Originally Posted by Mrmiata
I have to agree.. "IF" fast as you can go is priority one.. the research should have been done before the purchase.. "if" you had a cherry 5,000 mile roadster you stole from someone.. Okay.. I could see the upgrade list route.
I got the car with under 6k miles and in perfect condition for $19k out the door (including all tax, tags, fees, and 6 oil changes). They are selling crossfires with more miles and poorer condition for quite a bit more than that, and the SRTs I have seen have significantly more miles on them.
Originally Posted by Airscape
Your list is a bit expensive, there are alternatives you could do.
I wouldn't consider it too expensive. If you take off the brakes, it is about $2,500 total. The brakes are definitely pricey, but would be nice to have a few months down the road.
Sprint booster... I'd say waste as well but others swear by em. For that price and 0 HP gain it would not be high on the list. I just do the throttle reset regularly. Tune should help with pedal response as well.
For a couple hundred, it seems like a fun toy to have. (if nothing else just to change the color of the light! )
ANSA won't get any gains other than noise level.
That was the whole point of that one, and cheaper than a MagnaFlow system.
Old Feb 15, 2013 | 08:50 AM
  #62 (permalink)
rayth's Avatar
Of your list, the dual Needswings CAI will be a good upgrade along with the larger throttle body (just the throttle body, no need for the MAF sensor or housing as long as you do the upgrade together with the CAI which would make the most sense.. do get the O ring though), though the larger filters probably aren't needed since you'll have more air than your car will be able to do anything with...
I second the sentiments on the brakes... if you find a kickass deal somewhere then that's cool but you probably won't need to go too crazy since you won't be making SRT levels of power or anything. In fact, a nice set of slotted/drilled rotors and better pads would probably work fine. Again, I can appreciate wanting to go all out but at most I would say get some SRT brakes when someone else upgrades or wait for a smoking deal on the other brands... Personally, I am not going to touch my brakes until I upgrade my suspension/wheels/tires and get nice and low
And as others have said, the eurocharge tune comes with the cable already
Old Feb 15, 2013 | 12:54 PM
  #63 (permalink)
If the turbo or some other magic happens down the line we may be able to hang with the stock SRT crowd but visions of more than that will require swaps or many many more dollars.
I see some posts a couple years ago about a drop in supercharger for the N/A, but all links are dead now, and cannot find anything of the like. Is there something like that out there?
Old Feb 15, 2013 | 01:06 PM
  #64 (permalink)
Airscape's Avatar
Kleeman used to have a SC option for the NA m112 but they don't provide it anymore. The cost was pretty rediculous and the power was still not SRT level. If you search for kleeman you can find all the info on it. It's just a tease at this point though, even if it still existed you could basically just buy a second crossfire (srt) for around the same cost.
Current day, NA v8 swap is your most economical option beside getting an SRT if you want power. Mating to a stick has not been done stateside that I am aware of though but apparently they have figured it out in Germany.
Old Feb 15, 2013 | 01:11 PM
  #65 (permalink)
rayth's Avatar
You might be referring to some of the gimicky fans that attach to your intake which pretty much do nothing good.. there's no easy HP unfortunately
Old Feb 15, 2013 | 01:35 PM
  #66 (permalink)
Everything on their site looks to have ridiculous prices on it.
Old Feb 16, 2013 | 12:29 AM
  #67 (permalink)
So here is the list ... Tell me if I am missing anything.
· Tint ( I just need to get this done!)
o Side: VLT 28%, Reflect. 25%
o Rear: VLT 15%, Reflect. 35%
· Oil Catch Can (Recommended by Rob)
o NeedsWings Crossfire Oil Catch Can Kit $127
· sprint booster
o Chrysler Crossfire SprintBooster $290
· ANSA Muffler
o 03-up Chrysler Crossfire Mufflers from ANSA at Andy's Auto Sport $212
IMO these things do nothing for the performance aspect but you can have quite a difference in the definition of performance than what I have.
Old Feb 16, 2013 | 10:47 AM
  #68 (permalink)
Default
Yea, but each has its reason.
-Tint is so the car isn't so hot in the Florida sun
-Oil catch helps keep the engine cleaner
-Muffler is just to sound better
-Some people swear by the sprint booster, if nothing else it is a button to play with.
Old Feb 16, 2013 | 11:28 AM
  #69 (permalink)
Higher amounts of $ have been spent everywhere for the 'touchy-feely' variations of the loose definition of 'performance' enhancements. BTW the sprint booster only makes the pedal travel output faster, it does nothing else, it is just a sensation-al reaction to the more sensitive pedal. And of course the mods peeps do are entirely personal and not up for anyone else's justifications/criticisms.
Old Mar 2, 2013 | 07:09 AM
  #70 (permalink)
RED DOG's Avatar
I have had my 2008 Crossfire for about a year, and it has just over 19k miles on it. I am wanting to start doing some mods and make it more of a performance car to play with now that I have been using our Optima more for everyday driving. Personally I won't be doing the work on it, I am going to have someone else do them. I also don't plan to do everything at once.
So, what are some quick mods to increase performance to start, and then what are some more detailed things to do? Also, how much are they going to cost? I don't mind putting a significant amount of money into my car, but just want an idea of how much it will cost.
Here's your best bang for the buck mods . . . See if you can do an even trade / Your 2008 coupe for this 2005 SRT6 coupe . . . GOOD LUCK
Chrysler : Crossfire SUPER CLEAN in Chrysler | eBay Motors
Old Mar 2, 2013 | 08:53 AM
  #71 (permalink)
Abaton6's Avatar
If I had one of these, I would be in jail, or depending on self propelled transportation in very short order. See, having a NA XF, I know it's limitations. I like it very much, but I know it's not the fastest horse in the stable. I would definitely be in trouble with an SRT6. And I'm 60.
Old Mar 2, 2013 | 12:30 PM
  #72 (permalink)
Mrmiata's Avatar
Yeah while your at it why think small.. you can try for an even trade...
Horsepower: 1,200
Old Mar 2, 2013 | 11:41 PM
  #73 (permalink)
JEFASOLD's Avatar
Horsepower: 1,200
On the other hand, a good SRT6 with good shoes will out corner that 2 ton behemoth by quite a bit and they go for 2,285,000 LESS
Old Mar 3, 2013 | 12:00 AM
  #74 (permalink)
Mrmiata's Avatar
And how much straitaway to be passed and history in the six? And what is the skid pad number on the six.. 1g?
The all-wheel-drive system keeps the rear end stable, but it will come around if you aren't careful. Giant run-flat Michelin tires—P265/680ZR-500A up front and 365/710ZR-540A at the rear—provide excellent grip on dry and wet driving surfaces. And, by the way, a set of these goes for $35,000. The suspension—upper and lower A-arms front and rear—features titanium springs that help provide excellent stability and an even ride. If the Veyron has a weakness, it's through quick left/right transitions, where its mass becomes its nemesis. Still, the car managed to run through our slalom in a more-than-respectable 69.6 mph. Around the skidpad, the car has few equals as it registered a neck-wrenching 0.99g.
Weight is hardly an issue as the car sprints to 60 mph in a scary-fast 2.5 seconds, - See more at:
2011 Bugatti Veyron 16.4 Super Sport Road Test - Road & Track
Old Mar 3, 2013 | 12:26 AM
  #75 (permalink)
JEFASOLD's Avatar
I would think with some spacers for a bit wider stance and over sized rubber it would pull 1.01 to 1.02 and yes the Veyron does OK on the skidpad but as it says transitions are it's weakness which seems to be the roads I drive on. None of them go in a circle. The CF's are very nimble. Also, I couldn"t afford more than 1 Bugatti. LOL
Old Mar 3, 2013 | 12:28 AM
  #76 (permalink)
Mrmiata's Avatar
Your up on me then.. second note on the house just for a change of tires! LOL.
Old Mar 3, 2013 | 12:30 AM
  #77 (permalink)
Mrmiata's Avatar
Maybe we should just focus on what we have and are dealing with instead of shoulda coulda wishes.. IE.. thread back on track kinda thing..
syfi
Mar 28, 2026 04:14 PM
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
