Engine lost power
Old Sep 16, 2019 | 12:35 PM
droopaloop's Avatar
Default Engine lost power
Driving on a two lane road, I went to pass a car. Down shifted to fourth and floored it. While passing the crossfire losses power and has a bad vibration from the engine when the accelerator is pressed, it kind of felt like one side of the engine wasn't firing. I pulled off the road and when it got to idle speed it shut off. I checked the engine to see if there were any obvious breaks and/or loose connections. I didnt see anything and went to restart it. It fired back up normally and i was able to drive it just fine afterwards. Kind of thinking coil packs have a bad connection or they are going bad themselves. Any thoughts?
Codes pulled after : p0128, p0410, p0406, p0174, p0171.
Also i changed gears and the vibration happened in 2nd and 3rd gears so it is unlikely it is clutch or transmission related.
Old Sep 26, 2019 | 04:42 PM
Vilse.se's Avatar
Default Re: Engine lost power
Sam problem bump
Old Sep 26, 2019 | 07:00 PM
Do a google on those codes, enter each one, one at a time, into google like this:
"Mercedes P0128" and it will draw you a picture of what the ECM sees. Ignore P0410 for now, that's the stupid air pump, it very likely has nothing to do with your complaint. Indications are of a too lean burn, misfire on cylinder 6, and the engine is operating below normal temperature. If you got on it with the engine cold, ignore P0128.
I'd suspect MAF, Throttle body, MAYBE plugs (if you are over 80,000 miles, change the plugs and plug wires, made tremendous difference in my Graphite and I had the last three codes plus 400, 401, 403, etc.).
Old Sep 27, 2019 | 07:23 PM
zip439's Avatar
BMO,, just corrected this exact problem with a new set of plugs and wire. BE CERTAIN YOU ARE USING THE CORRECT PLUGS FOR YOUR CAR! This is no place to go cheap. BMO had his plugs and wire replaced by a garage and with only 20,000 mi he had this exact problem; loss of power and throwing misfire codes. Get the correct plugs, gape them at .040 There is a tool available that makes removing the plug wires a lot easier. I think I bought mine at ebay ; JTC auto tools 1308 or search for Mercedes spark plug boot puller.
NOT saying this IS your problem, but it corrected the same problem on others cars.
Old Sep 28, 2019 | 08:32 AM
Vilse.se's Avatar
Doing 110 km/h and engin lossless all power and no trottel response doing the quick maneuvering to the side of the rode and engine kinda stalls whole dash lights-up.
Turn ignition off and putting in park, re starts and the hole car is sakes very bad, sounds bad only working 2 or 4 cyl.
Panicking tutn off and restarting sam result and no trotted response.
Putting in gear and car barley moves forward trying to go fore the highway exit 500 meter when 100 meters left all cylinder wakupp and no sign of problem.
No engine light nada.
What could be the problem.
Haven’t checked OBD yet.
So far i have got tips it might be:
CPS = changed a 2 year ago non Borch Likley
Bad fule= probobly not 1/2 full tank
Fule pump = expensive not so likley
Throttle Position Sensor
RCM = K40
Old Sep 28, 2019 | 08:39 AM
Toolman's Avatar
I recently bought another Crossfire. My son drove it home and he told me he had similar problems trying to keep up with me on the highway. Testing it myself at home, I found when I would aggressively accelerate and hit 3,000 RPM the engine would actually stop running. I put one of my scanners on the car and it was showing a number of strange codes which I was suspect of. The seller mentioned changing the Crank Position Sensor. I decided to install another one. I found the seller had not installed a Bosch CPS. I installed the Bosch sensor and it fixed the problem.
Old Sep 29, 2019 | 04:51 PM
Vilse.se's Avatar
i hawe orderd a new one
Old Oct 9, 2019 | 08:41 PM
droopaloop's Avatar
I have not had an opportunity to try and replicate the issue but i will try to and also do the fixes and report back.
Old May 8, 2020 | 02:21 PM
droopaloop's Avatar
The issue happened again today. This time the engine still had issues after restarting it. After popping off the engine cover and taking a look one of the coil pack plugs from the wiring harness had come loose. I snugged it up and put a zip tie to hold it in place and that has seemed to fix the problem.
fener88
Mar 12, 2020 08:59 AM
XF1RE
Aug 31, 2019 11:13 AM
thegarman
Aug 24, 2018 10:32 PM
Kanadoos
Apr 20, 2015 08:42 PM
acrispy1
Oct 4, 2007 02:56 AM
