spoiler problems
Old May 6, 2011 | 07:29 PM
handyman's Avatar
Default spoiler problems
Newly acquired 05 convt. the spoiler works manually, but the speed activation doesn't. It did when test driven, but on return from dealer(6 hrs) noticed it didn't retract, or deploy??
Old May 6, 2011 | 07:47 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: spoiler problems
Hey another Crossfire from our nation's capital. Congrats on the new car.
I believe that the issue may be related to the battery. Have a look to see the colour of the battery. If it's white it is the original and when they go they cause funny stuff to happen to electronics, engine and noteably the spoiler. My car does not have the pop-up spoiler so I'm no expert but others will likely tell you what the issue could be.
Good luck and enjoy that car.
Old May 8, 2011 | 03:37 PM
A.M. Stalvey's Avatar
When I would crank the car, the spoiler would deploy and retract. Turned out to be a weak battery. Replaced battery and solved the problem. Recently, the spoiler would deploy and retract and then redeploy. Took it to the dealer for diagnosis. The sensor on the spoiler motor had failed. It seems you cannot buy a new sensor but must replace the motor. Had that done last week and spent a whopping $440.00, parts & labor.
Old May 8, 2011 | 03:46 PM
FUBU's Avatar
Can you get part#s that were changed? for future purposes..
Old May 8, 2011 | 05:54 PM
MikeR's Avatar
handyman, the other thing you might try is make sure you have taken it out of manual control. Try raising the wing manually all the way and then lower it all the way and hold the button until it 'dings'. That means it has retracted completely and should be in auto control again..... couldn't hurt..
Old May 10, 2011 | 09:45 AM
The part number is: 5161797. This is a Chrysler part number. Mercedes has no vehicles with a retractable spoiler. Hope this is helpful.
Old May 10, 2011 | 10:30 AM
JHM2K's Avatar
Except for the new SLS... $5 says it uses similar framework as the Webasto unit we have...
Old May 10, 2011 | 02:08 PM
And CERTAINLY so if you had been playing with the button (or the kids were, or the wife was, etc.)
Old May 10, 2011 | 02:13 PM
We?!? LOL I was under the impression you were unit-less Ironing board instead
Old May 10, 2011 | 02:26 PM
MikeR's Avatar
unit-less??? that is just mean....
Old May 10, 2011 | 05:47 PM
JHM2K's Avatar
After the first four hours it stayed up, I simply accepted it as a new identifying trait
Old May 10, 2011 | 05:59 PM
Thirteendog's Avatar
after 4 hours I think you're suppose to call your doctor... I'm not sure, maybe you should ask Steve. He's old enough to require that product
Old May 10, 2011 | 06:05 PM
JHM2K's Avatar
I doubt Steve would call a doctor, he'd phone a lady-friend and grab a handycam.
Old May 11, 2011 | 11:10 AM
Priapism, known also as Hulseyism
LMAO
Old May 11, 2011 | 11:59 AM
downwardspiral's Avatar
Bruce Willis was dead the whole time
Old May 11, 2011 | 01:58 PM
Question Re: spoiler problems
When I bought my XF new, I thought the spoiler button operation would 'ding' after full deployment or retraction. Now it does not 'ding' any more. Is there a problem with this? I thought if you manually extended or retracted it, when you cycled the ignition (park then drive later) it would be reset. Strange, it works fine, but the 'ding' doesn't 'ding' any more.
Any guidance/help on this issue?
Old May 11, 2011 | 02:46 PM
IBLUBYU's Avatar
RingaDingDing ....... sorry ... couldn't stop myself
Old May 11, 2011 | 02:55 PM
I don't remember it ever dinging when I had a limited.
Old May 11, 2011 | 03:18 PM
Yea, it beeps once when it's all the way extended or retracted. Not sure what would make it quit beeping.
Old May 12, 2011 | 03:17 PM
Thumbs down Re: spoiler problems
OK, page 106/107 in the owners manual says the 'ding' should be there when manually raising or lowering the spoiler. Once deployment speed is reached though, it automatically deploys open no matter what. Guess I'll have to take her in to have it looked at, don't need a problem like this run past the 3/36 warranty...
Lockhouse
Mar 20, 2024 04:50 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
davidc90
Sep 6, 2015 10:37 PM
