Dash lights go crazy, stuck in first gear, BAS light on and off
Old Dec 31, 2021 | 02:24 PM
Bzak1pgh's Avatar
Default Dash lights go crazy, stuck in first gear, BAS light on and off
My son has an 05 Base and lately when starting out or even in the middle of driving, all the lights on the dash start flicking, BAS/ESP stays on, rpm guage fluctuates up and down along with gas guage, then once we come to a stop, it's stuck in first gear. Pull over, restart the car, it's fine but a hard second gear shift. Replaced battery, brake pedal sensor to no revale. Can a wheel speed sensor do all this? It's doing it more frequently now like daily. Only code that reads is a Serial Communication Link, Crankshaft Position Sensor A Circuit....
We replaced the Conductor Plate 2 years ago due to shifting issues and it fixed that problem then.
Old Dec 31, 2021 | 04:29 PM
Default Re: Dash lights go crazy, stuck in first gear, BAS light on and off
If it says CPS problems change that. Easy and cheap to fix. If it is the CPS then one day it will not start.
Old Dec 31, 2021 | 05:16 PM
Bzak1pgh's Avatar
If it says CPS problems change that. Easy and heap to fix. If it is the CPS then one day it will not start.
Do u think that what's causing all the drama?
Old Dec 31, 2021 | 07:16 PM
EXACTLY what codes are you getting? P0xxx - tell us what the values in the xxx are.
EXACTLY what 'lights' are coming on? "Dash lights" to me means backlighting, but I get the idea you don't mean backlighting.
This kinda sounds like a failing Traction Control relay or similar issue with the RCM - but the idea it clears by restarting the car kinda blows that idea.
Old Dec 31, 2021 | 07:57 PM
Bzak1pgh's Avatar
P0335 & P0600 All lights, like battery, seat belt, engine light, etc....but the BAS ESP will stay on until we restart the engine. Everyone of them will come on and go off, like flickering on and off the entire time until....again....a restart then all stop. RPM fluctuates where u can here it and feel it in the power, like if it raises u hear it and if it lowers u hear it but also feel the power difference too if that makes any sense at all....lol. but I'd we come to a stop the car will stay locked in 1st gear and if luckily it shifts to second, it will be stuck there in second...until again....restart then it's fine for a while...
Old Dec 31, 2021 | 10:33 PM
This is not a wheel speed sensor.
P0335 usually means a bad Crank Sensor.
But the P0600 is another matter, it points to failed communications between modules but does not tell us which modules, you can assume it's failed communications from the ECU to another module.
Given the lights coming on like that I'd suggest the following:
1) Replace the Crank Sensor with a Bosch part from German Auto Supply, FCP Euro, etc.
2) Replace the RCM or send it to DJ for evaluation (he will replace bad relays and reflow any suspect solder paths).
3) I'd take a REAL close look at battery post connections, and the ground from the block to chassis or maybe install one of these modifications:
https://www.crossfireforum.org/forum...le-engine.html
I get the idea you have failing power to the ECU/Brake Controller/TCU/Instrument panel, this can be in the RCM or in the electrical (battery/alternator) system in general.
Old Dec 31, 2021 | 11:57 PM
Do the CPR first and see if it makes a difference, then if no change do the RCM. Do not do them all at once otherwise you never know what caused it and you have wasted money.
Old Jan 1, 2022 | 12:48 AM
Bzak1pgh's Avatar
Ok, I'll start with the Crankshaft Position Sensor and then do the module. Do u have the contact info for the guy who does the RCM? And lastly, THANK YOU!!! I've read a lot on the forums but they all hit around my issues with my son's car but not exactly what's happening, and dealships around here are useless....
Old Mar 8, 2022 | 02:08 PM
Bzak1pgh's Avatar
Well believe it or not, the Right Rear ABS sensor caused all this!!! It wouldn't come out of 1st gear, dash guages flickering, RMP guage cutting off and coming on, car wouldn't start, etc. Pass this on!!!! Put on the new sensor, and wella, purrs like a cat!!!
Old Mar 8, 2022 | 05:41 PM
DeKalb's Avatar
Been following this ... what led you to the Right Rear ABS sensor ... glad to hear you got it fixed, but how did you learn that was the problem?
Old Mar 8, 2022 | 07:08 PM
Bzak1pgh's Avatar
well the BAS kept coming on and I did some digging on the P0600...there was a lot of variety with this code so I just kept going through the process of elimination and the last (of course) was this sensor. With luck it was the first sensor I came to and replaced. Knowing this now, I'm going to replace the rest of them so I'm not stuck again at 10mph. I just STILL cannot believe that the ABS sensor can actually do all this to a car....computers I guess...I thought for sure it was the TCM but after testing it, I moved on to the next thing...imagine how many others this affected and who would of thought this!!!????
Old Mar 8, 2022 | 07:20 PM
DeKalb's Avatar
Thank you for your reply, will keep this information in my pile ... glad you found it ... enjoy
Old Mar 9, 2022 | 07:28 AM
Great follow-up & feedback on this issue. Thanks
Old Mar 17, 2022 | 06:02 PM
direwolf's Avatar
Great hear it was just the speed sensor freaking out the ABS (which then caused no speedo / limp mode).
Kustomiza
Aug 19, 2023 03:21 PM
TR6P
Jul 12, 2019 07:30 PM
jimcross
Nov 23, 2016 02:32 PM
mmann
Apr 9, 2016 10:05 PM
rfors777
Sep 1, 2010 04:54 PM
