Oil Level Sensor
Old Aug 21, 2016 | 05:32 PM
Default Re: Oil Level Sensor
Originally Posted by kamilspider
I think the same and I will do this at next oil change
I agree with your solution. We both know if it doesn't work, nothing is lost. I like to think the least expensive solution is the BEST. If that solution didn't work, it either didn't cost much, or it cost nothing. OMG, this philosophy ribs wrong with a lot of people who have too much money and not a lot of time to solve their problem with their own situation?
I'm a FIRM believer in 'trust but verify'. Especially when someone else wants to spend my $'s under the guise of 'advice'. Before I spend, I want to know I did all I could with my limited resources, to make sure every $ counts.
Old Aug 22, 2016 | 08:31 AM
Fla_Xfire_SRT's Avatar
very very nice write up Jerry, Admin please sticky this. Mark
I second the motion for the STICKY....I'll need to do this soon to one of my Xfires, can't remember which.
Old Mar 20, 2017 | 01:16 PM
performanceisland's Avatar
funny thing, looked up parts in autozone:
under 2005 chrysler crossfire srt-6 it shows part number su6904 for $300
under 2003 mercedes slk32 amg it shows part number 0061532728 for $100
oem mercedes part number 2759050000 (updated part from 0061532728) is $100 wholesale $125 retail.
pics look the same, any reason why these two cars would have different parts for this?
Old Mar 20, 2017 | 04:12 PM
Yeah, FCA/Chrysler wants to screw you royally (IMHO)....
Old Mar 20, 2017 | 04:42 PM
They are most likely the same part, but you pay Chrysler for going to the Mercedes dealer, picking up the part and putting a Chrysler label with the Chrysler part number on it over the top of the Mercedes label. That has got to be worth $200 or why bother to get out of bed.
You probably would get the updated part as well instead of the obsolete part.
Look at your oil pump the Mercedes number is on it somewhere.
Old Mar 20, 2017 | 06:36 PM
Seems the same part number is on ALL crossfire year/models including the SRT-6 AMG motors (oil level sensor).
Old Apr 27, 2017 | 06:14 AM
kamilspider's Avatar
Finally I do this!
Yesterday I clean my engine inside.
For engine flush I used 1L kerosene.
After 20km trip I add 1L kerosene to engine for about 15min and next change oil and filter for cheapest but new. Today and after 100km I changed for good quality oil and filter again.
Now my oil level sensor works OK, no bips!
Old Apr 27, 2017 | 08:10 AM
Finally I do this!
GLAD to hear! Sometimes, it is the simplest things that work. Like I said in post 19! I do not guarantee this is the reason all the sensors stop working BUT if it works afterwards it saves a lot of time, saves a messy cleanup, and saves a few bucks on parts and lack of use of the car. I know for a fact, ppl sometimes put WAY TOO MUCH OIL back in the engine so it figures to be bound to happen it gets stuck. In all my oil changes, I never add more than 8 US quarts, and that brings the level (on level ground) to right on the top FULL mark. I am going to put only 7 1/2 US quarts in this may (I do mine once a year due to low miles driven), just to see if it'll read that it needs oil (experiment). Again, ready glad to hear you got it 'unstuck'!
Old May 11, 2017 | 08:02 PM
liljay's Avatar
Just FYI. If your sensor is not bad and just leaking, you can change the o'ring for $5 bucks. I know I did it. Found the advice on SLK World forum.
Old Jul 12, 2020 | 04:47 PM
208james@gmail.com's Avatar
I think I my have a small leak at the sensor not enough to drip but is wicking up the wiring to behind the the stereo amplifier. Do I have to remove the oil pan and sensor as as described above or is it possible to replace o-rings etc from the outside. Thanks
Old Jul 13, 2020 | 09:31 AM
James,
I sent a message to someone on Facebook who recently went thru this - expect a reply here today.
Old Jul 13, 2020 | 09:52 AM
Crystal's Avatar
I just did mine yesterday... Unfortunately you do have to remove the oil pan to get to the o-ring.
Old Jul 13, 2020 | 10:23 AM
Crystal's Avatar
Old Jul 13, 2020 | 04:52 PM
Thanks. Is it possible to see if the oil sensor is leaking without taking off the pan inorder to know if I need to order one before starting. I am assuming I can see it if I remove the plastic rock shield under the car. I did look at the transmission sensor and it may have a small leak but didn't get to removing the rock shield to look for the engine oil sensor. Thanks
Old Jul 15, 2020 | 01:51 AM
Crystal's Avatar
Yes, I actually knew mine was leaking before I removed the oil pan. I was under there because of the trans leak and I was just looking everything over. I saw a ton of oil in that area and I posted about it. I posted pictures too. Bob McCubbin told me my oil level sensor o-ring was leaking. It was obvious when I removed it.
Old Jul 15, 2020 | 09:49 AM
Thanks for the help. I will take off the stone shield and have a look
Old Nov 12, 2020 | 07:12 PM
nelro_PL's Avatar
My unfortunately leaks again. New oring and leakage again.. I have a little more oil tan it should be. May it be the reason of leakage? I suppose I have at about 200ml more than max oil level. I just put all oil from 2x4 liters cans.it started leaking the sam day I replaced it..;/
Bought new one, at mercedes dealer....
Old Nov 12, 2020 | 07:32 PM
  #38 (permalink)
I always put in 8 litres as per the manual and never have any trouble.
Are you sure thatl is the area of the leak?
Old Jun 29, 2022 | 02:23 AM
  #39 (permalink)
John&Terry's Avatar
Thank you for this write up. It is very helpful, even 12 years later.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
lazorouss
Sep 11, 2015 09:16 AM
